Author Topic: EV electric fuel petcock  (Read 1952 times)
Offline Bob Wegman
« on: June 02, 2020, 06:44:18 AM »
My EV petcock has broken wires on the solenoid.  Anybody have one to sell?  Or where do I find a manual one.
MGNOC # 20848
AMA# 548668
Re: EV electric fuel petcock
« Reply #1 on: June 02, 2020, 07:09:18 AM »
PM sent
Offline s1120
Paul B
« Reply #3 on: June 02, 2020, 08:16:56 AM »
I'm going to Hamlin's soon and while I'm there switching out my working electric on Joe's Jackal for a manual.
You can have the electric cheap if you want it.
Online n3303j
  • Ron Cichowski
« Reply #4 on: June 02, 2020, 08:52:51 AM »
Hi Bob,
Broke the wire off my EV electric petcock during a recent disassembly. I had places to go and things to do and didn't want to wait. (Patience is often inverse to age) Used the Dremel tool with a ball type burr to cut away the sealing compound on the fuel solenoid coil. Turns out there was plenty of excess wire available to solder a sound electrical connection to the coil.
I then re-bedded the power wires in a new layer of epoxy. I added a bit of strain relief to reduce the chance of another failure.
Been working like a charm since. You have nothing to loose if you attempt a repair (except for irreplaceable time). You might just win.
I did stumble across a Google post where someone added some commercially available plumbing bits to the stock electric valve to convert it into a manual shut off while retaining the standard hose locations. Of course I can't find the instructions, but they are out there!
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Online JJ
« Reply #5 on: June 02, 2020, 09:13:33 AM »
...or just switch to a MANUAL petcock from MG Cycle, like I did, then, no more worries about solenoid failures... :wink: :thumb:
Offline BillinPA
« Reply #6 on: June 02, 2020, 09:15:46 AM »
Hi Bob, I replaced mine over 10 yrs ago with the mgcycle petcock.  Works like it should, one less worry.
Online n3303j
  • Ron Cichowski
« Reply #7 on: June 02, 2020, 09:39:30 AM »
Found it!
V11 Lemans Site c. 2011
"So I needed a manual fuel tap, but I didn’t even consider going to my deal because they are pretty worthless and never have a clue what they are talking about. Instead I amazingly found this little hydraulic needle valve (dynamic fluid components, p/n DKLN125N*1/8NPT brass needle valve), that once unthreaded from its housing threads perfectly into the v11 fuel tap!!! I did however have to turn a little radius on the tip of the needle to hold the o-ring, I used a machinist lathe, but you could do the same thing with a dremil if you have steady hands. I also used a little tread sealant on the threads just to make sure it would not leak and all my problems are solved, no more vapor lock issues and I now have a manual fuel tap/ petcock."
« Last Edit: June 02, 2020, 09:42:19 AM by n3303j »
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline Bob Wegman
« Reply #8 on: June 02, 2020, 12:14:42 PM »
Thanks so much for all the responses and offers.  I do think I will go the manual route and see how that works out.
MGNOC # 20848
AMA# 548668
« Reply #9 on: June 02, 2020, 12:42:32 PM »
I can't endorse either one.  I've had the manual ones leak and come apart.  Right now, the one on my Sport has been changed out with a plumbing connector.  I found a cork with the approximate size to seal it when the tank comes of again.  I might replace it then with another factory one.   :sad:
