Author Topic: V85 facelift  (Read 123283 times)
Offline lucky phil
Re: V85 facelift
« Reply #210 on: December 30, 2020, 05:01:24 AM »
Do you expect the engine to leak if I change the colour ?
No, but stripping the original paint does risk oil leaks, not a massive risk but it's there. Even repainting after stripping you need to bare in mind that a significant part of the factory painting process is to mitigate porosity issues. I've dealt with these casting porosity issues a lot over the years including the Daytona/Centy engines.
Ciao
Re: V85 facelift
« Reply #211 on: December 30, 2020, 05:40:19 AM »
Ciao
Ok that seems to make sense, but I do intend to repaint the castings in silver like my Norge.
Offline v85lover
Re: V85 facelift
« Reply #212 on: January 03, 2021, 05:52:51 AM »
Those cylinder heads need to go back to bare metal, would break up the black for sure.
Offline Unkept
Re: V85 facelift
« Reply #213 on: January 03, 2021, 12:51:30 PM »
I've liked your changes to your V85 Huzo.
Ever since I saw the new upcoming V7 with a new headlight, I've wondered what it might look like on your bike.
This is really poorly and quickly done but...
Re: V85 facelift
« Reply #214 on: January 03, 2021, 02:07:25 PM »
Looks better than I imagined.
What does the engine and gearbox look like in the same colour as the swingarm ?
Offline v85lover
Re: V85 facelift
« Reply #215 on: January 03, 2021, 08:13:42 PM »
Re: V85 facelift
« Reply #216 on: January 03, 2021, 08:25:45 PM »
I really like what you have done so far, I wouldn't strip the paint off the engine though, the black hides the dirt.
Offline Unkept
Re: V85 facelift
« Reply #217 on: January 04, 2021, 06:12:55 AM »
I'm not really practiced in that kind of editing but...
And a quick no luggage look...
Re: V85 facelift
« Reply #218 on: January 05, 2021, 05:28:53 AM »
Had a look this morning and did this..
With the front wheel IN LINE it became possible to manipulate the packers to align the spots and get them in line with the headlights.
Now they look like this.
I don’t think I’d put my vernier on them, but they will do until a night time run is done.
Yeah...
They work.. :thumb:
Re: V85 facelift
« Reply #219 on: January 20, 2021, 05:32:39 AM »
Not a facelift thing, but an improvement I think..
I’m of the opinion that the twist grip on the V85 is unnecessarily heavy.
Just letting anyone who’s interested know, that I had a new one on the shelf and performed some home surgery on it with a view to making it lighter in it’s action.
I ran a small blade through the joint line and cut the connecting screw/s that hold the halves together. Upon separation of the halves, it became apparent that the spring has about one and a half turns of preload on it,
I reduced the pre load to half a turn and needless to say, the action is now nice and light.
Before you ask, yes the twist grip snaps shut when you release it. Here’s the modified one...
« Last Edit: January 20, 2021, 08:41:02 AM by Huzo »
Online Vagrant
Re: V85 facelift
« Reply #220 on: January 20, 2021, 07:43:14 AM »
Instagram doesn't work for me. Can it be done while still on the bike by a dummy?
Re: V85 facelift
« Reply #221 on: January 20, 2021, 08:43:45 AM »
Would be possibly doable, but I don’t know why you would purposely make it harder.
Re: V85 facelift
« Reply #222 on: January 26, 2021, 11:04:36 PM »
I took the crappy carbon guard off the Zard can.
Also the metallic badge thing. I thought it looked like something from a decomissioned Bulgarian circus cart..
« Last Edit: January 26, 2021, 11:06:08 PM by Huzo »
Re: V85 facelift
« Reply #223 on: February 05, 2021, 04:24:12 PM »
Bump.
Online Bulldog9
Re: V85 facelift
« Reply #224 on: February 05, 2021, 05:28:23 PM »
Any concerns about porosity from a motor or gearbox stripped of paint could easily be addressed with PJ1 case paint. They used to sell it in gloss and satin clear, as well as silver, etc. Stripped and painted several XS1100 engines over the years and used this to good effect.
