Author Topic: New-To-Me V7 III Milano, No Manual  (Read 5475 times)
Offline GreyGooseGuy
« on: May 05, 2020, 02:33:43 PM »
Hey all,
I just brought her home. They're ordering me a manual. In the mean time, I understand 10w-60 is specified for the crankcase. My dipstick has a cross-hatched area with a solid bar across it. Where is the acceptable level on it? In the cross-hatched area above the bar? In the cross-hatched area below the bar? Anywhere in the cross-hatched area?
And while I have you... what grade of fuel is recommended?
Hmmm... how about recommended tire pressures?
I think that will probably do me until the manual arrives. Thank in advance for your assistance!
2024 Yamaha MT-07
Previous bikes: 1970 Honda CB100; ... '95 Honda 750 Nighthawk; '99 Suzuki SV650; '02 Honda 750 Nighthawk; '12 Suzuki V-Strom 1000; '10 FJR1300; '14 Super Ténéré ES; '16 FJR1300ES; '18 Ducati Monster 797; '16 FJR1300ES; '18 V7 III Milano, '20 Kawasaki Z900.
IBA #56124.
Offline jbell
  • Some progress
Re: New-To-Me V7 III Milano, No Manual
« Reply #1 on: May 05, 2020, 02:37:27 PM »
The dipstick has those crosshatches so you can see the oil.  Usually full is at the top of the crosshatches.  A little low is always better than a little high.
 The rest of your questions, sorry, don't know.
'76 Guzzi T3   Future project
'78 Guzzi G5  Current project
'81 Guzzi G5  Organ donor
'92 BMW K75RT  On the road
Offline Bulldog9
« Reply #2 on: May 05, 2020, 02:37:57 PM »
Hey all,
Welcome! Here you go
Owners Manual: https://cadrecycle.com/wp-content/uploads/2017/09/v7iii-race-stone-special.pdf
Tech/Service Manual: https://cadrecycle.com/wp-content/uploads/2017/10/V7III-tech-manual_EN.pdf
MUCH easier than the paper version.
MGNOC#23231
« Reply #3 on: May 05, 2020, 04:49:06 PM »
2024 Yamaha MT-07
IBA #56124.
« Reply #4 on: May 05, 2020, 05:09:19 PM »
Welcome to WG and congratulations on the Milano!
Offline Siamese
« Reply #5 on: May 05, 2020, 06:15:42 PM »
Yeah, the paper version is small, bordering on microscopic.  Prefer the digital.
On my 2018 V7III Special, the tire pressures are on a sticker on the frame.  Don't remember where, but not hard to find.
« Reply #6 on: May 05, 2020, 07:02:10 PM »
right in the middle of the cross hatch area will be just about perfect
« Reply #7 on: May 05, 2020, 07:04:58 PM »
Thanks everyone for your helpful posts. I ran out and bought a quart of Castrol 10w-60 synthetic "Supercar" oil ...$15.XX. I guess since the bike doesn't have a wet clutch, I no longer have to be concerned about buying oil that accommodates those.
Rode a bit over 100 miles today, getting acquainted with the bike. Rode my "short" and "medium" mountain/canyon loops (the former about 45 minutes; the latter about 1:45). Getting used to the bike, gradually pushing a little harder in the corners. I am SO not used to riding without a windscreen! But I have a Givi A34 coming. First impressions: of course, a totally different experience from the FJR. But I'm adapting. Stock suspension isn't quite as rotten as some would have had me believe. Less harsh than the Ducati Monster 797 I owned briefly, while living in Mexico. I'm not sure which centerstand the Milano came with, but nothing touched down in any of the fairly briskly-ridden left-handers on my twisty route. So nimble. And pulling off onto a gravel shoulder? No hesitation. Something that would have engendered quite a pucker factor on the FJR. In summary: no disappointments. I think this is going to work.
Hepco & Becker top (40L) and side (30L "flash") cases and mounts are enroute. Vista Cruise has been ordered. RAM mount for GPS is enroute. (I trust the bike can spare 6 watts for my Garmin.)
Thanks again for your helpfulness!
2024 Yamaha MT-07
IBA #56124.
Offline V7three
« Reply #8 on: May 05, 2020, 09:04:47 PM »
Ive been fueling my Milano with 89 since I got it last year, at the dealers recommendation. Recently, I was looking into this more, and found that the manual says to use 95 RON. This is using the European model for octane rating, which is different. In the US, this is equivalent to 91 ((R+M)/2).
