Author Topic: can anyone dub/translate this transmission rebuild video?  (Read 1536 times)
Offline amamet
« on: April 13, 2020, 09:51:51 AM »
this seems like it would be a good tutorial, if they are doing it correctly, what do I know?
https://www.youtube.com/watch?v=v5VWLMEKNOM
Online acogoff
Re: can anyone dub/translate this transmission rebuild video?
« Reply #1 on: April 13, 2020, 01:37:28 PM »
   I'm no help in translating. But it shows somewhat how parts go together.  I see they just had some silicone for a gasket on the end case, not a good idea. I would use the normal 8 thousandths paper gasket and check the internal end clearances. Putting the shafts in the main case and fishing the shifter forks into position with a coat hanger is not hard at all ( A cheap harbor freight spring installation hook tool works too).  To each his own, but I would not do it that way. Without knowing what they were saying I do not know if they mentioned to replace the shifter spring or to shim the shifter drum properly, both kind of important.
Marshall County Minnesota USA
Offline theoneandonlymin
« Reply #2 on: April 17, 2020, 08:04:57 AM »
You may be able to open it in Google translate using the share arrow.
Cheers
Min
Offline amamet
« Reply #3 on: April 17, 2020, 08:08:56 AM »
I did and its hilarious.  its just neat seeing a hands on "rebuild".  I would think putting the everything in the case first would be the way to go.
