Author Topic: Starter Grease Suggestion  (Read 1345 times)
Offline shiskowd
« on: December 24, 2019, 03:03:49 PM »
First - Merry Christmas fellow Guzzi brethren!
I pulled apart the Bosch starter from my 850T to take a look and clean (how can something this grimy still function?).  All appears to be fine once I washed away years of grit and gunk.  Is there a recommended grease to apply to the bushings and lever??
'14 KTM 500 EXC
'10 KTM 690R Rally
'75 Moto Guzzi 850T
Re: Starter Grease Suggestion
« Reply #1 on: December 24, 2019, 04:16:59 PM »
On the sintered bronze bushes I just use engine oil.
Look at the armature for signs of rubbing on the pole pieces, a sign that the bushes need replacing.
A little common grease or Graphite grease on the pinion cog will quieten it down for a while.
Brushes and commutator stay dry.
The solenoid plunger should stay dry or perhaps no more than a couple of drops of 3in 1
Yes the old Bosch starters will last forever with a little TLC
« Reply #2 on: December 25, 2019, 03:46:13 AM »
I thought I would do a search for the sintered bronze bushes used in the starter
You used to be able to pick them up at a local Auto Electrician but I haven't tried lately
I couldn't find them on the www
Several sites list the brushes, I wonder how long that will last, how can you blame a local Electrician if he will only sell you a complete starter when Amazon is trying to take over the world
MG Cycle will sell you a rebuilt starter
http://www.mgcycle.com/index.php?main_page=product_info&products_id=606
We had better support our suppliers or they will all dry up
« Last Edit: December 25, 2019, 03:49:14 AM by Kiwi_Roy »
Offline cookiemech
« Reply #3 on: December 25, 2019, 03:54:36 AM »
If you have the "157" series Bosch starter (used on Moto Guzzi and BMW), then here's a source for the bushings:
https://www.euromotoelectrics.com/Starter-Tune-up-Kit-BMW-MG-BO157-TK-p/bo157-tkplus.htm
« Reply #4 on: December 25, 2019, 07:00:39 AM »
Thanks for that, I suggest if you have an old Guzzi or Beamer you buy one of their $17 overhaul kits for it while they are still available.