She ran fine on the 89 (middle choice at our stations) I was using, but I’ll go for the higher octane now that I know. My dealer’s thinking was that we don’t have a lot of high octane cars driving in our area, just lots of Toyotas, Hondas, and light duty pickup trucks. He thinks the higher octanes end up sitting in the station tank for a lot longer and may show lack of freshness. I think maybe he’s just a little superstitious.
Offline bad Chad
« Reply #9 on: May 05, 2020, 10:44:13 PM »
95 Eu equals 90.  Using 89 is close enough for all but perhaps very hot weather.
The potential problem I see running mid grade is it is the least used gas of the three flavors.   I think 80% of cars are buying regular, another 17 ish use premium, and that leaves mid grade as the slow mover at most stations.    Do any vehicles actually call for mid grade?
1988 YX600 Radian
Offline Moparnut72
« Reply #10 on: May 06, 2020, 10:03:38 AM »
Some if not most of the Mopar Hemis require mid-grade but run fine on regular, at least ours do.
kk
Mopar or Nocar
Current Bike:
2026 V7 850 Special
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline TexMexStrada
    • YouTube Channel
« Reply #11 on: May 06, 2020, 08:51:21 PM »
Exciting news, glad to read you are having a good time so far! On the tire pressures, I run the front 1.5psi higher than the rear when cold, so that way they are balanced when hot (37.5/36 when it is just me and little extra weight on the bike). I found the front to get a little squirmy in fast sweepers if the rear has higher pressure than the front due to uneven pressure buildup  (When I started with 36/36 cold), and making that adjustment mostly cured that.
Another thing I recommend you look into is pushing up the front fork tubes a little to improve the suspension/frame geometry and weight distribution. There are some great discussions on that, everybody has a different magic number, so I recommend researching and then exploring it for yourself. I picked 12mm, and like the result so far.
Enjoy the ride, and please post pix once all your farkles are on the Milano!
TexMexStrada
2018 V7III Stone
« Reply #12 on: May 06, 2020, 09:12:44 PM »
I use Premium non ethanol fuel, I figure the bike is so economical why put that corn alcohol in it I have put Ethanol in it on a trip but I always make sure to end the trip with a fill of non Ethanol
The dealer I bought mine from uses Motul 8100 X-power SAE 10W60 which is nice because it shares that with the Griso.
« Last Edit: May 06, 2020, 10:54:42 PM by Kiwi_Roy »
« Reply #13 on: May 06, 2020, 11:09:07 PM »
... Enjoy the ride, and please post pix once all your farkles are on the Milano!
Will do!
2024 Yamaha MT-07
IBA #56124.
Offline Bulldog9
« Reply #14 on: May 07, 2020, 08:25:05 AM »
Dude.............. I completely understand the 'joy' of a V7, but I can't imagine coming from an FJR to a V7. I went from an FJR to a Griso and Norge, and it took me quite a while to adjust to lack of viceral power. I had an 05 FJR (faster/lighter) with Two Brothers Exhaust and PC. The thing was an absolute beast with insane passing power and chassis stability, but unless you were riding balls out ALL the time, it was boring........... Once I learned how to ride a Guzzi, I will say that the performance gap shrunk, and I tour with a buddy still on an FJR that couldn't lose me, but few bikes had that visceral power of the FJR.
Guzzi's however have so much character and liveliness, they are a delight to ride. You just have to get out of that 'It's a Vtwin, DONT spin it up" mentality. Guzzi's thrive in the 4500-6500K rev range, and the sound on and off throttle is sublime. Useable torque across the rev range is also fantastic.
I don't think I could have made the jump from an FJR to a small block, especially with the rev restrictions during break in.  I tip my hat to you.
MGNOC#23231
Offline Blaufeld66
« Reply #15 on: May 07, 2020, 09:05:56 AM »
Here in Italy at the gas stations you see pumps with the "E" letter with a number, that means how much % of Ethanol is inside. No probs with E5 or E10, but upwards it is bad for engine...
« Last Edit: May 07, 2020, 09:06:42 AM by Blaufeld66 »
Sold:
1984 V65C
1985 850-T5
2001 V11 Sport Rosso Mandello Edition
2008 Stelvio 1200 4V
Own:
2003 California EV
Offline et18
« Reply #16 on: May 07, 2020, 09:41:08 AM »
My understanding is most stations only have two underground tanks, one each for reg and super.  Mid grade is blended from these tanks when pumped.
