Author Topic: V85 facelift  (Read 123442 times)
Re: V85 facelift
« Reply #150 on: October 20, 2020, 04:18:58 PM »
Trim the fork covers?  They keep the road crap off the stanchions (tubes?  what are they called on USD forks?).  I would be concerned that the seals would see a lot more wear.
If you don't like whatever pyramid plastics has to offer- then just roll your own.  I used a piece of neoprene, cut to a sort-of triangle shape, that is unobtrusive.  Cost less than a (US) dollar.
Yes that little fact had not eluded me..
However, the section that runs on the seals will receive treatment before being exposed to aggravation.
Offline jrt
Re: V85 facelift
« Reply #151 on: October 20, 2020, 09:34:28 PM »
If there is one thing I've learned in this life, it is 'don't aggravate your seals'.   :boxing:
L-720
1973 Eldorado
2003 Yardbird (1100 hydro)
2020 R1250RS
Re: V85 facelift
« Reply #152 on: October 20, 2020, 10:27:41 PM »
Now I’ve started this..
Before..
After..
free image sharing
« Last Edit: October 20, 2020, 10:32:47 PM by Huzo »
Offline lucky phil
Re: V85 facelift
« Reply #153 on: October 21, 2020, 01:36:23 AM »
I needed to arrange some protection for the front of the engine and thought I would have the most success with a low mounted guard.
I don’t suggest it is more attractive, but when done in red, it will begin to blend..
Before..
After..
Walk around..
https://youtu.be/bT5mUS3_EKA
I cant decide.
Ciao
Re: V85 facelift
« Reply #154 on: October 21, 2020, 03:24:20 AM »
I have now LP.
The low one stays, with abbreviated fork guards.
Offline v85kris
Re: V85 facelift
« Reply #155 on: October 21, 2020, 09:44:55 AM »
How about this?
wrx 0 60 2017
Kris D.
2020 v85tt
Re: V85 facelift
« Reply #156 on: October 21, 2020, 12:58:44 PM »
Seen worse.. :thumb:
Offline SIR REAL ED
  • uh.... it's personal....
Re: V85 facelift
« Reply #157 on: October 21, 2020, 06:48:49 PM »
I already have two in my pants... :rolleyes:
I would guess either a serious STD or some form of blunt force, repetitive motion injury akin to carpal tunnel syndrome.
Pictures would help experienced WG personal provide a better diagnoses.   :grin:
2002 MZ Skorpion
1994 DR Skorpion
Re: V85 facelift
« Reply #158 on: October 22, 2020, 11:52:46 PM »
I’ve chopped away a hell of a lot of the bulk featured in the Caponord fender design.
The triangulation remains for structural integrity and the movement area of the staunchions is still protected from front on assault..
Here ‘tis..
https://youtu.be/6cDbkQxgCyA
« Last Edit: October 23, 2020, 12:46:42 AM by Huzo »
Offline jrt
Re: V85 facelift
« Reply #159 on: October 23, 2020, 08:52:52 PM »
That looks really good.  I'm surprised that the fender originally sat so close to the wheel.
L-720
1973 Eldorado
2020 R1250RS
Re: V85 facelift
« Reply #160 on: October 24, 2020, 02:02:13 AM »
I’ve given it 25-30 mm.
You cannot raise it too much or the radii will not match.
Offline lcjohnny
Re: V85 facelift
« Reply #161 on: October 24, 2020, 09:06:43 AM »
Looking better and better
Spada 1000, V50111, Lario and now Griso (and some 23 other bikes over the years)
Offline jrt
Re: V85 facelift
« Reply #162 on: October 24, 2020, 02:49:10 PM »
Hey Huzo, you're a trend-setter!
Mistral now offers 'big bore header pipes'
https://www.mgcycle.com/index.php?main_page=product_info&cPath=26_336&products_id=5675
Cheers,
jrt
L-720
1973 Eldorado
2020 R1250RS
Re: V85 facelift
« Reply #163 on: October 24, 2020, 04:38:54 PM »
Cheers,
jrt
They look ok too..
I made mine with more degrees of bend exiting the head with no crossover, for what I think is a more elegant sweep down past the engine and the line matches the protection bar
but that’s only asthetics, the result is the same.
My O2 sensors are downstream further.
