Author Topic: argh, leak at banjo inlet!  (Read 847 times)
Offline amamet
« on: March 20, 2020, 02:14:55 PM »
so I rebuilt my phf36 on the lemans, but the carb won't stop leaking at the banjo inlet.  I tried multiple banjos, bought new screens and have new gaskets.  I noticed that the mating surface on the carb is a bit rounded over on the bottom.  is this the culprit?  what can be done?
« Last Edit: March 20, 2020, 02:21:47 PM by amamet »
Re: argh, leak at banjo inlet!
« Reply #1 on: March 20, 2020, 02:28:12 PM »
Put on screen, line up lines on screen w/lines on carb. Put on banjo w/new fiber washer on bolt. Tighten till friction w/turning banjo. Spin banjo while tightening bolt so it all goes in groove. Position banjo before final tightening.
Offline acguzzi
« Reply #2 on: March 20, 2020, 03:16:29 PM »
is the screen new? maybe it is hardened? New fiber washer? The fiber washer is the only place I;ve had a leak before, if as guzzi Steve said, the screen and banjo are seated properly.
Offline amamet
« Reply #3 on: March 20, 2020, 07:01:32 PM »
thx steve, seems to have done it...for now :)
