Author Topic: Crank Differences, early to later big twins  (Read 1650 times)
Offline rjamesohio
« on: December 18, 2019, 09:53:36 AM »
I've started laying out the parts to my G5, and since I have two roundhead motors I have been laying out the parts to compare.
As I was looking at the two cranks, I noted there is a vast difference in the crank nose on what I think is a later crank (pictured). The other one has a tapered nose that I believe was probably to accommodate the early alternators.
Therefore - to run the earlier alternator setup I'd probably have to use the other crank, not this one. But I'm guessing that this crank could be used with the later and more effective alternators.
Can anyone confirm or provide more details?
Ron James
Ex LM V
Ex SP1000
Ex Eldorado
Ex Quota - parts live on after crash
EX 1000G5
EX 850T3
EX 2003 V11 Stone
EX 1996 California 1100i
EX 2006 Big Breva
1979 1000 G5
1993 California iii
Spine Frame Mongrel
1999 BMW R1100R
Waynesville, Oh
9372715697
Re: Crank Differences, early to later big twins
« Reply #1 on: December 18, 2019, 11:17:59 AM »
Yes, Bosch (and Saprisa) alternator crank nose is short and tapered, Ducati crank nose is long and straight.
Offline rjamesohio
« Reply #2 on: December 18, 2019, 04:38:13 PM »
Thanks Charlie, I suspected that in general. Do you know if the later crank will work with an early timing chest cover? For example - with this engine I had planned to use an analog tach so I need the mechanical tach drive front cover but have not fitted everything up yet as the cam is a bit tight in the front bearing and I need to check that.
Thanks my friend - there's seldom a road in Guzzidom where someone else has not been down before you ;)
Ron
Ron James
Ex LM V
Ex SP1000
Ex Eldorado
EX 1000G5
EX 850T3
EX 2003 V11 Stone
EX 2006 Big Breva
1979 1000 G5
1993 California iii
Spine Frame Mongrel
1999 BMW R1100R
Waynesville, Oh
9372715697
« Reply #3 on: December 18, 2019, 08:17:16 PM »
Ron
The timing cover wasn't changed as far as I know, so it should be a direct swap.
Offline dblue
« Reply #4 on: December 20, 2019, 11:13:33 AM »
The throw can be different on the late crank, 78mm or 82mm depending whether it is a 950 or 1064cc,
David Blue
dfblue46@outlook.com
937-210-8721
