Author Topic: Convert flywheel  (Read 2428 times)
Offline dxhall
Re: Convert flywheel
« Reply #1 on: December 11, 2019, 09:47:15 AM »
That's the early, light, fracture prone, stamped item.
Offline brider
« Reply #2 on: December 11, 2019, 09:56:51 AM »
Yes, that's the "light" flywheel, but it can be made serviceable by applying a bead of weld or brazing the seam between the center bolt flange and the bowl itself. This seam is visible in the 2nd and 3rd photos from the left.....I had this done and it lasted 30k miles until I sold the bike. Original without the brazing fractured at 17k, and the fracture will occur at that seam.
And the price seems high for this risky version, most are almost give-away, if you can find them. A later heavier version that won't require reinforcement would probably cost less.
« Last Edit: December 11, 2019, 09:59:00 AM by brider »
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
Offline dxhall
« Reply #3 on: December 11, 2019, 11:09:08 AM »
Thanks for the quick responses.  If this were the good part, I thought I’d make an offer on it.  I haven’t found a convert yet, though, so I’m in no rush.
Offline mtiberio
    • TiberioRacing
« Reply #4 on: December 11, 2019, 01:41:02 PM »
answer: no. This is a good one:
https://youtu.be/I--NdcXOGkQ
Land Speed Records w/Guzzzi:
SCTA M-PG 1000 141.6 MPH
LTA M-PF 1000 137.3 MPH
ECTA M-PG 1000 118.6 MPH
Offline Aldo
« Reply #5 on: December 11, 2019, 01:53:32 PM »
I have a reinforced stamped one if interested; pics just below.
Cheers,
Aldo
« Last Edit: December 11, 2019, 02:47:36 PM by Aldo »
MGNOC Lifetime Member
1973 Eldorado 850
1971 Ambassador 1000 Automatic
1960 Gilera Giubileo 98
1967 Benelli Sprite 125
Offline Groover
    • Scooteropolis
« Reply #6 on: December 12, 2019, 08:00:39 AM »
Is there a difference in performance of any sort between the light and heavy ones?
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
« Reply #7 on: December 12, 2019, 08:19:49 AM »
I rode my buddy Leo's '76 Convert with the light "flywheel" and my '76 with the heavy flywheel back-to-back once. Really couldn't tell a whole lot of difference. Maybe slightly quicker acceleration and a bit more engine braking effect, but nothing real noticeable.
Offline mtiberio
    • TiberioRacing
« Reply #8 on: December 12, 2019, 01:53:00 PM »
Yes, but unless you are a nut like me building "the worlds fastest Guzzi automatic"(TM) for land speed racing, who cares.
Offline dxhall
« Reply #9 on: December 12, 2019, 01:56:33 PM »
When and where do you plan (hope) to run the LSR bike?  I’ve always wanted to go out to Bonneville for Speed Week.
Offline mtiberio
    • TiberioRacing
« Reply #10 on: December 12, 2019, 02:17:01 PM »
I visited El Mirage (the smaller red headed step child of Bonneville) in 2015 on a rental harley. A friend from LA was running, and I was hooked. It had miles of hot rods, quite the scene. The SCTA runs both El Mirage and Bonneville speed trials (same rules). Unless you need a long course, (and on my 142 MPH ex pro-twins racer, I didn't), I see no reason to go the the salt. It is dying, being mined out of existence. It is corrosive. I own a ranch 18 miles from El Mirage. After running all 6 events there in 2017, I got a job nearby and moved out in 2018. I was able to run the last 2 events of the year in '18, going 114 on my eldovert. I have since retired, and back in virginia, but still have the ranch, and plan to make it back in '20 with a hot cam and bigger carbs. visit: http://www.scta-bni.org/
Offline dxhall
« Reply #11 on: December 13, 2019, 08:17:00 PM »
What’s the spectator situation at El Mirage?   I’m retired now ...
Offline TN Mark
« Reply #12 on: December 14, 2019, 08:51:53 AM »
Sweet! Many years ago I was building one of my Converts for more power. I bought a lightened Convert flywheel from Moto International that looked just like the one in this video. If I didn’t need it to go into the bike I would have hung it on the wall as art. Those were some fun times. Did it make a difference in performance? Sure it did, but likely only because I knew it was their and what I paid for it.
