Author Topic: Will these work on controlling heated gear?  (Read 2296 times)
Online Perazzimx14
« on: December 04, 2019, 06:22:44 PM »
In the dead of winter I use on/off rocker switch for my heated jacked but in the more shoulder months it would be nice to be able to adjust the heat level. It would also ne nioce if they weren't $50 a shot so perusing Amazon I came across these 12V LED dimmers. What say ye think they will work?
https://www.amazon.com/FAVOLCANO-12V-24V-Dimmer-Channel-controller/dp/B01325KCSY/ref=sr_1_4?crid=2RRQFF93MRSAD&keywords=12v+dimmer+switch+dc&qid=1575505127&sprefix=12v+dimmer%2Caps%2C263&sr=8-4
2017 Road Glide Special
2020 Kawasaki KLX300SM
Offline moto-uno
Re: Will these work on controlling heated gear?
« Reply #1 on: December 04, 2019, 06:37:32 PM »
  If your heated vest draws less that 6 amps , it may be fine , and at that price what are you waiting for ?
Get back to us . Peter
Offline acogoff
« Reply #2 on: December 04, 2019, 06:54:01 PM »
     If it is the heat setting that is important to you, then yes that would probably work. But I also use an on/ off switch with a heated vest, but as a means of compensating for the limited output of my alternator. To me, a set up with that controller would be a continuous draw and would not work for my limited output electrical system. But what do I know?
Marshall County Minnesota USA
Offline Bud
« Reply #3 on: December 04, 2019, 07:24:32 PM »
     I think dimming a "Light Emitting Diode" and varying the voltage to a resistive heat load are two very different things. I would not do it.
Online nc43bsa
« Reply #4 on: December 04, 2019, 08:38:58 PM »
Dimming LEDs involves reducing the amount of time the current flows through the diode, as in ON for x milliseconds and OFF for y milliseconds, and repeat.
The dimmers you listed use PWM, which is Pulse Width Modulation.  I haven't read of anyone using that approach for limiting current through a resistive load like a heater.
1990 MilleGT
Offline antmanbee
« Reply #5 on: December 04, 2019, 10:04:58 PM »
A PWM will work great for controlling a heated vest. I use one that I made from parts for a LED controller. The better controllers that you buy from the heated gear companies are PWM.
A PWM will use less amps when you have it set on less than full.
https://wildguzzi.com/forum/index.php?topic=99540.msg1574064#msg1574064
Online Perazzimx14
« Reply #6 on: December 05, 2019, 05:03:24 AM »
Possibly right church wrong pew. Need to look for somethgin with a higher ampacity. My jacket draws between 6.9 and 7.9 amps.
Having adjustable heat is not of paramount importance but it would be nice a few few days in the fall and spring when it full on is just too much and off with base layers is not enough. Thats why I'm having a hard time spending $50 on a Gerbing controller.
« Reply #7 on: December 05, 2019, 09:40:15 AM »
Using a PWM dimmer like that is PERFECT for a resistive heater.
BUT, they are only 6 amp. I'll bet that your vest is near or over that. So I wouldn't use it, just because it is near or over the current capability.
What is the wattage if the vest you want to control?
Offline moto-uno
« Reply #8 on: December 05, 2019, 01:45:10 PM »
  I've a heated vest and sleeved vest made in B.C . They average 5 ohms . If Ohms law holds here , that's around 2.5 amps .
  Are you sure your vest is rated at (or close to 6 amps ? )   Peter
« Reply #9 on: December 05, 2019, 03:08:28 PM »
6 amps is about 120 72 watts at 12 volts.
Gerbing claims 6.5 amp for theirs.
https://gerbing.eu/en/heated-jacket-liner/#product-specificationsac4c-002a
My vest is rated at 60 watts. I measured it at closer to 50 watts actual. It is not very hot, but it does the job well and doesn't tax the charging system.
« Last Edit: December 05, 2019, 04:28:25 PM by Wayne Orwig »
Online StuCorpe
« Reply #10 on: December 05, 2019, 03:16:36 PM »
Wayne, when I went to school the formula was P=IE, how do you get that to agree with 6 amps, 12 volts and 120 watts?  Just curious but by my math 120 watts at 12 volts would be 10 amps.  6 X 12 would be 72 when I went to school.
« Reply #11 on: December 05, 2019, 04:27:01 PM »
I was brain dead. It is of course 72 watts.
Online StuCorpe
« Reply #12 on: December 05, 2019, 06:21:36 PM »
OK, thank you, I thought maybe my age and memory was worse than what I was aware of!  :grin:
