Bike-lift mods
Topic: Bike-lift mods (Read 1798 times)
GonzoB
Hatchling
Bike-lift mods
March 02, 2020, 05:00:38 PM »
Hi All.
I have this bike lift, left over from my Harley days:
Lifting Harleys was easy as the frame rails stick out below the engine. Not so for MGs.
So I don't have to re-invent a solution, has anyone done a mod, eg a "cradle", for a Breva 750, or similar?
I've got a centrestand fitted, so it's not *really* needed, but I've got the lift so.....
Gonzo
Last Edit: March 02, 2020, 05:01:10 PM by GonzoB
My '07 Breva 750 Projects:
MCC cruise
Luggage
Shorter Shocks
Dharma Bum
Re: Bike-lift mods
Reply #1 on:
March 03, 2020, 12:22:09 AM »
Gonzo, I had one similar to that . I used a piece of half inch plywood for a deck that the sump rested on with wood pieces added to the back to grab the frame rail behind the transmission. Not at my house currently, but I'll try and post a pic in a day or so.
Rick4003
Gaggle Mentor
Re: Bike-lift mods
Reply #2 on:
March 03, 2020, 03:10:02 AM »
I got a lift a bit similar also, a bit smaller I think. I just put a piece of plywood on top and lift under the sump. Works fine with the old big blocks. I don't use it to lift super high, but it is very handy for working on the front end of the bike.
Moto Guzzi Ambassador - 1967
Yamaha FZR 600 - 1996 - SOLD
SIR REAL ED
uh.... it's personal....
Re: Bike-lift mods
Reply #3 on:
March 03, 2020, 05:26:52 AM »
I made one for my Nevada when I wanted to remove the forks. I made it out of wood since it was not going to be used often.
Two vertical 2x4's about 5" long under the frame rails, a 2x4 and a 2x2 to tie them together and keep them vertical.
I'll try to post a picture later on today.
2019 Beta EVO 250
Global Moderator
Re: Bike-lift mods
Reply #4 on:
March 03, 2020, 08:09:02 AM »
Wood blocks work fine with my ex HD jack with any bike.
DougG
Gaggle Mentor
Re: Bike-lift mods
Reply #5 on:
March 03, 2020, 08:38:03 AM »
Hi Gonzo, 03-03-20
Ditto, what Dan said. I actually used 4x4's and bolted them to the jack plates so that they would not twist or drop off. It seems to work well and safely.
Be well,
DougG
A possum playing possum is no big deal. Find one that can play giraffe, now you got yourself something!
SIR REAL ED
Re: Bike-lift mods
Reply #6 on:
March 04, 2020, 07:56:13 AM »
Crude farmer fixture:
2019 Beta EVO 250
GonzoB
Hatchling
Re: Bike-lift mods
Reply #7 on:
March 04, 2020, 09:00:59 AM »
Thanks for the suggestions. I'll break out the timber and saw!
Gonzo
MCC cruise
Luggage
Shorter Shocks
Dharma Bum
Re: Bike-lift mods
Reply #8 on:
March 04, 2020, 11:31:30 AM »
One more!
John Warner
Gaggle Mentor
Growing old is mandatory, growing up is not . . .
Bike-lift mods
Reply #9 on:
March 05, 2020, 12:16:41 AM »
For my home-made lift, I made a small 'cradle' that bolts on in place of the Centre-Stand, then the arm on the Lift Carriage slots into that.
You could probably do something similar, but have the two uprights welded to a flat plate that will fix to your lift top.
With the use of some Straps, you could adjust how the Bike sits once lifted, like I do on mine, Level/Front up/Rear up.
Doc out . . .
Stelvio Owners Group on FB ~
https://www.facebook.com/groups/888995181188209/?fref=nf
GonzoB
Hatchling
Re: Bike-lift mods
Reply #10 on:
March 05, 2020, 12:41:40 AM »
Wow, Doc. I love the "Stoppie" position. Also the plywood backing for your bags. Timber is much under-utilised material on motorcycles!
The ideas are really coming out of the woodwork! <sorry>
Gonzo
MCC cruise
Luggage
Shorter Shocks
John Warner
Gaggle Mentor
Bike-lift mods
Reply #11 on:
March 29, 2020, 01:39:38 PM »
Every Bike should have a bit of Wood on it somewhere!
The lift is extremely useful, don't know how I managed without it really.
Doc out . . .
Bike-lift mods
