Is there another thread on Wild Guzzi that explains the beer bottle buildup, operation?
I've never seen the beer bottle. I always used the yardstick, hose, and trans fluid to balance
Obviously we only need two, but this shows the idea fairly well.There are other on YT, just search 'DIY Carb Balancer'https://www.youtube.com/watch?v=0HfrHLmpHCY
I apolagise for the pictures but the thumb nails are so small I cant see what I am putting up. I had 12cm hg with the carbtune on the trike, but only 8 or less on the two wheeler at the same rpm.Wth?The bottles are more sensitive.
Are you meaning mercury compared to mercury?Valve clearance. Cam profile. Obviously vacuum leak. Ignition timing might (not sure on that).
The tube over the top acts as a syphon to move fluid from the side with lesser vacuum (higher absolute pressure) to the side with stronger vacuum (less absolute pressure), at some point where the carbs are almost balanced the transfer of liquid will stop and the relative vacuum will be indicated by the liquid height.I imagine unlike a simple "U" tube manometer it is quite well damped as the inside diameter of the bottles is many times greater than that of the syphon.It's very clever really
I've a question: to the extent that there will always be a head of fluid in the fluid transfer line of the bottle which is transfering fluid to the other bottle -
We used to use mercury in the instrument shops because but it's pretty much banned as being too dangerous nowadays. Spilling a mercury manometer in your garage would be considered a major environmental disaster these days.
A carb tune is measuring the weight of mercury as a standard. Not the weight of some other liquid in a tube or beer bottle. Unless you have a known chemical of equal weight of mercury in tube attached to a scale with the correct index reference points calculated based on the i.d. of the tubing, there is know way to properly set the correct vacuum setting on a carb or set of carbs or f.i. butterflies. Balancing two or more may be possible, but to get the correct idle vacuum setting is very questionable. The density of water compared to mercury is huge. Over 13-1. Meaning 1 inch on a mercury gage is over 13 inches on a gage with water. You can be out a couple of inches with a light chemical in tubes and still be within tolerance if compared to mercury gages. Don't fool your self with these homemade balancing systems.
Are you not both setting idle mixture on carburetted models (using a combination of highest vacuum achieved and highest engine rpm) - with the Hg columns + ear... and then also adjusting throttle valve take up (play in the cables.... for equality thereof) with the Hg columns?
When I was a kid, a cousin that was in dental school was always bringing me a vial of mercury to play with.That explains a lot..
No the manometer has nothing to do with the mixture AFAIK, it is just used to set the balance.A manometer or the beer bottles measure the difference in pressure directlyCarbtune sticks or Vacuum gauges measure the difference indirectlyThere are many types of manometer, some of them will measure low pressures, fractions of an inch with extreme accuracy.
I remember at a school Biology class, the experiment was something to do with germanation I think. There was a glass cylindrical open vessel filled with Mercury and an upturned test tube under partial vacuum. The Mercury rose up the test tube and there was a small gap at the top, in there was some sort of seed or beanAnyway there was a problem and I can't remember what, but the teacher asked me to literally give here a hand. We were both up to our wrists in Mercury trying to do something, although what is lost in the sands of time, for quite a few minutes.Given the panic that the stuff generates nowadays I still can't workout how I'm not dead (but perhaps it affected my memory). I know it can have real bad long term affects, so looking forward to that As far as U tubes go for balancing I got some unwanted Mercury from my old firm when it went to the receiver and they were junking all sorts. Years later I managed to find 2 good U tube manometers and then another large single one, both on E-Bay for reasonable money. Now I have a pair, I can use one on each cylinder, or use the large one and connect both cylinders to either side. Before I do use them I check with gauges that the Vacuum is in a range where there is no danger of sucking the stuff through the engine
I think I'm confused. On my Loops and EV there is a connection in the manifold to hook a gauge to. Isn't that where both styles are hooked up?RER: I used to use a gauge similar to that, it was a pain to read on my Loops and you had to try to hold the throttle the same when you checked each side. I now have a pair of vacuum gauges instead.Tom
Mercury poisoning is extremely rare with less than 500 deaths annually worldwide. Mostly caused by coal burning and eating fish.
