Author Topic: Norge service schedule  (Read 40963 times)
« on: April 18, 2020, 03:31:32 AM »
I’ve now done 213,000 km on the Norge, so that equates to 9 major services and 9 minor ones.
I note that in the owners book, the intervals are a haphazard conglomeration of disjointed mish mash. So I decided from the get go that I would do a MAJOR service at every EVEN 10,000 kilometres. 20,000 40,000 60,000......etc
And a MINOR service every ODD 10,000 kilometres. 10,000 30,000 50,000...etc
Below I will outline what I do in a MAJOR service.
Brake pads check and replace if necessary.
Check disc bobbins for free movement.
Clean the discs.
Spark plugs (inner and outer) replace…(Replacing inner plugs requires airbox removal, 10 minutes off 15 minutes back on)
Engine, gearbox, final drive oil change with filter.
Air filter replace.
Valve clearance check.
Air filter box clean/purge.
Fork oil change.
Brake and clutch fluid change.
Remove and lubricate brake and clutch lever/s.
Remove gear change lever, withdraw and clean/lubricate shaft pivot.
Lubricate rear brake and gearshift lever/s.
Clean battery terminals…(both ends).
Check tank cap drain.
Remove and lubricate side and centrestand.
Balance TB’s and check for DTC’s
That’s every EVEN 10,000 k
Now at every ODD 10,000 k..
Change Engine, Gearbox and Final Drive fluids.
There are some longer term items that I attend to at around 60,000 k intervals.
Alternator belt check/replace..(easy when the forks are out for changing fluid)
Fuel filter
Headstem bearings grease adjust.
Drive splines clean/grease.
Clean throttle bodies.
I cannot see how anything relevant can be missed if this schedule is adhered to, but let’s know if y’all have spotted something.
« Last Edit: January 12, 2026, 04:05:15 PM by Huzo »
Offline Andy1
Re: Norge service schedule
« Reply #1 on: April 18, 2020, 04:21:44 AM »
Looks good.
You ride a lot so not relevant to you, but some service jobs like brake fluid changes are done on a time basis rather than miles - maybe the fork oil change as well?
I do a similar thing with my bikes but because I do a lot less miles I also do a 1000 mile check of things like nuts and bolts and tyre pressures (or monthly).
andyB
« Reply #2 on: April 18, 2020, 04:25:25 AM »
Looks good.
andyB
That sounds reasonable Andy.
« Reply #3 on: August 09, 2022, 07:33:07 PM »
Bump for Kaladin
« Reply #4 on: October 01, 2022, 03:16:00 PM »
Bumped for SemperVee
« Last Edit: October 01, 2022, 03:25:17 PM by Huzo »
Offline SemperVee
  • USMC Retired
« Reply #5 on: October 01, 2022, 11:26:39 PM »
 Thanks Huzo... Cut and pasted.  Searching for fluids and parts now.    Staying with the previous original owners Redline 10-60 since Hi-Ho SIlver already has 48,000+ miles of smile on her.
« Last Edit: March 16, 2023, 11:07:40 AM by SemperVee »
2007 MG Norge - VroomHilda
2003 Cali Hydro EV
2012 Victory CCT
2007 MG RED Norge
14 Harleys 2 VStrom 1000's
« Reply #6 on: October 02, 2022, 12:17:17 AM »
 Thanks Huzo... Cut and pasted.  Searching for fluids and parts now.    Staying with the previous original owners Redline 10-68 since Hi-Ho SIlver already has 48,000+ miles of smile on her.
ok.
« Reply #7 on: March 11, 2023, 06:16:42 PM »
Bumped for Karkaliev.
« Last Edit: March 11, 2023, 06:17:27 PM by Huzo »
Online Pescatore
« Reply #8 on: March 11, 2023, 09:48:30 PM »
Fork oil change.
Fuel filter
Huzo, are you into making videos/taking pictures while you do the above tasks?
I am stressing out about removing the tank, I can't imagine removing the forks.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
« Reply #9 on: March 12, 2023, 03:40:19 AM »
Is your bike a Norge or Griso ?
