Author Topic: How to find the washer  (Read 9678 times)
Offline GonzoB
    • Gonzo Projects
« on: November 04, 2019, 07:48:40 PM »
Imagine that you've just taken the tank off your '07 Breva to do some work on the bike.
Imagine then you have to remove the left mirror.
Now imagine dropping the 10mm washer from under the mirror stalk onto the top of the left cylinder. It makes a tinkling noise as it SOUNDS like it is dropping between the fins somewhere towards the base of the cylinder.
You can't see it because the airbox and frame tubes are in the way.
You can't be sure where it is, but you know it's not on the garage floor.
After you've tried looking in there with a tiny camera, fishing for it with a magnet, and blasting the fins with compressed air, what's next?
SWMBO said, "why not leave it there?"
Suggestions please....
Gonzo
My '07 Breva 750 Projects: MCC cruise - Luggage - Shorter Shocks -
Offline Gliderjohn
Re: How to find the washer
« Reply #1 on: November 04, 2019, 07:53:08 PM »
Pick the bike up upside down and shake. :grin:
Back in central KS
« Reply #2 on: November 04, 2019, 07:57:28 PM »
 Giant paint shaker ?
Offline pete mcgee
« Reply #3 on: November 04, 2019, 08:35:39 PM »
Ah the infamous garage blackhole.....every workshop has one, if you find yours can i have my sock back.
Have you looked under the airbox or at the bottom of the V between the cylinders? Also have another look around on the floor, steel on alloy = bounce.
Another trick you might try needs 2 to 3 people is lean the bike as far over to the other as possible and try the compressed air again.
Or find 5 islanders and turn it over and shake............so rry.
« Reply #4 on: November 04, 2019, 09:01:05 PM »
It'll be in the last place you look  :grin:
« Reply #5 on: November 04, 2019, 09:38:30 PM »
Do you think it will cause some catastrophe if you just forget it's even there? Just get a new washer for the mirror and ride.
Offline 80CX100
« Reply #6 on: November 04, 2019, 11:16:17 PM »
I've got a few of those black holes in my garage :rolleyes:
Compressed air & magnets are good bets; I've sometimes lucked out probing into every thin black hole I can reach with a really thin long screw driver or dental pick style tools, fwiw
Get the best smallest brightest light down into the dark holes that you can, seeing what I'm doing is a challenge.
I've sometimes gone in looking for one thing, and found something completely different, ie washer/nut, now that's a head scratcher lol  :grin:
Good luck
Kelly
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
Offline Huzo
« Reply #7 on: November 04, 2019, 11:45:55 PM »
Wait ‘till you do the next oil pressure switch.
You’ll be able to get it once the  airbox is off
« Last Edit: November 04, 2019, 11:47:39 PM by Huzo »
Offline Perazzimx14
« Reply #8 on: November 05, 2019, 04:56:01 AM »
I'd forget about it and move on with my life.
Offline malik
« Reply #9 on: November 05, 2019, 05:42:56 AM »
If that Breva's a 750, the airbox doesn't need to come out if you've another pair of hands helping from the other side. Doesn't find the washer, tho'.
Offline antmanbee
« Reply #10 on: November 05, 2019, 06:27:39 AM »
Just remove the airbox. It is easy. :wink: Here is how I did it.
« Reply #11 on: November 05, 2019, 06:35:07 AM »
Where *is* that like button?  :grin:
Online John A
« Reply #12 on: November 05, 2019, 09:46:38 AM »
The other day a die from a cable&wire stripper departed the tool and found its way into the black hole.  It has been eluding me for four days and I’m thinking I will throw the rest of the tool into the back of a toolbox where I won’t remember it when and if the die shows it’s cowardly face. I heard it hit what I thought was an open drawer but that doesn’t seem to be the case.  I understand the need to find that washer, it’s not that it cannot be replaced, it’s not knowing if it’s somewhere that it could cause some unknown catastrophic damage.  In your case it might be better to forget about it but I’m guessing it’s in the pocket that the lower frame rail forms where it starts to curve aft.
« Reply #13 on: November 05, 2019, 11:38:40 AM »
I have one of those black holes as well. If I find it, I'll grab that sock while I'm in there.
Have you tried one of those small mirrors on a stick with a flash light? Put the mirror where you want to look and point the light into the mirror, it lights up where your trying to look.
Could it be on your front rim?
Good luck!
« Last Edit: November 06, 2019, 01:29:17 PM by Tom H »
« Reply #14 on: November 06, 2019, 01:21:46 PM »
..... it’s not knowing if it’s somewhere that it could cause some unknown catastrophic damage.
If it had fallen into the cylinder or down a cam chain tunnel I could understand that concern, but I don't think there's any place that a washer could get to on the OUTside of an engine that could fall into the potential catastrophe category ... known or unknown!   :thumb:
« Reply #15 on: November 06, 2019, 01:51:58 PM »
I LOVE it!!~!!  Classic.
