Author Topic: changing dot 3/4 to dot 5 brake fluid  (Read 1604 times)
Offline amamet
« on: April 14, 2020, 12:06:48 PM »
during the rebuild, I rebuilt both master cylinders and ultrasonic cleaned them, I was wondering if I should do the same to the calipers and clean the lines out to go to dot 5 brake fluid.  is it worth it?  this is what happens when you have too much time on your hands
thx
allen
Offline Rich A
Re: changing dot 3/4 to dot 5 brake fluid
« Reply #1 on: April 14, 2020, 12:15:56 PM »
I think Brembo says not to do this unless you replace the MC & caliper seals, but you should verify this. Dot 5 evidently can cause the seals to swell.
(Some have said they've done this with no problems)
Rich
Offline skippy
« Reply #2 on: April 14, 2020, 12:35:46 PM »
I would not recommend using DOT 5 unless it is DOT 5.1. Even then I would recommend DOT 4 be used and changed on a regular basis. But here is some information for you.
https://www.powerstop.com/different-types-brake-fluid/
Skippy
23 V100 Mandello
20 V85TT
Offline Old Jock
« Reply #3 on: April 14, 2020, 01:01:56 PM »
As per skippy, although personally I don't care much if it's 4 or 5.1, depending on the manufacturer and the type (racing etc:) I've seen DOT 4 with better Specs than 5.1
I always flush mine through ideally ever other year but sometimes go out to 3, if other tasks are a higher priority
I'd stay well clear of 5, never used it, but seen literature that it can attack seals unless the whole system is designed specifically for it.
Offline amamet
« Reply #4 on: April 14, 2020, 01:26:50 PM »
yes, sorry, meant 5.1, forgot about that.  the master cylinders pistons and seals have been replaced and cleaned, but the calipers and brake lines have been run previously with dot 3.  in order to run 5.1 or 4 would I need to rebuild the calipers and clean out the lines or are they compatible?
Offline amamet
« Reply #5 on: April 14, 2020, 01:29:28 PM »
google says 3,4 and 5.1 are all compatible, guess I answered my own question, guess ill go with dot 4
« Last Edit: April 14, 2020, 01:32:41 PM by amamet »
Online PeteS
« Reply #6 on: April 14, 2020, 04:03:39 PM »
When DOT 5 first came out I tried it in my Dunstall brakes. Bad idea. The motion became very notchy, like adding sand to the mix. Went back to Dot 4 and all was good again. I believe the higher number of the glycol base fluids have a higher boiling point. Use 5.1 in a race bike otherwise Dot 4 should be sufficient.
Offline moto-uno
« Reply #7 on: April 14, 2020, 11:25:57 PM »
  ^The other (real) advantage to DOT 5 , was when you spilled it on the paint and never noticed it , the paint wouldn't come off later
when you wiped it  :evil:,  Peter
Offline pat80flh
« Reply #8 on: April 15, 2020, 04:32:17 AM »
Can be done but all rubber in brake system must be replaced, including hoses and caliper seals, metal lines must be thoroughly cleaned. Iy is the mixyure of dot 4 and 5 which causes rubber to swell.
00 Bassa
80 FLH (in rehab)
75 850T prject
Offline Murray
« Reply #9 on: April 15, 2020, 05:44:07 AM »
I have found 5.1 solved a brake fade problem on my track bike so there is something to it, admittedly the local track is pretty brutal on brakes (3 very hard stops in just over a minute). For a road bike it won't do any harm and if it helps you sleep at night all good but I don't see it as absoutely required.
« Last Edit: April 15, 2020, 09:48:41 AM by Murray »
Offline s1120
« Reply #10 on: April 15, 2020, 07:10:46 AM »
5 avoid....  It lasts a long time, and doesnt eat paint...  but frankly I dont think its really good for much past that. I havent used 5.1 but it is compatible with 3 and 4, so if you want go ahead. Personally Ive never needed any more then dot 4..
Paul B
Offline sdcr
« Reply #11 on: April 15, 2020, 07:16:04 AM »
Is 5 and 5.1 compatible?
Or. would your braking system need to be flushed completely, if you have one of these fluids, in order to use the other?
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Offline s1120
« Reply #12 on: April 15, 2020, 07:35:34 AM »
5 and 5.1 are not compatible..  5.1 is more like 3 and 4..  I think its kinda stupid that they named the spec 5.1 being 5 is so different.. and the general public does not read...
Paul B
Offline sdcr
« Reply #13 on: April 15, 2020, 07:40:45 AM »
Paul,
  Thanks for clarifying. Yeah, I agree about the names.
2000 BMW R1100 RS
1983 BMW R100
2009 Jaguar XK
Offline roadventure
  • There is no try; There is only do.
« Reply #14 on: April 15, 2020, 10:33:54 AM »
Why?  Use what the OEM recommends. Unless you are into racing there is no reason to do otherwise.
dave
Millville, DE
"Moto Guzzi....you're never more than 500 miles from your nearest dealer"