Online Pescatore
« Reply #10 on: March 12, 2023, 07:25:52 AM »
2008 red Norge with 9k miles.
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
« Reply #11 on: March 12, 2023, 02:17:05 PM »
To get the forks out..
Loosen the pinch bolt in the top triple clamp.
Lightly loosen the fork cap nuts with a six sided socket.
Remove the front wheel along with the front fender, calipers and speed sensor.
Fully loosen the two clamping bolts each side on the bottom triple clamp.
The plastic cover on the top clamp does not need to come off.
Now the tricky bit..
BLOODY GENTLY tap a suitable flat blade screwdriver into the slot (top and bottom), that the pinch bolts bite onto when you tighten the clamps, to open the gap slightly. If you overdo this you risk breaking the clamp.
The top clamp needs to be accessed from underneath.
The forks will slide out easily.
« Last Edit: March 16, 2023, 06:51:55 AM by Huzo »
« Reply #12 on: March 16, 2023, 07:09:10 AM »
Now, the tank…
Start by undoing these two bolts, one each side.
Undo and remove the rear tank securing bolt…(10 mm socket).
Slide the tank backwards a couple of inches.
Lift the rear of the tank about 4” and place a block of wood under the rear where the bolt was, to get some clearance.
Undo the multi pin electrical plug that powers up the fuel pump etc.
Disconnect the air vent hose where it goes from two into one.
Stand on the right (rear brake lever) side of the bike.
With your left hand, hold the red fuel output elbow that comes out of the bottom of the tank.
While you are supporting the elbow, push the fuel line onto the elbow spigot to it’s comfortable limit, (you’ll hear a faint “click”).
Keep hold of the fuel line with your right hand and bring the grey plastic collar on the female fuel junction fitting towards your right hand.
Now with BOTH hands, place your 1st and 2nd fingers behind the grey collar with your thumbs against the elbow and slide the fitting off the spigot.
This method will not put any bending force on the elbow…(you might not even break it…!).
Then lift the tank off and walk away with it.
Offline Bigtime
« Reply #13 on: March 16, 2023, 10:25:44 AM »
  Huzo, greatly enjoy and appreciate your write ups on the Norge. I have a '09 2v that I just finished servicing ( alt. belt, inner plugs, throttle body cleaning fluids ect). My charging voltage has always been a bit low for my liking ( around 13.6 to 13.7 at the battery). With the air box out, I checked and cleaned the ring connector on the out put wire on the alternator ( it was clean and tight). I then paralleled an additional conductor directly to the battery (through a fuse block). The results are I now have 14.2v at the battery. The original circuit from the alternator to the battery has several connections (as you well know) that adds resistance to the circuit. This turned into a worth while experiment. Anyway, thanks again for your posts and looking forward to your 300k report.
« Reply #14 on: March 16, 2023, 12:09:49 PM »
Hmmm…
That’s interesting to say the very least Biggy.
 Something I probably won’t do, but rather clever I’ll admit. I would have thought 14 and a bit might have been nicer too, but I will keep your sage words in mind and investigate that if needs be.
Interestingly, the on board voltmeter agrees exactly with my good multimeter, so that’s a bonus… :thumb:
Offline Bigtime
« Reply #15 on: March 16, 2023, 05:39:23 PM »
  I probably need to remove my dash and clean the connectors. My on board voltmeter reads about .6v lower than my multimeter at the battery. What do you think?
« Reply #16 on: March 16, 2023, 07:33:58 PM »
I have had the dash off a few times and it REALLY helps if you remove one handlebar riser, because this facilitates the removal of the black panel.
 If you choose not to do this, it requires the panel to be twisted, turned, re oriented, all while standing on one foot…etc.
The plug on the back of the dash has a rotatable cam lock and is not easy to access, but quite doable.
Once you’ve rotated that cam lock the plug comes away pretty easily, it (not surprisingly) will not go back on incorrectly.
I would suggest that you disconnect the battery first, but you probably didn’t need that advice.
