Author Topic: tubeless conversion with 3M 5200 and tape??  (Read 7919 times)
Offline s1120
« on: March 14, 2020, 11:51:30 AM »
OK, so I have read, and studied a lot of the threads on this subject, and soaked in a ton of information. That being said, I decided to go with the 3M 5200, with the 3M super sealing tape.  One thing I dont see anywhere, is when you put the tape on??  Do you wait till the 5200 is fully cured??  still tacky? Soft? Does it even matter??  Does anyone who have done this ever looked into this aspect of the conversion??
Paul B
Offline John Croucher
Re: tubeless conversion with 3M 5200 and tape??
« Reply #1 on: March 14, 2020, 12:09:07 PM »
No need to tape if you put on enough sealant.  This is 3 applications over a period of several days.  24 hours between applications and a couple of days for a final cure.  Acetone is your friend with 3M sealant.  It is the base solvent and cuts it good when cleaning up.
Offline s1120
« Reply #2 on: March 14, 2020, 12:18:02 PM »
Ya, I plan to break out the Acetone to smooth things out before I do the tape. I was thinking of just doing the sealer, but went with the tape in the end. Did you use the fast set, or the normal 5200??  I ended up with the normal stuff, and its been a slow process because of the long cure time. You can only do a handfull at a time, because it sags as you turn the wheel.
Paul B
Offline pyoungbl
« Reply #3 on: March 14, 2020, 12:59:03 PM »
Either 4200 or 5200 will work for this application.  Both are marine grad sealers.  4200 is designed to come apart at a later date whereas 5200 is meant to never come apart.  I had to chase a leak on my 5200 and it was fairly easy to pick out with an ice pick.  The key here is to clean the rim to operating room clean so the sealer will stick.
'13 V7 Special (red/white)
Offline hauto
« Reply #4 on: March 14, 2020, 01:11:30 PM »
Just ordered the tape.Will going the same route next week. Is the tape needed? Most people who were successful used 3M 4411n tape
Offline s1120
« Reply #5 on: March 14, 2020, 01:33:08 PM »
Ya thats what im using. I figure hedge my bets.
As for prep..  I wire brushed. I had some rusty spots that I hit with Naval jelly to treat. Brake clean, and wipe, then a final shot of rubbing alcohol for good measure.  Could it be cleaner??  Maybe but I did what I could.
Paul B
Offline ampm7
« Reply #6 on: March 14, 2020, 01:34:11 PM »
I used 5200 for years working in boatyards and I can tell you that stuff works! 4200 if you want to take it off at some time.
1970 Moto Guzzi Ambassador, 1998 EV, Honda 1972 850 Ambassador, 2022 Indian Super Chief Limited
Offline s1120
« Reply #7 on: March 15, 2020, 02:31:09 PM »
Well im not going to lie...  putting that tape on was a PITA!!!   But its done...  I think I got it sealed well..  I guess I will find out when the tire goes on.  The front rim is so narrow, with a small drop center, it was hard to work it all in. We will see how the rear goes. Some say to get the tire on right away to have air pressure pushing on it to seal it.... and some say wait. Right now the tire is ice cold so it will at least wait a few hours.
Paul B
« Reply #8 on: March 15, 2020, 05:14:16 PM »
I didn't have any luck getting the tape laying down like I wanted with the narrow drop center. <shrug> Ripped it out, cleaned everything up again  :rolleyes: and just used the sealant. That has worked very well indeed. So far.. :smiley:
Offline s1120
« Reply #9 on: March 15, 2020, 05:43:40 PM »
Took a bit but it seems to be laying down OK.. We will see I guess. The rear is wider, so I hope it will go better.
Did you use a rim strip on top of it??
Paul B
« Reply #10 on: March 16, 2020, 08:20:25 AM »
Nope, but I was careful installing the tires.  :smiley:
Offline s1120
« Reply #11 on: March 16, 2020, 11:43:46 AM »
I was asking because I had ordered new ones, [old were rock hard] and they were not due till the end of the week.. Well they showed up this morning, and I guess it wont hurt to use it....
