Author Topic: Stelvio Bar Risers  (Read 2974 times)
Offline Steve350f
Stelvio Bar Risers
« on: February 24, 2020, 08:41:26 PM »
Quick question.  Looking to add handlebar risers to my 2017 Stelvio.  Any suggestions or comments on these 2 types?  Also, with either of these would I need longer cables?
2016 Eldorado
2017 Stelvio
1973 Eldorado
1973 Norton Commando
1972 BMW R75/5 Toaster
1971 BSA B50MX
1976 Kawasaki KZ750 Twin
Offline HarveyMushman
    • Photo Galleries
Re: Stelvio Bar Risers
« Reply #1 on: February 24, 2020, 10:13:52 PM »
I have the Rox. You won’t need longer cables, but you need to re route the cables from aft of the forks to in front.
Tim
Offline menzies
« Reply #2 on: February 25, 2020, 08:45:10 AM »
What HarveyMushman says, had the 1 1/2" Rox on my Stelvio.
2001 Triumph Bonneville
2007 Triumph Bonneville
2006 Triumph Scrambler
« Reply #3 on: February 25, 2020, 10:09:15 AM »
Just for my curiosity ....
Why bar risers on a Stelvio?   I can see them on a Sport or Lemans, but the bars on my Stelvio are plenty high for me - I wouldn't want even another 1/2".    On a long trip, I stand up every 20 minutes or so to get the blood circulating, and the bars are just right for that.    I'm 6'2" with a 32" inseam, therefore "long-waisted" as they say ...
Is it for off-pavement riding?   Or just a really tall rider?
« Reply #4 on: February 25, 2020, 10:29:38 AM »
The Rox Risers work well, only downfall is it can be difficult to cinch the bolts on the bar clamp, as the bar now fouls at least one set of bolts...  I had good luck cinching them down without the bar in place, note the gap, then set the rearward bolts with the front bolts loose, then you can rotate the rox riser into place and cinch down the front bolts to get your gap correct....
Offline thechief86
« Reply #5 on: February 25, 2020, 01:11:46 PM »
I have used both kinds, on a few different bikes. I prefer the Rox risers, and have been using the set on my KLR 650 for a few years now, through lots of tough offroad riding and over 25k miles, and have yet to experience a failure with them.
They are more versatile than the other type, and allow a wider range of bar positions.
I've never had to lengthen cables for 2" or less of difference.
Offline severely
« Reply #6 on: February 25, 2020, 04:39:08 PM »
I appreciate the adjustability of the ROX riders but I took a simpler route. Bought some 2"x1.5" aluminum stock and cut to length;1" for me; and center drilled a 10.5mm hole for riser bolt and purchased a 1" longer bolt. Loosened the bottom bolts of risers under top triple clamp, remove bolt, place riser block under risers and install longer bolts. I only had to rejiggle the cables a bit but no replacement. Fairly cheap to change to get a real idea where you really need the bars. You can even machine the blocks to match the risers. Good luck. :bike-037:
« Last Edit: February 25, 2020, 04:40:23 PM by severely »
Offline Blueboarhound
« Reply #7 on: March 26, 2020, 11:30:49 PM »
Motobits may be another option for you.
http://www.motobits.com/guzzi.htm
1993 Ducati 900SS
1993 Moto Guzzi Daytona 1000
1996 Moto Guzzi Sport 1100
2012 Moto Guzzi Stelvio NTX
Offline Steve350f
« Reply #8 on: March 31, 2020, 06:22:42 PM »
So will I need to move ALL cables, including the break lines?
2016 Eldorado
2017 Stelvio
1973 Eldorado
1971 BSA B50MX
Offline Green1000S
« Reply #9 on: March 31, 2020, 07:34:30 PM »
I have Motobits, works great. I had to open the cable ties, rearrange cables and make sure they were not binding.
No need to remove cables, just rearrange.
Lannis, I ride often standing (mainly gravel roads and in woods) and the raisers are necessary for me, other vise I would have to hunch down and you could not ride long like that....
We all have different leg heights, hand reaches and back heights.
Lauri
2014 Green Stelvio NTX
2016 Stornello #101
1972 Bultaco Matador SD
2016 KTM Duke 390
1968 Riverside MW 125
Ciao!
Offline Steve350f
« Reply #10 on: March 31, 2020, 07:48:37 PM »
I believe the Motobits is a 1” rise, the Rox are 2”.  May make a big difference.
2016 Eldorado
2017 Stelvio
1973 Eldorado
1971 BSA B50MX
Offline Steve350f
« Reply #11 on: April 01, 2020, 11:28:52 AM »
With the Rox risers, am I going to have to separate the brake and clutch lines to reroute?
2016 Eldorado
2017 Stelvio
1973 Eldorado
1971 BSA B50MX
Offline farrider2
« Reply #12 on: June 24, 2021, 03:31:25 PM »
Just installed a set of MotoBits bar risers on a 2013 Stelvio. Fast delivery, great fit and easy install. Highly recommend Brent and Motobits.
Ride Fast - Ride Far
    • Photo Galleries
« Reply #13 on: June 25, 2021, 05:41:22 AM »
A little late but no.  You remove the top plate from the forks, move the cables and brake lines, and reinstall the plate.
Tim