Online Pescatore
« Reply #17 on: March 22, 2023, 01:08:51 PM »
Thanks for your patience, Huzo.
I am not used to working on newer bikes, so I don't go for the service manual right away.
After reading your posts it dawned on me that this might be documented.
Lo and behold, with the Norge we have pictures... in color!!!
So, I studied the pictures in the manual and compared to your instructions.
One thing I am not clear on is how the forks are aligned.  Here are some questions:
I see they insert the wheel pin, but how do I know the two stems are exactly the same length from the top?  Does the pin really enforce that?
Next, what sets the length of the two stems from the top?
Do I need to mark with tape before removing, or is there a stop washer at the top?  I don't see it in the parts manual, nor a mention in the service manual.
Now, the tank…
The tank removal is a bit vague in the manual.  I appreciate your instructions for the fuel connector.  Hopefully I will not break it.
I found a replacement from MGCycle, but it is now sold out (MG410 Fuel Line Connection Elbow).
2008 Norge red
1991 V65GT
1980 CM400T
MGNOC Member
Offline coast range rider
« Reply #18 on: March 22, 2023, 01:53:51 PM »
Are you intentionally skipping cleaning throttle bodies?
2017 Stelvio
2002 V11 LeMans
« Reply #19 on: March 22, 2023, 03:21:21 PM »
The forks will not come out through the top of the upper clamp.
They are machined to prevent this, as you slide the forks in you will feel them hit against the limit. Make sure you do one at a time and replace the first one before removing the second, this will prevent you from putting them in the wrong sides.
The one with the ABS sensor goes on the right (twistgrip) side.
« Last Edit: March 22, 2023, 03:29:28 PM by Huzo »
« Reply #20 on: March 22, 2023, 03:25:36 PM »
Because my bike was exhibiting no idling problems and returning excellent fuel economy figures, I left them alone.
I have since done them as one of the jobs I schedule every 100,000 km.
I did not do them at the first 100,000.
« Last Edit: March 22, 2023, 03:27:33 PM by Huzo »
« Reply #21 on: August 09, 2023, 02:28:48 PM »
Just a thing when removing the inner plugs..
Blow around the area thoroughly before removing the plug…(With compressed air that is.. :rolleyes: :wink:).
I once held a strong light down in that area to find a tiny bolt that trickled down between the fins..(of course… :angry: :rolleyes:) and saw quite a few small particles of debris congregating around the base of the plug, made up of at least one small stone about the size of a grain of rice…!
They were hazardously close to being able to fall in upon removal of the plug….Not good at all.
« Last Edit: August 09, 2023, 02:31:01 PM by Huzo »
« Reply #22 on: August 31, 2023, 05:16:20 AM »
Bumped for brider
Offline brider
« Reply #23 on: August 31, 2023, 06:36:04 AM »
Bumped for brider
Thanks, I copied and printed your schedule previously. Great reference!
'85 Cal II Auto
'71 Ambo project
'02 GasGas EC300
'07 Norge
'05 KTM 950 Adventure
Wish'd I'd never sold:
'72 Red Eldo
'74 White Eldo LAPD
'77 Convert with DB bags
'06 Gas Gas EC300
'86 LM IV
« Reply #24 on: August 31, 2023, 01:25:40 PM »
Oh, ok.
« Reply #25 on: December 10, 2023, 03:09:19 PM »
Bumped for nick949
Offline nick949
    • Nick Adams Writing
« Reply #26 on: December 10, 2023, 03:44:55 PM »
« Reply #27 on: January 12, 2026, 03:59:49 PM »
Bumped for Rod Rocket…
The kilometres are now around 230,000, they were 213,000 at the time of first post.
« Last Edit: January 12, 2026, 04:01:49 PM by Huzo »
Online Rocket Rod
« Reply #28 on: January 14, 2026, 02:29:10 PM »
Thanks Huzo. Printed maint schedule, tank and fork removal for my Norge folder.
Can't believe I bought a Guzzi.
2001 California Jackal
2007 Norge
« Reply #29 on: January 14, 2026, 04:32:40 PM »
Ok
