Author Topic: Enduralast alternator kits  (Read 3074 times)
Offline dxhall
« on: June 12, 2020, 09:23:41 PM »
Anyone ever tried one of these?  The price is pretty reasonable, and it sounds like a big improvement over stock.  Here’s the link:
https://www.euromotoelectrics.com/category-s/1844.htm
« Last Edit: June 12, 2020, 09:55:19 PM by dxhall »
Offline Scout63
Re: Enduralast alternator kits
« Reply #1 on: June 12, 2020, 11:56:55 PM »
I installed the 450w brushless kit in my /5 about 5 years ago.  I think the same kit fits the Guzzis as they both use the same Bosch charging systems. Easy install and very well made. Good phone support as well.
Ben Zehnder - Orleans, MA USA
Offline 80CX100
« Reply #2 on: June 13, 2020, 06:44:27 AM »
I put the 450W PM system in my CX100, and I'm glad I have the extra power for heated clothing, but in hindsight after seeing how little power that old points bike actually uses, I'd be totally confident going with the system you're looking at.
One season my sensing signal wire for my R/R had inadvertently been pulled off so my alternator wasn't charging, I ran that bike for a whole summer as a total loss system, just charging it up at home, no problems, but all of my riding was in remote areas not requiring turn signals,lights etc. fwiw.
The 450W PM system is an easy install for someone knowledgeable about wiring & electrickery;  :evil:
EME's instructions were a little vague for a MG newbie like myself at the time I put the system in, so when the instructions warned to ensure that the Red wires from the old system were disconnected and isolated, I took that literally and did a very fine job of completely disconnecting the chassis wiring power supply,,, much head scratching at the time  :violent1:
KiwiRoy solved that one and many others for me.  :bow:
I like the aspect of the system you're looking at, because it's a straight plug and play replacing parts, it should be an easier install. EME has a lot of good quality parts, if you're thinking of any electrical/ignition/maintenance work take a good look around his site, get the system that works for your power needs, take claimed output levels with a grain of salt.
Good luck
Kelly
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
« Reply #3 on: June 13, 2020, 07:38:24 AM »
I installed one on my old '83 850 LeMans III...it worked well and as advertised.  Thumbs up! :thumb: :cool: :smiley:
Offline Two Checks
« Reply #4 on: June 13, 2020, 09:45:23 AM »
As I recall, isn't the BMW rotor sized a few mm differently?
1987 1000 SPII "Il Duce' II"
« Reply #5 on: June 13, 2020, 09:52:06 AM »
I've installed a few on both BMWs and Guzzis. Worn well, a few regulator/rectifier failures though.
Largely unnecessary, IMO, unless you're going to be using a full suit of heated gear (or two). A solid-state voltage regulator, large AGM battery and LED lights are easier and less costly.
Offline dxhall
« Reply #6 on: June 13, 2020, 10:10:53 AM »
Hmm.  What regulator did you use?
« Reply #7 on: June 13, 2020, 12:55:46 PM »
Offline pressureangle
« Reply #8 on: June 13, 2020, 02:42:21 PM »
I put one on my '85 LeMans. The bike was prone to low battery constantly, even when ridden 100miles a day at 50mph+. This system simply cured all ills, including being able to run a 100w high beam headlamp.
Offline bodine99
« Reply #9 on: June 13, 2020, 08:55:18 PM »
Coming up on 10 yrs. on their rotor, brushes, & reg/rectifier on my 76 Airhead good stuff and service.
Offline dxhall
« Reply #10 on: July 10, 2020, 05:10:37 PM »
Sorry to dredge up this old thread.  I bought an RMStator regulator/rectifier.  It has five wires going to the alternator.  The alternator, however, has six spade connectors.  I’m thinking that one of the spade connectors on the alternator must be a ground, and I’m thinking it may be the one labeled “Y” on this diagram:
http://www.thisoldtractor.com/mg_manuals/wiring_i-convert_civilian.pdf
Scroll down to the next to last page to see the alternator, which is #22.
Any thoughts?  The RMStator unit didn’t come with any instructions, and there are none on its website.
« Last Edit: July 10, 2020, 05:12:20 PM by dxhall »
Offline Lesman
« Reply #11 on: July 11, 2020, 08:06:53 PM »
MPH installed one in my GSPD. The BMW rotor and diode Boards not very robust. My opinion. 3 failures in a 3 year period. Very happy. I think my Quota has the exact same set up. Just reliable.
Offline dxhall
« Reply #12 on: July 11, 2020, 08:16:03 PM »
After finding another wiring diagram for an SP, I think that “D-“ should be connected to ground.  Anyone?