I am booked in for a dyno pull in two weeks and am having the map re done to bring things up to scratch mixture wise.
There is the slightest hint of flat spot right at 2,900-3,100 rpm under certain TGPS settings so that will be good.
I’m running the dB killers in the Zard muffler full time. It sounds more mellow under load and I think nicer overall.
« Last Edit: October 24, 2020, 04:45:31 PM by Huzo »
Re: V85 facelift
« Reply #164 on: November 06, 2020, 03:33:05 AM »
Putting these on my new V85tt when it is ready to pick up, mounting on the crash bars. Will run through a Skene controller to make them drl's as well as spots.
https://www.stedi.com.au/25-cree-led-motorcycle-driving-spot-light.html
Have you got your V85 yet..?
Offline j.davis
Re: V85 facelift
« Reply #165 on: November 06, 2020, 06:51:22 AM »
Yep
Waiting for loom fitting to fit spot lights and flasher to tail light.
Just made an inquiry to bloke in Spain about a seat.
Re: V85 facelift
« Reply #166 on: November 06, 2020, 09:21:18 AM »
Very nice..
Am interested to hear about the lights.
Re: V85 facelift
« Reply #167 on: November 07, 2020, 03:12:18 PM »
If left stock, I reckon they are the prettiest...
Offline j.davis
Re: V85 facelift
« Reply #168 on: November 08, 2020, 05:45:41 AM »
Mounted my Spots today, only wired through  standard relay to work with High Beam though. Will put my Skene controller in when the propper loom fittings arrive.
Work extremely well, 25w Stedi Spot beam.
Offline Knuckle Dragger
Re: V85 facelift
« Reply #169 on: November 08, 2020, 04:58:51 PM »
Just thinking....  would a short - say 150-200mm - LED lightbar fit where the upper 'guard had been removed?  I have one mounted to the handlebars of my Nuda, which makes a world of difference at night:  greater penetration & spread. This would still leave room for a pair of crashbar mounted foglamps wired to the low beam circuit.
Vaguely reminiscent of a Mod's Vespa from the '60s?  Without all the mirrors of course.
Severus bastardis
Re: V85 facelift
« Reply #170 on: November 08, 2020, 07:37:51 PM »
Yes, but I don’t want that look..
Re: V85 facelift
« Reply #171 on: November 10, 2020, 09:42:10 PM »
Is it possible to get a night time shot of them in use and give us a bit of a report ?
I am going to get a couple, but did not know whether the Touratech or Denali was a worthwhile course.
Re: V85 facelift
« Reply #172 on: November 10, 2020, 09:46:11 PM »
Who among us would argue with that logic... :popcorn:
Offline j.davis
Re: V85 facelift
« Reply #173 on: November 11, 2020, 07:54:14 AM »
Got the wiring bits I needed and now have running lights and spots.
Low beam
Low beam
High beam
Re: V85 facelift
« Reply #174 on: November 11, 2020, 12:00:56 PM »
Thank you very much, that looks very good from here. I think I will order some today.
Re: V85 facelift
« Reply #175 on: November 12, 2020, 02:37:27 AM »
Low beam
Low beam
High beam
Are they LED ?
Offline j.davis
Re: V85 facelift
« Reply #176 on: November 12, 2020, 04:38:28 AM »
Are they LED ?
Yes, they look yellow in these pics due to me not being head on to the lens, and running them at 30% as DRL's.
I have the spots angled slightly outwards towards the side of the road where the skippies hide.
Re: V85 facelift
« Reply #177 on: November 15, 2020, 01:46:38 AM »
They do look vaguely similar..
upload images online free
Offline jrt
Re: V85 facelift
« Reply #178 on: November 15, 2020, 08:39:39 PM »
I like that yours are 'cleaner'.  Do I recall correctly that you have the O2 monitor bungs downstream a bit?  They are well hidden.  Personally, I could do without the tangs to fit the skid plates.  I don't do that kind of riding on this bike.
L-720
1973 Eldorado
2020 R1250RS
Re: V85 facelift
« Reply #179 on: November 15, 2020, 08:58:19 PM »
Yes, they are removed in that shot but are visible now since refitting.
Clearly, this is an earlier shot with the standard muffler and high guard, but you can see the sensors.
« Last Edit: November 15, 2020, 08:59:49 PM by Huzo »