2014 California Touring
1994 BMW R1100RS
2001 BMW R1200C
« Reply #17 on: May 07, 2020, 11:26:37 AM »
Over the past few years ethanol free premium went from fairly scarce to quite common.  I am always able to find it nowadays.  With the help of a phone app I haven't had to use ethanol in my bikes for 2 years now.  All other grades have 10% ethanol so it's a no brainer what goes in the Guzzis
« Last Edit: May 07, 2020, 11:27:46 AM by Dave Swanson »
Offline HarveyMushman
    • Photo Galleries
« Reply #18 on: May 07, 2020, 11:45:33 AM »
Wish I could, but it's not available anywhere convenient to me.
As for the Milano, it's a terrible bike.  Best be rid of it ASAP.
« Last Edit: May 07, 2020, 11:47:47 AM by HarveyMushman »
Tim
Offline et18
« Reply #19 on: May 07, 2020, 12:03:27 PM »
Yes, that's what I've heard.  Just to help you out, I'm prepared to trade one carton of toilet paper, one bottle of hand gel and one pound of hamburger for the bike in the picture.  Again, this is just to help you out.
1994 BMW R1100RS
2001 BMW R1200C
    • Photo Galleries
« Reply #20 on: May 07, 2020, 01:03:58 PM »
That’s very generous. Too generous, really. I couldn’t live with the guilt.
Tim
« Reply #21 on: May 07, 2020, 03:14:03 PM »
1. It was necessary, or would soon have been. I haven't been comfortable on the FJR for a while now.
2. Don't spin it up? I hit the rev limiter on the test ride...  :whip2:
3. My Milano was already broken in. It had 2,966 miles on the clock when I rode it off the lot.
I knew it would take some adaptation. The fact that I've had an irrational interest in Guzzis for decades will make it easier. A very different style of riding -- yet, I think I'll still be able to ride twisty roads briskly, even if the V7 might prefer a more relaxed pace. It's certainly well-planted at freeway speeds, much more so than the Ducati Monster I owned briefly. Now, passing a string of cars on a winding two-lane road ...that will suffer...
2024 Yamaha MT-07
IBA #56124.
Offline Bulldog9
« Reply #22 on: May 07, 2020, 04:17:44 PM »
Ride on Good sir! I didn't realize it was already broken in. The V7 is a Gem....... All you need is a Beetlemap, which I believe bumps the revlimiter by 500 RPM. Not much going on that high, but I find the bump in headroom keeps me from hitting it which I would do REGULARLY before the re-map.  THough the stock mapping on the V7's is good, the overall response and torque curve is greatly improved, particularly the little dip in torque around 3500rpm, at least on the Stornello.
MGNOC#23231
« Reply #23 on: May 07, 2020, 04:23:23 PM »
I've found nothing to complain about regarding the fueling thus far, but I'll keep that in mind. Probably won't do anything while the remainder of the factory warranty is still in effect.
Thanks!
2024 Yamaha MT-07
IBA #56124.
    • Photo Galleries
« Reply #24 on: May 07, 2020, 05:26:57 PM »
I didn't have any issues with the stock fueling either, but the Beetle map is an improvement nonetheless.  It just brings the engine to life a bit, with a fuller sound and a freer feel.
Tim
Offline Kev m
« Reply #25 on: May 07, 2020, 06:31:45 PM »
That's an interesting comment. Which Monster?
In not sure I agree that is true with ours, but maybe I haven't ridden then back to back lately. I have always felt our 696 was surprisingly stable on the highway.
« Reply #26 on: May 07, 2020, 07:34:52 PM »
I had a 797. Found it positively twitchy at freeway speeds or better. Harsher suspension than the V7, too, despite my efforts to adjust the harshness out of it.
2024 Yamaha MT-07
IBA #56124.
Offline Andy1
« Reply #27 on: May 08, 2020, 01:37:03 AM »
Small blocks like to spin not slog!
AndyB
Offline Kev m
« Reply #28 on: May 08, 2020, 06:47:04 AM »
Wonder if my little bro agrees (he's got one).
That definitely does not describe our 696. Stability and suspension is better on it then either of our V7s.
Offline Bulldog9
« Reply #29 on: May 08, 2020, 04:40:01 PM »
In regards to suspension feel and stability, NFN, YMMV, blaa blaa blaa, I initially found the Stornello (v7ii) to be very twitchy overall. Granted that is in comparison to the Griso, Norge, and MGX, and switching between the bikes required attention and adjustment.
Things got much better with the suspension upgrades (Ktech 7.5lb fork springs w/stock oil, and 420mm Hagon Enduro/Trail shocks in the rear). That said, after about 4 months of experimenting with tire pressures, I settled on 30-32 Front, and 34-36 rear. After this, the bike was solid, planted, responsive, but not nervous and twitchy. Made a huge difference in highway and high speed (over 60). I also found that the additional weight of the bags and large windscreen helped to settle the bike.
MGNOC#23231