Paul B
Offline larrys
« Reply #12 on: March 16, 2020, 01:16:41 PM »
Metoo. I use 3M 4000 for above the waterline applications, its got UV inhibitors. 5200 will give up the grip with some heat, propane or MAPP. Had to get some thru-hull fittings out without destroying them, the heat did the trick.
Larry
'13 Monster 1100 EVO
'95 Cal 1100
'68 Bonneville
MGNOC 7248
Offline BigDen
« Reply #13 on: March 16, 2020, 01:43:13 PM »
S1120, regarding using rim strips, Greg Bender on the This Old Tractor site says to use rim strips when installing the tires, then remove them after the tire is on.  He says "I (and others) have found that the rim strips can migrate and cover the valve stem. When this happens, the rim strip acts as a one-way valve, permitting air in, but not allowing any air to escape. This makes checking tire pressure a fruitless experience."  Here is the link to the TOT entry: http://www.thisoldtractor.com/moto_guzzi_loopframe_tires_-_tubeless_conversion.html.
Dennis
1976 850-T3
1974 850 Eldorado
1954 HD Panhead
1953 HD K Model
Offline Denis
« Reply #14 on: March 16, 2020, 09:37:37 PM »
Why not just put tubes in it?
'87 SPII
'74 Eldorado
'85 LeMans
'91 California big valve
'61 Falcone Turismo,
'41 Indian 841
'40 Indian Model 640B ex-Canadian Army
'40 Indian Chief 340B
Offline hauto
« Reply #15 on: March 16, 2020, 10:20:55 PM »
In the middle of a conversion myself.I cursed like hell dismounting my old tire.Just thinking of trying to do that on the side of the road would make my head spin.Thank you very much,but I'll just push a plug in and be on my way.
Offline s1120
« Reply #16 on: March 17, 2020, 06:55:27 AM »
The thought of changing a tube, on the side of the road, 4 hours from home, with no center stand, and cheap small tools. Im not as young as I used to be, and wrestling with a heavy bike on the side of the road just doesn't appeal to me any more.
Paul B
Offline s1120
« Reply #17 on: March 17, 2020, 10:31:30 AM »
Tire held air overnight!  We will check the "win" box for that one!!
Paul B
« Reply #18 on: March 17, 2020, 11:24:54 AM »
Attaboy.  :smiley: The tubeless spoked wheels on the G5  :grin: hold air longer than any other wheel I've had. It's probably because of the over the top cleaning I did on them.
Offline bigbikerrick
« Reply #19 on: March 18, 2020, 12:07:39 AM »
I am a big fan of tubeless conversions,and used the 3M 5200 slow cure on my Cali Aluminum 's  spoke wheels over 7 years ago, and many tire changes, without any problem whatsoever. I "glued" a rim strip over the top of the 5200 after it cured, but I really dont think it was necessary... .That 5200 is some tough stuff!!
I bought some of the 3M #4411 tape,  actually to do a fat tire,mountain bike tubeless conversion,and I am not sure I would trust it to stay put....  to me,It does not seem as tenaciously sticky as regular black Gorilla tape, for example.
Rick.
Offline hauto
« Reply #20 on: March 19, 2020, 08:26:12 AM »
I got my tape today in the mail.I'm questioning if it is really a 3M product.that I got.If you have a roll of 3M 4411 tape,does the cardboard core have 3M identifying logo printed on it. Mine has nothing on it.
Offline s1120
« Reply #21 on: March 19, 2020, 12:11:53 PM »
No. All I have seen is the 3M tape comes on huge rolls. They reroll it onto smaller rolls for sale. So its 3M...  just not a lifetime supply.
Paul B
Offline Bisbonian
  • Living the Dream
« Reply #22 on: March 19, 2020, 12:40:35 PM »
Rick.
It really is tenaciously sticky stuff, the 3M tape.
I used it on my Versys-X, just pay attention as you won't be pulling it back up.
