Author Topic: ‘07 Norge timingchain  (Read 2771 times)
Offline Huzo
« on: December 22, 2019, 01:08:46 PM »
This thread has been here before, but I can’t find it.
I still think my Norge sounds a bit slappy in the timing chain. I put a new one in with no dramas and got a new tensioner from Millepercento, to replace the piddly thing that’s currently there.
I also fitted a new spring.
To my dismay, I see there’s a bloody great lump of casting preventing the mounting of the new unit. Is there a way around this issue ?
I’ve asked this before but thought some new technique may have surfaced.
« Last Edit: December 22, 2019, 02:03:27 PM by Huzo »
Re: ‘07 Norge timingchain
« Reply #1 on: December 22, 2019, 01:33:15 PM »
Hey, is it on the RH side by the main bearing mount?  That was from an 03 Hydro motor that's documented here. Thought it may be similar.
Online Frenchfrog
« Reply #2 on: December 22, 2019, 01:36:31 PM »
Offline Huzo
« Reply #3 on: December 22, 2019, 01:56:33 PM »
Yes mate, it’s on the right when viewed from the front..(gearshift side, clutch lever side)
Pete is all over the issue and we’ve spoken about it, so I think I’m rooted.
I just don’t want to ignore something she might be trying to tell me...(the Norge that is, not Pete) :clock: :bike-037:
« Last Edit: December 22, 2019, 02:04:43 PM by Huzo »
Offline Huzo
« Reply #4 on: December 22, 2019, 02:02:32 PM »
something here Huzo https://wildguzzi.com/forum/index.php?topic=100365.0
Here’s the one I got from Millepercento.
It’s that dirty great lump of casting that’s the fly in the ointment.
The one pictured would fit as designed, under the two adjacent oil pump housing bolts but the casting precludes this.
Bugger..!
Offline Brian UK
    • Guzziriders
« Reply #5 on: December 24, 2019, 05:26:34 AM »
I found most of one of those tensioners in my Spada III. The spring had broken. Never found the end of it, just as well the bits didn't get caught in the chain. The slipper part was mangled up.
The Guzzi one works fine.
Brian.
Offline Huzo
« Reply #6 on: December 24, 2019, 06:24:10 AM »
Oh, OK..
Maybe it’s a good job it didn’t fit then.
Online Frenchfrog
« Reply #7 on: December 24, 2019, 08:11:40 AM »
The link i posted shows how Bill Owens "blended" the late type mounting plate to a spring loaded valtek tensioner....I'm guessing that that would work on your bike ? You do need to have an oxy acetaline torch to braze the two parts together though....
Offline Huzo
« Reply #8 on: December 24, 2019, 01:11:21 PM »
I’ll give Pete a listen sometime soon.
It might just be the combined slappiness of a 180,000 k motor, he’ll probably say it’s one of the better ones.
Online Frenchfrog
« Reply #9 on: December 24, 2019, 01:34:59 PM »
presumably you put the new chain in? didn't sound bad this summer but neither did mine till I slapped a new one in...have a good one !
Offline Huzo
« Reply #10 on: December 24, 2019, 01:47:30 PM »
Yeah, new one in.
