Author Topic: Suspension geometry math  (Read 2632 times)
Rough Edge racing
« on: May 12, 2020, 06:03:11 AM »
  I hear all the time how raising or lowering the bike affects steering geometry. For you guys who like math,I do not , lol, how about this example.....A bike with 57 inch wheelbase, 27 degrees fork rake and 4.5 inches trail...Raise the rear one inch, how much rake and trail change?  Suppose instead you drop the front end half an inch?
Re: Suspension geometry math
« Reply #1 on: May 12, 2020, 06:12:38 AM »
If the wheelbase is 57” and you raise the arse by 1”.
You have a triangle whose sin is 1 and cos is 57.
The tangent is therefore sin/cos= tan
And that is 1/57=0.0175
So an angle whose tan= 0.0175
Is 1 degree.
You have altered the rake by 1 degree...
If a line drawn down the angle of the headstem to the ground and the distance from that point to the contact patch is the sin of the angle change.
You’ve to take the sin of 1 degree and multiply it by the distance of the axle to the imaginary point where the line of the forks will touch the road. This will be the radius of the rim plus the depth of the tyre...(near enough)
For an 18” rim that’s ...
9”+3”=12”
So the alteration to trail is about 12x sin 1 degree, which is 12x 0.0174 = 0.21”
So that’s a change in trail of about 1/4”
« Last Edit: May 13, 2020, 06:42:17 AM by Huzo »
« Reply #2 on: May 12, 2020, 07:57:43 AM »
Uh, let's see.  Multiply the first by the second, minus the fourth and divide by, what, again?  Or is it second from first minus third......crap, I don't know.
Oh, HUZO figured it out.  Thank goodness.  Well done, mate.  Good on ya! :boozing:
Having done that mod to a few bikes I always wondered-now I know.
« Last Edit: May 12, 2020, 07:58:38 AM by kingoffleece »
Offline Groover
    • Scooteropolis
« Reply #3 on: May 12, 2020, 08:04:05 AM »
What Huzo said :grin:
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Offline cloudbase
« Reply #4 on: May 12, 2020, 10:10:57 AM »
Gotta break out the old slide rule for that one.
Offline John Croucher
« Reply #5 on: May 12, 2020, 10:54:31 AM »
Better jump in here before Lannis.
Huzo's explanation is good, to a point.  When a rider gets on the bike, weight is added, passenger added, road surface imperfections that change the shock lengths.  In a perfect world of smooth consistency the math works.  In the real world, it is constantly changing in a range.  Some times close is good enough.
Offline kirby1923
  • '81 CX100
« Reply #6 on: May 12, 2020, 10:59:03 AM »
Yes, especially in the case of SAMs.
'81 CX100
« Reply #7 on: May 12, 2020, 11:36:53 AM »
Or horseshoes and hand grenades
Rough Edge racing
« Reply #8 on: May 12, 2020, 12:19:07 PM »
  I bent conduit for years as an electrician. With multiple pipes on a rack the starting point of bending each pipe if making a bend had to be adjusted so the pipes remained the same distance apart from each other .Sin and all that business. Generally we just  memorized about 5 situations and made adjustments based on past experience.
  Pretty much the same when I modify a bike. I jack the bike up or down and using angle levels and marks on the work platform to keep track of trail changes. But it,s handy to see it written down, Thanks..
« Last Edit: May 12, 2020, 12:24:13 PM by Rough Edge racing »
« Reply #9 on: May 12, 2020, 01:50:48 PM »
Or P factor...
Offline malik
« Reply #10 on: May 12, 2020, 02:11:39 PM »
Or P factor...
You don't want to let any of those factors get in the way of a good story.
Offline dguzzi
« Reply #11 on: May 12, 2020, 03:59:43 PM »
   I have a Suspension Engineering Handbook if it would help you. Its old but math and geometry doesn't change much!
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
« Reply #12 on: May 12, 2020, 09:42:20 PM »
Kirby straightened me out on some old knowlege that needed some polish years ago.
Sometimes you don’t know what you don’t know... :embarrassed:
« Reply #13 on: May 12, 2020, 09:52:26 PM »
You could draw a schematic diagram at 10:1 scale and plot the angle with a protractor.
Then raise the back by 0.1” and plot the new angle.
Similar triangle theory says the angle change will be the same, but the change in trail will be 1/10 th of my calc.
A 1/2 or 1/4 scale drawing will yield more accurate results, but don’t look too closely...
You might discover that I’m full of shit.....(but I think not..)  :wink: :thumb:
Offline Harryc
« Reply #14 on: May 13, 2020, 12:47:45 AM »
I did a spreadsheet a while ago to work this stuff out. I can't see a way to attach it to the post, but if you want a copy, message me with your email & I can forward it.
Rough Edge racing
« Reply #15 on: May 13, 2020, 05:32:17 AM »
  Harry ,thanks ,but this was a one shot theoretic question.....For me, using a bike and measuring tools seems to be best....
« Reply #16 on: May 13, 2020, 06:33:45 AM »
http://www.thompsonchoppers.com/rake-and-trail-calculator/
Found this website when I was considering a raked front end on my Mean Streak.
Offline dguzzi
« Reply #17 on: May 13, 2020, 07:58:52 AM »
    The book says, Raising or lowering the chassis at either end by one inch will generally change the angle by almost one degree.
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
