New question, so part of this conversion will be machining (EDM) the 1100 EV cam nose so it can accept the hex bit to drive the ATF pump. I Have looked around but have not seen if it's possible to remove the cam shaft and leave the heads, push rods, followers, and tapets in Situ?
The Ducati alternator will work fine, no problem there.I wouldn't mess with an electric pump for the ATF.. just adds more complications.
Will the long crank nose and Ducati Alternator work with the Convert front cover though?Ciao
Yes, nothing is different. The Ducati stator bolts directly to the cover, the front seal is exactly the same size.
