Author Topic: what the best approach for a stripped fill plug on a 5 speed?  (Read 1637 times)
Offline amamet
I have a 5 speed case that has a completely stripped fill plug in the case. timesert? helicoil?  20mm-ish I think?  that has to be a pricey timesert kit id assume
Offline moto-uno
Re: what the best approach for a stripped fill plug on a 5 speed?
« Reply #1 on: May 31, 2020, 11:31:27 AM »
  It's possible this may be a job that a machine shop could do for what you'll have to spend to get a kit
that you may only use once . For instance , in the middle 80's after a decade in the trade I decided I would
get a selection of heli-coil kits that I'd found most useful . Today I have over 95 percent of those kits left  :sad:.
Peter
« Last Edit: May 31, 2020, 01:27:36 PM by moto-uno »
Offline Guzler
  • 1977 850 T3
« Reply #2 on: May 31, 2020, 11:37:24 AM »
Aluminized duct tape, a rubber freeze plug, or wine cork should keep the air in there.
Offline speedyg
« Reply #3 on: May 31, 2020, 11:48:17 AM »
I helicoiled mine, taking care that no swarf  got into the casing and the insert tool retained the helicoil tag that breaks off.
Drained and replaced transmission oil.
Offline Scout63
« Reply #4 on: June 01, 2020, 10:23:05 PM »
If you want, Send me your address and I’ll mail you my helicoil kit Amamet. I bought one and it came with a dozen inserts. I used two or three on my tranny.  Just send it back when you are done. Ben - Orleans, MA
Ben Zehnder - Orleans, MA USA
Offline lucky phil
« Reply #5 on: June 02, 2020, 12:52:29 AM »
Personally I think timeserts are way better but that's a great offer right there.
Ciao
Offline amamet
« Reply #6 on: June 02, 2020, 04:36:26 PM »
like they say in the movies, " thats an offer I can't refuse"
Offline cee2cee
« Reply #7 on: June 03, 2020, 08:21:16 AM »
I used Helicoil on a stripped sump pump drain plug and it worked great.
