Author Topic: No start  (Read 1504 times)
Offline bacongrease
No start
« on: June 28, 2020, 09:17:47 AM »
 My just acquired 2004 Stone won't start. After sitting 5 yrs. or so. I Clean the tank, New fuel, pump, filter.  I disconnected  the fuel line and there is good pressure.  Removing the plugs and squirting gas in the cylinders  and it fires. Injectors were cleaned by the BMW guy and fuel line checked.  I am new to EFI cycles and do not know what to look for now.
I do have the air box off.  Any ideas?
Thanks.
« Last Edit: June 28, 2020, 10:51:26 AM by bacongrease »
Re: No start
« Reply #1 on: June 28, 2020, 10:27:31 AM »
Well, it also needs compression. Like to know, being an 04 and Hydro. Does it have a fix kit. Well covered for a search. Hydro valve motors cam kit.
May be why bike sat.
« Last Edit: June 28, 2020, 10:38:29 AM by guzzisteve »
Re: No start
« Reply #2 on: June 28, 2020, 11:10:08 AM »
Why was it not run for 5 years and did it run when parked?
What is the age and condition of the battery?
2, perhaps a bad relay not telling injectors to squirt?
And yeah, was the hydro recall done?
Offline Vagrant
Re: No start
« Reply #3 on: June 28, 2020, 12:25:14 PM »
I'd start by replacing the relays then clean the cam position sensor. Be careful it has shims under it. there is a screen in the fuel tap also.
« Last Edit: June 28, 2020, 12:25:50 PM by Vagrant »
Online Tkelly
Re: No start
« Reply #4 on: June 28, 2020, 01:23:22 PM »
I had a couple of crank sensors fail.The bike turns over but won’t fire.
Re: No start
« Reply #5 on: June 28, 2020, 04:55:37 PM »
Thats why I always try to get guys to monitor the pump contacts with a small lamp, I have known several owners remove the sender and put extra gaskets under this upsets the gap from sensor to tone wheel
Online Tkelly
Re: No start
« Reply #6 on: June 29, 2020, 07:47:06 AM »
what I was trying to say is that I had sensors fail on 2 bikes and new sensors got me on the road.
Re: No start
« Reply #7 on: June 29, 2020, 08:18:38 AM »
I'm saying the same thing but how do you know the sensor has failed?
When the engine is spinning over the ECU sees the pulses from the sensor and tells the load relay to power up coils and injectors, so if you know the relay is closed you know the sensor is ok or at least working for the moment
It's pretty hard to troubleshoot the sensor directly on the road, adding lights to each of the relays is a simple no brainer.
Ignore the meter the 3 lights are Start Relay, Injection relay, headlight relay. Really the only important one is Injection relay, its the only information you don't have otherwise.
« Last Edit: June 29, 2020, 08:38:34 AM by Kiwi_Roy »
