Author Topic: Moly additive  (Read 3910 times)
Offline ampm7
Moly additive
« on: February 18, 2020, 06:42:29 PM »
I have used Moly additive (Guard Dog Moly and the previous Houston Co.) on all my Guzzi's in the final drive and trans in the Ambassador but was wondering whether it is needed in the newer Eldorado. Frankly, on my previous Guzzi's it made quite a difference but I will change the oil in the "transmission" as the Italians call the final drive when I change rear tires even though the manual says I don't need to but sometimes the Italians are stingy on the amount of grease and oils that they use. Any thoughts? The bike runs great!
1970 Moto Guzzi Ambassador, 1998 EV, Honda 1972 850 Ambassador, 2022 Indian Super Chief Limited
Offline lucian
Re: Moly additive
« Reply #1 on: February 18, 2020, 06:50:53 PM »
The short answer is no. Any good synth gear lube is fine, I use valvoline synpower 75/90 in my 1400 custom. Change it with every rear tire change. No issues in 24,000 miles
« Last Edit: February 18, 2020, 06:54:34 PM by lucian »
Offline 80CX100
Re: Moly additive
« Reply #2 on: February 18, 2020, 07:37:13 PM »
     I'm not familiar with that Moly additive or the 1400 bikes but I'll throw out these thoughts for your consideration.
     I've used a variety of Moly additives in the rear end diffs and can't see why it could cause problems, I'm not sure if it's needed though, especially with a high quality synthetic.
     I don't want to sound like a broken record, because I've mentioned this a few times already; but the last Moly additive I used was marketed and sold as a very high end super duper gear and manual transmission additive, I normally didn't add Moly to the tranny oil, but when I had a little left over from the rear end, I dumped it into the 5 speed tranny on my CX100.
     Shortly after, I had tranny issues and showed scarf in the fluid; I haven't cracked the tranny yet, but I suspect a thrust bearing failure.
     Apparently gears like Moly, but bearings don't, the Moly bonds so well that the bearings can cake and load up and not spin freely, fwiw ymmv jmho
     Good luck
     Kelly
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
Offline Burkslaw
Re: Moly additive
« Reply #3 on: February 18, 2020, 07:59:48 PM »
I once read that moly can cause a roller bearing to stop rolling and slide instead, leading to failure. I think I saw that on the internet, so it is true.
Offline kirby1923
  • '81 CX100
Re: Moly additive
« Reply #4 on: February 18, 2020, 08:22:37 PM »
Actually true believe it or not.
Moly additive probably should not be added to you machine unless the manufacturer requires/recommends its use.
The friction properties,(very slippery), will/can... cause  "skidding" (damage) on high speed roller bearings.
Guzzi recommends (my manual CX 100) a small amount in the rear drive. Don't know about other models of Guzzi.
FWIW
'81 CX100
Offline ampm7
Re: Moly additive
« Reply #5 on: February 19, 2020, 02:09:25 PM »
I've always used Amsoil synthetic gear oil and not had any problems with my VII and my EV but just in the final drive and not the transmission. I did however use it in my 1970 Ambassador in the tranny-so far no problems. The amount that is recommended in the final drive is 10-20%. At least in some of the older models. But I think it is good advice to change the oil everytime a new rear tire is put on as the 50,000km service seems excessive. You definitely want to use the liquid Moly for the drive and the grease for the spline. Thanks for your input.
Offline skippy
Re: Moly additive
« Reply #6 on: February 19, 2020, 03:57:40 PM »
Short answer, no.
Long answer, almost all, if not all Moto Guzzi's prior to the CARC bikes required a small amount of moly as specified by Moto Guzzi. I am not aware of any of the current bikes with such requirements. It very well maybe because of the advancements in lubrication technology but it most definitely is not the manufacturer being stingy. Moto Guzzi, and all manufacturers, specify lubrication requirements with not only reliability and longevity in mind but with mileage and efficiency as well.
I have read here some where, or maybe even in my own owners manual from my 06 B11 Breva that moly in the transmission (Bevel Drive) is not specified and will cause bearing damage.
Just my two cents.
Skippy
23 V100 Mandello
20 V85TT
Offline n3303j
  • Ron Cichowski
Re: Moly additive
« Reply #7 on: February 19, 2020, 06:58:48 PM »
I don't run Molybdenum in any final drive or transmission (BMW, Ural or Moto Guzzi). I've looked at some I've run 80K miles and the gear faces are burnished to a sheen with negligible wear. I do run Amsoil Severe Gear 75W90.
I did buy a '98 V11EV that was run with Molybdenum for the 36K miles before I bought it. The ring gear needle bearing was failed. I figure it was the Molybdenum additive.
I assume someone at Guzzi owns stock in a Moly additive company (or 40+ year old oil formulas failed to perform under sliding pressure of gears)?
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline s1120
Re: Moly additive
« Reply #8 on: February 20, 2020, 07:32:02 AM »
I hate when these threads come up...  I am getting ready to change the fluid in my final drive and I have the moly...  but now dont know if I should use it!!
Paul B
Offline kballowe
  • - Kevin the Great -
Re: Moly additive
« Reply #9 on: February 20, 2020, 07:42:22 AM »
 :bike-037:
Ride more, worry less
 :bike-037:
Re: Moly additive
« Reply #10 on: February 20, 2020, 08:15:23 AM »
It is certainly not needed if you are using synthetic. If you are using dino oil, the manufacturer calls for it. Pretty easy..
Offline bodine99
Re: Moly additive
« Reply #11 on: February 20, 2020, 09:01:27 AM »
I am a fan of Redline Shockproof almost 20 yrs in my 76 airhead trans & final drive. Also Water Wetter in our 1 water cooled bike. No issues
Offline kirby1923
  • '81 CX100
Re: Moly additive
« Reply #12 on: February 20, 2020, 09:23:37 AM »
I have found that red line does sorta tame the 5 speed but another benefit is that if you find a bit of a spot on the shop floor and its pink from the box, black from the rear drive (I use the specified moly) and amber from the engine.
'81 CX100
