Author Topic: Stock fork springs V85tt  (Read 6653 times)
Offline Kitze
« on: May 06, 2020, 04:27:48 PM »
So I’ve search the internet. I’ve searched here. Gone blurry eyed reading the Threadfest. I’ve talked to several dealers. And I’ve emailed my contact at Piaggio USA.
Apparently info on the fork springs is either a deep dark trade secret. Or lost to history.
Does anyone have any info on the specs? Bueller??
V85TT, SV650
Offline Vagrant
Re: Stock fork springs V85tt
« Reply #1 on: May 06, 2020, 04:36:26 PM »
well what do u really need to know. the V85 is as good as it gets without spending $3K xtra. 95% of buyers will be happy.
Offline Kitze
« Reply #2 on: May 06, 2020, 04:55:10 PM »
At a minimum I’d like the rate. Ideally rate, free length, coil count, Symmetry  etc.
For my scrawny ass (145#) the forks are way too stiff.
V85TT, SV650
Offline Trialsman
« Reply #3 on: May 06, 2020, 06:07:09 PM »
I am not much heavier and they were too stiff for me as well.  It was more the compression damping, so I halved the viscosity of the oil.  15wt > 7.5 wt. same volume.   It seems just right now.  You might give it a try.
2010 FE570 Husaberg
2019 Alta Redshift EXR
2021 Moto Guzzi V85TT Centenario
2024 Stelvio V100
2026 Bonnell 805 EX
Offline slopokes
« Reply #4 on: May 06, 2020, 06:49:48 PM »
If you put on fifty pounds the front end will be fine😃
Offline Kitze
« Reply #5 on: May 06, 2020, 06:57:16 PM »
I definitely need to tweak the dampening. But as I’m getting less than 1/2 of the sag I should the springs need to go down in rate.
I’m curious where you got the oil viscosity. Both the service and owners manual call out 7.5 wt. Did I miss an update?
V85TT, SV650
Offline Trialsman
« Reply #6 on: May 06, 2020, 09:12:37 PM »
You are correct.  I was going from memory which was not accurate about the starting wt.  In halving the wt I would have mixed 2.5wt and 5wt to come up with something around 3.75wt.  It took the harshness out of square edged bumps.  Sorry for the mix up.
2010 FE570 Husaberg
2024 Stelvio V100
2026 Bonnell 805 EX
Offline mechanicsavant
« Reply #7 on: May 07, 2020, 07:05:23 AM »
Ya might wanna reduce preload on front springs if possible (shorter spring spacers) to get sag correct , schedule 40 abs works w/washers vs. cutting OEM spacers .
Offline Kitze
« Reply #8 on: May 07, 2020, 10:19:53 AM »
preload is all out. Shorter spacers will move the measurements and can help. But ultimately sag is based on spring rate. I don’t mind changing springs. I actually have a fair number of springs from various race and track bikes. What I don’t have is a spring dynamometer to get a baseline on the OEM springs. On bikes with handed adjustments, such as the V85, its very common to have asymmetric spring rates and often time length.
In normal times springs are 4-5 days out. Now??? Seems like everything is 2-3 weeks. I’m guessing, based on feel, that the installed springs are .95. But I’d like to avoid guessing and having to do multiple swaps.
I guess I’ll have to either build a dynamometer or wing it. I know several companies sell kits. But they all use progressive rate springs, which I hate. And their rates are calculated using weight only. Which ignores several key factors. Geometry, sprung/unsprung weight, stiction etc.
Oh well.
V85TT, SV650
Offline Goose85TT
« Reply #9 on: May 02, 2021, 12:14:31 PM »
Kitze, I too hate progressive fork springs for all the reasons explained on the RaceTech website. I found a review of the V85TT by Ultimate Motorcycling.
In the article he says the V85TT forks are KYB brand sourced from the Aprilia Dorsoduro 900. Have you learned anything new since your last post?
67 Stornello Scrambler
85 850T5
86 V65TT
86 1000 Lemans
2020 V85TT
Offline Goose85TT
« Reply #10 on: June 21, 2021, 07:37:30 AM »
The fork springs in the V85TT are progressive. see the fork internals from my 2020 V85TT
85 850T5
86 V65TT
86 1000 Lemans
2020 V85TT
Offline Goose85TT
« Reply #11 on: June 21, 2021, 07:52:56 AM »
The V85TT fork springs are not only progressive but very stiff. If you weigh more than 200lbs you may not have noticed but if you weigh 150 as I do the forks are torture. With the preload backed all the way out my forks static sag was about 1 inch but when I climbed on there was no additional sag. So I got with AF1 racing in Austin TX and they fixed me up with custom Andreani fork cartridges with linear springs for my weight for $600. Amazing! its a whole different bike. I owned a KTM 1190 Adventure R a few years back and thought suspension could get no better than that but what a difference these cartridges made. The right cartridge was no problem to install, but the left one you need special tools. I took the left one to a local shop, Fast Italian Bikes in Murfreesboro TN and Mike did the work. I attached a picture of the instructions.
85 850T5
86 V65TT
86 1000 Lemans
2020 V85TT
Offline Goose85TT
« Reply #12 on: June 21, 2021, 07:56:59 AM »
Andreani Cartridges pictured
85 850T5
86 V65TT
86 1000 Lemans
2020 V85TT
