Author Topic: What coating/plating is this?  (Read 2253 times)
Offline SED
« on: December 22, 2019, 06:00:37 PM »
What is the brownish/gray coating on the spring tubes, fork links, shifter and ratchet, cush-drive, seat springs?  The catalog photo seems to show the same coating - not chrome or paint.
1983 LeMans III
1981 Monza
1947 Ariel Red Hunter
1939 Ariel Red Hunter
1937 Guzzi GTV
Online RinkRat II
  • Lake Powell AZ
Re: What coating/plating is this?
« Reply #1 on: December 22, 2019, 06:15:51 PM »
   A) Patina
   B) Iron Oxide
   C) Salt Air Corrosion
       Paul B :boozing:
« Reply #2 on: December 22, 2019, 07:24:45 PM »
What are "spring tubes"?
Offline SED
« Reply #3 on: December 22, 2019, 07:34:08 PM »
Hold the springs for the swingarm.
1983 LeMans III
1981 Monza
1937 Guzzi GTV
« Reply #4 on: December 22, 2019, 07:56:18 PM »
 Probably a form of Parkerizing .
Offline redhawk47
  • Traveler
« Reply #5 on: December 22, 2019, 08:28:31 PM »
   A) Patina
   B) Iron Oxide
       Paul B :boozing:
in other words: rust
Dan
Dan
Offline SED
« Reply #6 on: December 22, 2019, 08:39:22 PM »
It isn't as corroded as the chrome so I discounted iron phosphate Parkerizing.  Is there a way to make it more weather resistant?
1983 LeMans III
1981 Monza
1937 Guzzi GTV
« Reply #7 on: December 22, 2019, 08:49:47 PM »
 Not an expert , but I am aware of different techniques using zinc or manganese that give different results . We need someone who knows what the Italians were doing in that era .
Offline SED
« Reply #8 on: December 22, 2019, 08:52:23 PM »
I've seen that internet searching but they said both manganese and zinc needed a top coat.  Paint and oil were the recommended top coats.
1983 LeMans III
1981 Monza
1937 Guzzi GTV
« Reply #9 on: December 22, 2019, 09:00:12 PM »
 True , Parkerizing is really just a base coat , which I think is what you are seeing .
Offline SED
« Reply #10 on: December 22, 2019, 09:09:09 PM »
   A) Patina
   B) Iron Oxide
       Paul B :boozing:
 :grin:
1983 LeMans III
1981 Monza
1937 Guzzi GTV
Offline larrys
« Reply #11 on: December 22, 2019, 09:11:21 PM »
Zinc park is gray. Manganese park is black. The British used to use manganese park with black paint on top for their military firearms. Most other countries used manganese park and oil. That doesn’t look like parkerising on that bike.
Larry
« Last Edit: December 22, 2019, 09:12:19 PM by larrys »
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
Offline Groover
    • Scooteropolis
« Reply #12 on: December 23, 2019, 08:40:54 AM »
Makes me think of the same metal type used for strapping steel to strap heavy bundles, also used on stuff that needs to click back into place in mechanical-type gizmos. Springy type metal, typically dark, Just a guess. I'm also intrigued.
« Last Edit: December 23, 2019, 09:39:40 AM by Groover »
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline SED
« Reply #13 on: December 23, 2019, 11:11:46 AM »
Groover, I've been thinking the same thing.  I've got 100 year old pliers that are bare steel and don't rust easily.  Something about the steel protects it.  Modern Channel Lock pliers have the same type of coating at the teeth.
I'm starting to think it might be zinc or manganese phosphate with an oil film.  In the past I've used something called LPS3 that goes on as a liquid, but dries to a waxy film.  Once wiped off a thin brownish film remains.  Some of the brown may also be very small rust specks beginning to form.
In the photos, the fasteners, moving parts and links all seem to have the same coating and many repop parts come from Italy coated in black manganese rather than chrome, zinc or cad that is much more common now - even spokes are black.
Was there ever an industrial process where zinc or manganese phosphate coating was then coated by, say, boiling in linseed oil?
Any other ideas?
« Last Edit: December 23, 2019, 11:39:51 AM by SED »
1983 LeMans III
1981 Monza
1937 Guzzi GTV
Online John A
« Reply #14 on: December 23, 2019, 11:52:00 AM »
[quote author=SED link=topic=103899.msg1645496#msg1645496 date=1577121106
Any other ideas?
[/quote]
I think that’s it, linseed oil. Raw linseed oil does not dry,  boiled linseed oil dries into a very durable coating.  Either will spontaneously combust and will burn your shop down if rags are not kept in airtight containers so it’s use has largely been discontinued.  On gunstocks or other bare wood you rub in raw linseed oil, then boiled.  Then if the wood is scratched it won’t even be noticeable.  On ferrous items the boiled is baked on.
Rough Edge racing
« Reply #15 on: December 23, 2019, 11:57:35 AM »
 I have used a product called CLR on mild rust to clean it up and the end result is a smooth brown patina....Custom car and bike guys use it .....Then they wax over it to ffer a bit of protection...Some even clear coat it
Online John A
« Reply #16 on: December 23, 2019, 12:15:50 PM »
If you can find battery terminal protective spray that is not red,  it makes a good coating on nuts and bolts.  I used to be able to find it in silver but haven’t found that in years
Offline SED
« Reply #17 on: December 23, 2019, 12:21:01 PM »
Thanks for the help guys!
Might have to set up the camp stove in the driveway and boil some nuts in linseed oil!    :grin:
1983 LeMans III
1981 Monza
1937 Guzzi GTV
« Reply #18 on: December 23, 2019, 01:15:57 PM »
Went and had a look.  I always assumed it was Phosphoric acid at the heart of it but it is something called Sulphamic.  Never heard of that one.
Googled it,  H3NSO3.  Very useful sort of acid indeed.