I was reinserting the rear wheel after rep[lacing the battery shield that had obviously stopped a large goolie, and I had my little pile of those infernal rubber cush blocks.  On installing them I found suddenly I was one short.  I had placed them in that little pile when I started, there were none missing when I started, I did not shift the pile or molest it in any way, yet suddenly one is missing. I gutted the place.  It still resides in the black hole.  I had to order a new one.  Blinkin Gremlins. :evil: :evil: :evil:
Offline Daleroso
« Reply #16 on: November 06, 2019, 02:26:13 PM »
Experienced and tried all the above including spiraling out fm dropped location, placing left cheek (of face) on the floor to scan then right cheek (again fm face). Haven't lost a thing since my wife 1st asked if she could help. Pride aside I conceded. She found it under 5 minutes. Since then after a reasonable search I ask her & without fail she finds it. Uncanny. She claims it's the uterus.
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #17 on: November 06, 2019, 02:33:19 PM »
No need on the Breva 1100 either.  Just remove the LH header pipe.
Offline SIR REAL ED
  • uh.... it's personal....
« Reply #18 on: November 06, 2019, 08:07:44 PM »
Buy her a beer for me.  One of the other benefits of marrying a woman, is you never have to remember anything.  Since they never forget, you can just ask em.
Always best to start out the request with "Hey honey, have I told you how much I love you lately?  I can't seem to remember (or find)....."
2019 Beta EVO 250
Offline SIR REAL ED
« Reply #19 on: November 06, 2019, 08:11:11 PM »
IMO, highly skilled craftsman, who only shows pictures of their finished craft, rather than video's of them precisely practicing their skill sets so others can benefit from their experience, are a bunch of selfish SOB's!   :wink:
« Last Edit: November 06, 2019, 08:14:55 PM by SIR REAL ED »
2019 Beta EVO 250
Offline Motormike
« Reply #20 on: November 06, 2019, 08:24:57 PM »
As I've gotten older, my dexterity isn't what it used to be.  Now when I drop a small washer or screw, I don't even spend more that a few moments looking for it.  I just bite the bullet, go online and order a couple thousand extra of them so when I fumble it the next time it doesn't even slow me down!
Online nc43bsa
« Reply #21 on: November 06, 2019, 09:12:41 PM »
When I order small parts I always order 3 or 4 more than I need, just in case a couple go MIA.
After all, what's a few bucks, compared to a couple of hours spent looking for the only f@&king one you have?
« Last Edit: November 06, 2019, 09:14:49 PM by nc43bsa »
1990 MilleGT
Offline normzone
« Reply #22 on: November 06, 2019, 11:19:45 PM »
Offline GonzoB
    • Gonzo Projects
« Reply #23 on: November 07, 2019, 12:05:18 AM »
Well, I never found the washer. I assume it's going to rattle around in there (or wherever it is) forever.
Thanks for all your interesting suggestions.
No, I didn't find any socks.
Gonzo
Offline hzbloke
« Reply #24 on: November 07, 2019, 02:25:43 AM »
It seems that metal washers can perform miracles that even graduates of the Uri Geller Institute of Advanced Spoon Bending would have trouble replicating. My 'missing' swing arm washer thread is another example of the phenomenon.
Be happy in the knowledge that your are carrying a spare with you everywhere you go.
2019 Kawasaki Z900rs
2008 Breva 750
1986 BMW R65
Offline gearman
« Reply #25 on: November 07, 2019, 07:22:06 AM »
I lost  a 5 mm allen wrench .After looking all around and in the bike....nothing. My floor is smooth painted.I get the broom and sweep a ten foot circle. Nothing. I gave up and bought a not so good one.Weeks later I am using my lathe and sitting on top of it is the missing wrench.I do this all the time.
Offline Kiwi Dave
    • Guzzi Gander Ltd
« Reply #26 on: November 07, 2019, 01:33:30 PM »
Yep, it's called old age.  I do this all the time.  I'll be able to hide my own Easter eggs soon!
Offline pete mcgee
« Reply #27 on: November 07, 2019, 02:25:34 PM »
Gonzo
Bugger.........
« Reply #28 on: November 07, 2019, 07:19:13 PM »
Years ago I was replacing the clutch on a friend's EV. I found a HUGE numbers of nuts and washers between the motor and frame. At the lower front motor mount. On BOTH sides. He was like, "oh, that is where those went".
 :boozing:
« Reply #29 on: November 08, 2019, 07:01:38 AM »
I wouldn't spend much time looking for a washer that fell on the outside of a motorcycle. It'll either lay somewhere harmlessly or bounce out and fall on the road.
However..
I spent over a week looking for a 9/16" combination wrench that I couldn't find at the end of the day when working on an airplane.  :rolleyes:
