Author Topic: Car brakes - need help - Fixed  (Read 5279 times)
Offline Vince in Milwaukee
« on: December 24, 2019, 11:18:29 AM »
Looking to tap the collective wisdom of the group here.  My car is a 2005 Buick LeSabre.  While running errands yesterday, the red brake warning light came on.  Upon inspection this morning, I found my master cylinder was way low.  Filled it back up to the line with the correct DOT 3 fluid.  Well, the warning light is off, but now the pedal goes all the way to the floor and the brakes don't work at all!   :grin:  Since brakes aren't my strong suit, I may be having it towed to the shop.  Just wondering; did I get air in the system (quite likely), has my master cylinder given up the ghost, etc...?  Seeing how the car has @150,000 miles and is now 15 years old, I try not to get too upset about things like this.  Being that I'm rather cheap (Guzzi content), this beats a car payment any day of the week.
« Last Edit: December 31, 2019, 01:59:14 AM by Vince in Milwaukee »
Gone but not forgotten:
Offline GeneW
Re: Car brakes - need help.
« Reply #1 on: December 24, 2019, 11:26:22 AM »
Vince,
Having owned several cars that survived 15 years in WI, my bet would be on a rusted through brake line. Check for spots on the garage floor where the car was parked.
Gene
Rough Edge racing
« Reply #2 on: December 24, 2019, 11:36:41 AM »
 Later model  GM trucks are noted for rusted brake lines..I believe there was a class action law suit.....Buick is GM so as said above, rusted brake lines are a possibiity...
Offline OldMojo
  • Career of Evil
« Reply #3 on: December 24, 2019, 11:38:41 AM »
Yup. Ruptured brake line is #1 by a mile. In addition to the parking spot puddles, check the inner side of the tires for brake fluid splatter.
'15 Griso 1200
'14 California Tour
'02 California EV
'80 CB 650C
« Reply #4 on: December 24, 2019, 11:42:08 AM »
 Or you may have just sucked some air into the system that was pushed farther in by adding fluid . Try bleeding the brakes first .
Offline redrider90
« Reply #5 on: December 24, 2019, 12:12:49 PM »
It sounds like maybe you never check the brake fluid?  As the brakes wear the calipers require more fluid to operate the brakes. Hence it requires brake fluid from the master cylinder. So it is possible you just never filled you MC in time and like Dusty said you have air in the line.   If you have a leak from a rusted line just fill the MC with fluid and let it sit on concrete floor and check for leaks. Leave to cap off the MC to make it easier for the hole to leak. I will leak just sitting there but pumping the peddle will sure find the leak even with air in the line. Otherwise get someone to pump the pedal and you start bleeding. Start at the left front and then right front. Move to the back left and then the right back side. If you have a leak it will reveal itself.
I just put new calipers in the front of my 4X4. After I got done bleeding all 4 wheels my brake light and ABS light were still on. There is a little switch in the master cylinder that got stuck. I very gently hit it with a rubber mallet and the lights went off.
Red 90 Mille GT
« Reply #6 on: December 24, 2019, 12:46:16 PM »
Definitely get it towed over trying to drive it to a shop.
« Reply #7 on: December 24, 2019, 01:01:18 PM »
Its' broke, throw it away.  Its' just a car.
« Reply #8 on: December 24, 2019, 01:32:16 PM »
Just got home from taking the girlfriend out to lunch in HER car.  Yup, big ole puddle of brake fluid under the rear passenger side.  Looks like my car will be getting a tow to the shop right after Christmas.
Offline nc43bsa
« Reply #9 on: December 24, 2019, 01:32:39 PM »
The front brakes on my 99 Regal failed on the way to the grocery store one night.  I turned around and parked at my house.
A few days later I was moving it into position to determine what was wrong and the rear brakes failed also.
Both brake lines had rust holes.  It was the first time I'd had that happen to one of my vehicles, but it was also the first time I had one that had spent most of its life in the rust belt (Columbus.)
1990 MilleGT
« Reply #10 on: December 24, 2019, 02:29:05 PM »
 That puddle would be a good clue Vince  :grin:
Offline pressureangle
« Reply #11 on: December 24, 2019, 02:43:56 PM »
Dimes to donuts it's a brake line to the rear; which means if you push hard, you'll blow a rusty front line as well.
Possibility is that it's the rear cylinders leaking (if it has drum brakes) But as everyone else has said, you live in the rust belt and it's a serious consideration to just throw the car away. Repairing brake lines is a fool's errand.
« Reply #12 on: December 24, 2019, 03:19:52 PM »
This happened to me on a couple cars, why don’t they make brake lines from stainless or something else that won’t rust?
« Reply #13 on: December 24, 2019, 03:40:46 PM »
Price, nothing else.
Offline nc43bsa
« Reply #14 on: December 24, 2019, 03:46:12 PM »
And encouraging owners to discard their cars when they rust out.
1990 MilleGT
Offline Furbo
« Reply #15 on: December 24, 2019, 04:45:21 PM »
This is actually a pretty simple straight forward repair. Finding someone with the skills to do it can prove challenging.
Killeen, TX
'96 Sport 1100
'72 N. Falcone
'72 Eldo
Eccl 9:9,10
Offline wirespokes
« Reply #16 on: December 24, 2019, 06:57:52 PM »
Being a Guzzi owner, you should have no trouble fixing it yourself. They sell brake lines at the auto parts store. Get the correct size flare wrench and replace them. There may be problems removing the lines and freeing up the bleeders though if they're also rusty.
Offline old head
« Reply #17 on: December 24, 2019, 07:18:55 PM »
Sounds like a rear brake wheel cylinder has failed if you have rear drums.  If it has failed, then change the cylinder and the pads on both sides, bleed the system as most likely you have air in the lines.  Could be anything from  a wheel cylinder to a brake line, hard to say until you get into it.
Old Head.
06 Breva 1100
Hepco-Becker crash bars
Givi A620 screen
Garmin GPS
« Reply #18 on: December 24, 2019, 07:39:19 PM »
Really sorry to hear this as I just spent $400 for 4 new tires.  So you're saying that it's not worth the cost / trouble to replace the bad lines?  It seems that all of the lines will need to be replaced if I go that route.  Maybe I need to get out now before I throw more $ away.  Can't seem to find a good used car that I like.   :sad:
« Last Edit: December 24, 2019, 07:42:54 PM by Vince in Milwaukee »
Offline old head
« Reply #19 on: December 24, 2019, 07:51:46 PM »
Well, I would fix it unless the car very rusted or the drive train is in need of major repairs, but that's me.  I find it cheaper to repair and keep driving rather than buy someone else' problems with a used car.   At least you know what is fixed and don't have to worry about it in the future.
Old Head
06 Breva 1100
Givi A620 screen
Garmin GPS
Offline nc43bsa
« Reply #20 on: December 24, 2019, 07:55:15 PM »
I went to the local salvage yard and bought ALL of the brake & fuel lines from the firewall back for $50.
Fortunately, there was a donor car with the engine/transmission already removed, which made it much easier to remove the lines.
1990 MilleGT
Offline redrider90
« Reply #21 on: December 24, 2019, 08:18:09 PM »
If the puddle is in front of the tire then it's in the brake line. If it is coming off the rear wheel cylinder then the puddle will be right next to the tire and you might even see where it leaked out down the tire.
Red 90 Mille GT
Offline 80CX100
« Reply #22 on: December 24, 2019, 08:38:26 PM »
I did this job last year on the main front brake line on my GMC plow truck in February out in the snow not fun.
It's really not that big a job, but as others have pointed out, the hardest part is getting the rusty fittings apart without causing more damage.
If you can locate the point of the leak, follow the line to the fittings at either end, I'd be soaking them and the appropriate bleeding screw with atf/acetone or similar asap so they'll come apart for you.
If you keep the m/c reservoir topped up with fluid to keep as much air out of the system as possible it will make for an easier job, usually a standard pre-made brake line can be bent to fit.
Good luck
Kelly
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
Offline Two Checks
« Reply #23 on: December 24, 2019, 09:09:31 PM »
Quote from: nc43bsa on Today at 07:55:15 PM
You bought old, unknown quality brake lines? Do you have a death wish?
New lines are not expensive. This is not a place to be cheap.
I just had this done on my 05 Taurus. About $300. New OEM lines.
That's much less than one car payment and you know the new lines won't blow out.
1987 1000 SPII "Il Duce' II"
Offline Matt Story
  • Flint, MI
« Reply #24 on: December 24, 2019, 10:14:45 PM »
Since I live in the rust belt, and have sworn off buying cars new, I have needed to replace brake lines on several cars.  The stuck fittings are the worst problem with the job.  Doing it myself though, I can easily justify buying the connected components new.  Generally having the intent to keep the vehicles for the long term makes it easier to replace an otherwise good caliper or wheel cylinder.  Drum brake cylinders are so cheap replacing them is a no brainer financially.  For an added bonus, lifetime warranty components are usually available.  With all new components, the job becomes much easier.  Instead of buying pre-bent replacement lines, I have always opted for lacing bulk tubing through the vehicle, cutting to length and installing flair fittings at either end.  It's not as hard as it might seem, and removal of the old line is not necessary.  Stainless, coated steel and copper alloy bulk tubing are all available.  I opt for the copper alloy as it offers good corrosion resistance and is quite easy to form as you lace it through the vehicle.  All new lines need to be properly retained so they can't be damaged by road debris.
'75 850T - First & only owner
'77 Honda CB750 Supersport
'02 BMW R1150RT
Flint, MI
Offline nc43bsa
« Reply #25 on: December 24, 2019, 11:25:38 PM »
You bought old, unknown quality brake lines? Do you have a death wish?New lines are not expensive. This is not a place to be cheap.I just had this done on my 05 Taurus. About $300. New OEM lines.That's much less than one car payment and you know the new lines won't blow out.
The car I pulled the lines from was completely rust-free, and the OEM brake lines were not available from GM.
1990 MilleGT
Offline Two Checks
« Reply #26 on: December 25, 2019, 04:46:17 AM »
What did those lines look like from the inside? Brake systems develop moisture over time.
I wish you good luck.
« Reply #27 on: December 25, 2019, 06:58:10 AM »
Old Head
Thank you for the positive encouragement.  It's still a very nice car with just some minimal rust around the rear passenger side wheel well.  Word has it that the 3.8L V6 is an old work horse and is good for a lot of miles.  I've shied away from getting a new car as they have so much electronic crap on them.
Offline s1120
« Reply #28 on: December 25, 2019, 08:00:17 AM »
Been there more times then I can count. When you live in the rust belt, added to the new salt mixes they use on the roads, anything over 10 years old is go start rotting away under you.. Replacing the lines are not a hard job... but can be a bit of a pain in the butt. Small old school independent shop would be your best bet to do it IMHO. Haveing worked at a dealer for 25 years ive seen that most new car tech's just dont have the mindset to do this kinda work.
Paul B
Offline Vagrant
« Reply #29 on: December 25, 2019, 09:14:42 AM »
fix it right or junk it. your choice but why do the lines and not do the wheel cylinders too. they will be next to go and if you have my luck it will be in a month or so after the cheapo repair. same holds true for the pads and shoes. and yes find a independent shop. owner / operator who has been there for years.
