Author Topic: Norge re-born  (Read 3192 times)
Offline Moto TT
Norge re-born
« on: May 03, 2020, 10:17:49 AM »
Hi all, I wanted to share my experience. I bought my 2012 Norge new towards the end of 2013 and was my only bike for a few years. In that time I had the dealer verify it was factory roller tappet, it was one of the first. Soon after bringing it home, I bought a hand-made megaphone can from guzzitech. Over the years added AVS levers, tinted windscreen cut down, and had the seat upgraded from a local shop.
Well early in March I took her in for inspection and didn’t pass because the front tire was worn too much on the left side, so that led to new hoops, went with the new Road5GTs and had the rims painted red. While that was being done I did a fork service and noticed it was difficult to remove the front axle, so I think the forks where misaligned and could have led to the uneven tire wear. With new seals, bushings, fluid and proper fork alignment the bike has never handled this well, even from new.
A week later did the normal maintenance needed for around the 22,000 mile mark. And while digging on this forum I decided to remove swingarm and re-grease the bearings... like others they were a bit dry but in good shape.
Lastly I bought the beetle map and was able yesterday to give it a good test ride for a few hours over many different roads. Wow what a nice difference, smoother in all regards, feels more powerful and very consistent in power delivery. Less gurgles and pops on decelerations. I wish I did this years ago and if you are contemplating it don’t wait, super easy to install and great price.
I want to thank all who posted the how to’s that helped me!
Re: Norge re-born
« Reply #1 on: May 03, 2020, 10:20:40 AM »
 Another beetlemap success story .
« Last Edit: May 03, 2020, 10:25:29 AM by oldbike54 »
Online willowstreetguzziguy
Re: Norge re-born
« Reply #2 on: May 03, 2020, 11:44:30 AM »
Where can I get a beetle map for my 1200 Sport? What’s the cost?
2008 Guzzi 1200 Sport
Offline Spuddy
Re: Norge re-born
« Reply #3 on: May 03, 2020, 11:52:16 AM »
KEWL!
Spud
'13 Stelvio NTX
'07 California Vintage
'01 W650
Re: Norge re-born
« Reply #4 on: May 03, 2020, 12:03:36 PM »
https://www.griso.org/
Look at the header and select the "Stelvio, Norge, Sport, and Bellagio Maps" drop down menu.
« Last Edit: May 03, 2020, 12:04:14 PM by Dave Swanson »
Offline Moto TT
Re: Norge re-born
« Reply #5 on: May 03, 2020, 12:03:53 PM »
http://www.griso.org/
Re: Norge re-born
« Reply #6 on: May 03, 2020, 12:06:40 PM »
Nice success story!  And good on you for sticking with it!  Now you have a real jewel.
Since I planned to keep the stock pipe I thought the factory map would suffice.   Soon I found I was not happy with the rough edge to the way the engine felt so I installed a Beetle map for the stock Norge at my 600 mile service.  Beetle's map completely transformed the rough nature of the engine into an almost turbine like, smooth, tower of power.  The best money spent on the Norge, for sure.
« Last Edit: May 03, 2020, 12:09:23 PM by Dave Swanson »
Offline guzzi ride
Re: Norge re-born
« Reply #7 on: May 03, 2020, 12:09:01 PM »
Your Norge looks great, but we need a pic of the other side.
Re: Norge re-born
« Reply #8 on: May 03, 2020, 02:33:20 PM »
The lightest hint of green in the right place would set that off very very nicely.
Just give me a little more time with the wheels, but I think you’ve done well.
As for the sticking axle..
You’ve to make sure all 4 pinch bolts are completely loose or the axle will be as tight as a fish’s arse.
You can undo the first one and by the time you do the others, the first one is nipped again. Also a smear of Panther Piss is a worthwhile pursuit upon assembly.
Offline Moto TT
Re: Norge re-born
« Reply #9 on: May 03, 2020, 05:00:44 PM »
Thanks! Here are some pics...
Offline Moto TT
Re: Norge re-born
« Reply #10 on: May 03, 2020, 05:06:00 PM »
Thanks and I love the green, might happen... the Tuono I have features just enough green.
I did have all the pinch bolts completely lose and there was zero tension on them. After doing the fork service and making sure the forks we aligned properly the axle went in very easily. Love this bike again and she has now earned her place in the stable, LOL.
Re: Norge re-born
« Reply #11 on: May 03, 2020, 05:43:20 PM »
So things are stable in the stable...Good.
Check this out..
You’d only get away with it on a Wog Hog, but it sorta’ works...?
« Last Edit: May 03, 2020, 05:47:50 PM by Huzo »
Re: Norge re-born
« Reply #12 on: May 03, 2020, 06:22:32 PM »
That's a lovely seat.  Please tell me more about it.
And, if you need to protect it from the rain, let me know.
Offline Moto TT
Re: Norge re-born
« Reply #13 on: May 03, 2020, 07:47:03 PM »
Check this out..
Love it! Thanks for sharing
Offline Moto TT
Re: Norge re-born
« Reply #14 on: May 03, 2020, 07:53:31 PM »
The seat is the base stock seat but had them save the Guzzi logo from the original covering. The foam is built up 1” higher to give me a little more leg room and also has gel inserts. The sides are vinyl with a carbon fiber texture and top is Alcantara for grip. I spray it with 3m fabric protector a few times a year to protect against water and elements. Seat is about two years old since redone by the upholster
Re: Norge re-born
« Reply #15 on: May 03, 2020, 09:52:52 PM »
This happened to my Griso, I replaced both wheel bearings, this is something I do before an extended trip because one bike spat all the balls out of one bearing.
Shortly after one of the new AllBalls bearings must have seized causing it to spin on the axel, by the time I replaced the front tire it had chewed quite a grove in the axel and I had to make a puller to extract the axel.
Re: Norge re-born
« Reply #16 on: May 04, 2020, 09:16:56 AM »
That is one hot norge!
Offline blackbuell
Re: Norge re-born
« Reply #17 on: May 05, 2020, 06:55:00 AM »
Great looking Norge, Moto!
Jon
Offline Moto TT
Re: Norge re-born
« Reply #18 on: May 05, 2020, 08:29:42 AM »
Thanks guys!
Offline bighand
Re: Norge re-born
« Reply #19 on: May 05, 2020, 11:37:59 AM »
That doesn’t look like stock exhaust on your Norge
Offline Moto TT
Re: Norge re-born
« Reply #20 on: May 06, 2020, 02:48:13 AM »
It’s not, soon after buying the bike I found a muffler from GuzziTech and this was hand-made, took a while to get. They don’t sell this style anymore.