« Last Edit: February 05, 2021, 05:30:17 PM by Bulldog9 »
MGNOC#23231
Re: V85 facelift
« Reply #225 on: February 05, 2021, 05:30:45 PM »
Any concerns about porosity from a motor or gearbox stripped of it's paint could easily be addressed with PJ1 case paint. They used to sell it in gloss and satin clear, as well as silver, etc. Stripped and painted several XS1100 engines over the years and used this to good effect.
Yes.
That silver that I used is brake caliper paint.
Re: V85 facelift
« Reply #226 on: April 13, 2021, 01:22:19 PM »
Bump for “V85 cruise control fail” thread.
Offline egschade
Re: V85 facelift
« Reply #227 on: April 13, 2021, 02:02:38 PM »
Now that you've put this out I'm starting to agree that the pull Is a bit heavy (thanks a lot  :undecided:). I put some Biltwell Renegade grips on my V85 which have a larger diameter so maybe that will help. The modification looks straightforward enough though a bit fiddly. Did you have to re-calibrate the throttle when you were done?
« Last Edit: April 13, 2021, 02:03:36 PM by egschade »
The elder Eric in NJ
Past Guzzis:
2016 V7 Stornello #394
2018 V7 III Carbon Dark
1985 LeMans 1000
2020 V85TT Adventure
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Re: V85 facelift
« Reply #228 on: April 13, 2021, 02:21:26 PM »
Maybe it was unnecessary, but I did a throttle re learn anyway.
Offline redhawk47
  • Traveler
Re: V85 facelift
« Reply #229 on: April 13, 2021, 08:31:13 PM »
So I missed something.  Why did you cut the screws?  Why not just unscrew them?
Dan
Offline egschade
Re: V85 facelift
« Reply #230 on: April 13, 2021, 09:54:01 PM »
Huzo said that the OEM throttle uses glued/pressed pins, not screws. He cut the pins, drilled them out and replaced with screws when he re-assembled the throttle
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Re: V85 facelift
« Reply #231 on: April 14, 2021, 02:26:06 AM »
That’s almost exactly right.
However, the pins wind in on a thread and have a toothed clip hidden down a hole. Once the pin is cut, half will fall out and the other half can be wound out.
« Last Edit: April 14, 2021, 02:43:08 AM by Huzo »
Re: V85 facelift
« Reply #232 on: April 28, 2021, 03:42:36 PM »
I’m not going to do this, but I thought it wasn’t too bad a styling exercise and nice workmanship.
https://youtu.be/z5yQVyINB_Y
Offline egschade
Re: V85 facelift
« Reply #233 on: April 28, 2021, 08:04:23 PM »
Nice workmanship. Wonder if we'll see this racing cowl / number plate on eBay some day.
Past Guzzis:
1985 LeMans 1000
V65 SP
V7 III Stone
V50
Breva 1100
EV Touring
Re: V85 facelift
« Reply #234 on: April 28, 2021, 08:44:28 PM »
Mmmmm...
Re: V85 facelift
« Reply #235 on: November 12, 2021, 11:48:47 PM »
I’m thinking along these lines.
Re: V85 facelift
« Reply #236 on: November 13, 2021, 01:00:14 AM »
The Zard that’s currently fitted and the stock can will be up for grabs.
Offline redhawk47
  • Traveler
Re: V85 facelift
« Reply #237 on: November 13, 2021, 08:59:46 AM »
I like it.  Classic sport/sport touring bike.  Low front fender, no skid plate, no beak, single wall pipes, low muffler.
What else did I miss?   :thumb:
Dan
Re: V85 facelift
« Reply #238 on: November 13, 2021, 12:27:45 PM »
There’s a fair bit more, but it’s covered throughout the thread.
« Last Edit: November 13, 2021, 12:45:20 PM by Huzo »
Offline Brand X
Re: V85 facelift
« Reply #239 on: November 14, 2021, 08:32:02 AM »
There is some other paint that is a perfect match for your Stornello trim.. Auto body guys are well aware of this brand,, Some of the very best plastic paint in a can also..
I always thought the Wire wheels on the Norge knocked it out of the park
https://www.amazon.com/gp/product/B000EM019O/ref=ppx_yo_dt_b_asin_title_o04_s00?ie=UTF8&psc=1
« Last Edit: November 14, 2021, 08:34:04 AM by Brand X »
