reverse gear for my trike
Topic: reverse gear for my trike (Read 1518 times)
gearman
June 06, 2020, 04:49:21 PM »
As some here know my first attempt using a sprag clutch was a failure.As some here said I should making a retractable motor assy. Well it is now done .The slide assy was a pain. However when testing it backing up the wheel would only climb a piece of 3/4 in. plywood.Anything thicker and the drive roller will slip on the tire.I have done tons of net searches and saw gear tooth looking rollers,knurled ones,even a herringbone profile one.All of these had a much finer pitch than mine,but they were made for lawn mowers or bicycle conversions.,not a big bag mc.I was thinking of re machining my roller and remove 50% of the present crown width,the theory being the roller would imbed deeper into the tire.Ideas thanks
Markcarovilli
Re: reverse gear for my trike
Reply #1 on:
June 06, 2020, 07:40:40 PM »
Slippage - how about roller with rubber around it? That’s all I got...
Mark
rtbickel
Reply #2 on:
June 06, 2020, 07:52:37 PM »
It needs more friction surface.
2020 V85TT
stubbie
Gaggle Mentor
Reply #3 on:
June 06, 2020, 08:26:54 PM »
Would it be from where you are trying to push the tyre from? IE the middle, top, bottom.
