Author Topic: Monster LEDs  (Read 2904 times)
Offline larrys
Monster LEDs
« on: March 06, 2020, 08:28:51 AM »
I am considering replacing the halogen bulbs in my Monster's headlight with LEDs. Went over to Ducati.ms and posted the question but got no response. That place doesn't seem to have the level of traffic that we enjoy here. Any recommendations/cautions? There isn't a lot of space in the headlight shell behind the bulbs. Some of the emitters I looked at on the innanet have long extensions on the backs of them and they don't look like they would fit in the shell.
TIA
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
Online rocker59
Re: Monster LEDs
« Reply #1 on: March 06, 2020, 08:45:26 AM »
I think you'd be better off replacing the entire headlight unit.  Search 7" LED headlamp on Ebay and you'll find lots of choices.
Just sticking an H4 replacement LED into the OEM reflector will not net very good results.
This subject has been discussed here quite extensively.  You should be able to search up the threads.
Re: Monster LEDs
« Reply #2 on: March 06, 2020, 09:13:30 AM »
Without knowing what bulbs it uses, I can't really recommend anything.
It's not a normal 7" round headlight.
"Just sticking an H4 replacement LED into an OEM reflector" worked out very well the two times I've done it. Well, the first time wasn't exactly an OEM reflector, but was an aftermarket Hella H4 reflector. The second was the V7 Stone. Both have/had nice wide beams of light with no dark spots, easily the equal to the JW Speaker LED sealed unit in my Convert. The LED bulb I used is the key - the ADVMonster Native H4R2. http://stores.advmonster.com/native-h4r2/
Results with other bulbs were not nearly as good.
« Last Edit: March 06, 2020, 09:21:25 AM by Antietam Classic Cycle »
Online rocker59
Re: Monster LEDs
« Reply #3 on: March 06, 2020, 09:25:52 AM »
Thanks for the info!   :thumb:
Re: Monster LEDs
« Reply #4 on: March 06, 2020, 09:34:19 AM »
 Yeah , thanks Charlie .
Online bad Chad
Re: Monster LEDs
« Reply #5 on: March 06, 2020, 09:39:27 AM »
I put a Safego LED in my CSC 250, is the same dimensions as a halogen h4, and makes far more light.  It was $38 bucks a year ago when I bought it, I now seem them advertised for about $10!   Has worked great no issues what so ever.
1988 YX600 Radian
Offline n3303j
  • Ron Cichowski
Re: Monster LEDs
« Reply #6 on: March 06, 2020, 09:57:55 AM »
https://tinyurl.com/w998nev
Same bulb but half price (actually you get two for $51) from Amazon. (I have both original and Amazon versions.) Happy with light pattern. Brighter than H4 and no rear protrusion issues. Wonder how long that microscopic cooling fan will last?  Did have to open up hole on Hella reflectors to fit this bulb. 3 minutes with a Dremel Tool and sanding drum. Plenty of material available in reflector opening so no strength compromise. Did not touch standard bulb nest in reflector so return to stock bulb is no issue.
« Last Edit: March 06, 2020, 10:00:20 AM by n3303j »
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Re: Monster LEDs
« Reply #7 on: March 06, 2020, 10:10:04 AM »
A friend tried a pair of the cheaper ones and had one fail almost immediately, the other about six weeks later. The one from ADV Monster has been in my V700 for nearly a year and is still working fine. I can hear the cooling fan spinning up like a tiny turbine every time I turn the headlight on.  :azn:
No alteration of the Hella reflector was necessary - "plug and play". On the Stone I removed a "filler ring" held on by two screws and then it fit in perfectly.
When I installed a Safego in a customer's '02 Special Sport, I did need to Dremel away some casting flash on the reflector opening for it to fit.
Offline n3303j
  • Ron Cichowski
Re: Monster LEDs
« Reply #8 on: March 06, 2020, 10:47:00 AM »
Running the 3 units for about a year now. No problems with any of them. (Including a cross country round trip on the Mictuning unit)
Holding the two units side by side there is no discernible visual difference. Doesn't mean the internals are identical.
Wouldn't be surprised to find that ADV was buying the Mictuning units and marking them up 100 %.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline 80CX100
Re: Monster LEDs
« Reply #9 on: March 06, 2020, 12:08:38 PM »
Charlie,     Thanks so much for doing the real world testing on these and other items,then taking the time to share the results on what works and what doesn't. :thumb:
It will save me and a few others I'm sure, the major hassle of trying to figure out what actually works while wading through hundreds of options on line. :bow:
Tks
Kelly
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
Re: Monster LEDs
« Reply #10 on: March 06, 2020, 12:16:24 PM »
TIA
Larry
Like some Guzzis, it appears there are three bulbs, one for low beam (H7 type) another for high beam (H1) and a small one for park/city light. I don't have any experience with LED replacements for either of those types.
Perhaps something like this would work for the H1?
https://www.amazon.com/Arastar-Headlight-Fanless-Waterproof-Conversion/dp/B07CNZPPC2
and a similar type for the H7?
https://www.amazon.com/Headlight-Conversion-Flicker-10000LM-Warranty/dp/B07TG74XY2
Offline larrys
Re: Monster LEDs
« Reply #11 on: March 06, 2020, 01:20:12 PM »
I posted my experience with LEDs in the previous post about them. I had very good results replacing the H4 bulb in my Cal with the ADV Monster Native H4R2. Same beam and spread, just much brighter.
My Monster uses two, an H7 lowbeam and an H1 highbeam, like Charlie said.
I took the plunge today and ordered the H7 and H1 emitters from these guys; https://ledlightstreet.com/. $50 shipped, we'll see.
Larry
« Last Edit: March 06, 2020, 01:40:28 PM by larrys »
'95 Cal 1100
'68 Bonneville
MGNOC 7248
Re: Monster LEDs
« Reply #12 on: March 06, 2020, 04:39:14 PM »
I have a Monster 796, same headlight as your 1100 Evo.
I have two of the predecessor to this one: http://stores.advmonster.com/h7-plus-led-headlight/
It was a tight squeeze, but, I got 'em in.
It now throws WAY more light on the road than it did with the halogen bulbs.    The beam pattern is OK, not great, but, that's not the bulb's fault, as it is pretty much the same beam pattern as it was with the halogens.
I don't usually ride this bike at night anyway, and was mostly going for the "be seen" factor.   The 25 (low) or 50 (low+high) watts power savings is nice too, as I know I can run heated gear w/o worrying about charging.
Offline bigbikerrick
Re: Monster LEDs
« Reply #13 on: March 07, 2020, 09:35:16 AM »
I used the"Native" based on Charlie's recommendations ,and have been very happy with it. Currently resides in my Cal II convert headlight, and the light output is great. Its been over a year ,and the tiny fan is still churning away!  A bit pricier than the others, but its Good stuff !  :thumb:
Rick.
