Author Topic: Small block crank seal. Oil or not?  (Read 1155 times)
Offline SmithSwede
  • I don't want a pickle
« on: July 04, 2020, 10:52:15 PM »
I’m replacing the transmission side engine crankcase seal.   I’m aware that there are some new-fangled PTFE seals that you are NOT supposed to oil.  But I’m assuming my new Guzzi seal is a conventional design, not PTFE, and I should go ahead and smear a light coat of of engine oil in the inner lips of the new seal when installing it.
I have no instructions or warnings that say not to oil it.  What do I do?
This is a 2013 V7 Stone small block.   I got the seal or what the manual calls the “gasket ring” from AF1 in Austin, part number 886365.   That part number replaced GU 04000500.
The seal itself has a felt outer cover on the transmission side.  The other side is labeled, reading clockwise:
Ratazione Sinistra
BDFVISLVLKX7
53-72-10
I1
IT CFW
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Online Tom H
Re: Small block crank seal. Oil or not?
« Reply #1 on: July 05, 2020, 11:50:10 AM »
Maybe try giving AF1 a call and see what they say about it.
Good luck,
Offline jpv7
« Reply #2 on: July 05, 2020, 01:01:10 PM »
Ratazione Sinistra
BDFVISLVLKX7
53-72-10
I1
IT CFW
no idea but "rotatzione sinistra" means left hand rotation.
Online RinkRat II
  • Lake Powell AZ
« Reply #3 on: July 05, 2020, 01:08:03 PM »
  A very light amount of oil on the lips will prevent the seal from tearing on start up and will go away in short order. Think Q-tip as a swab, a dab on the shaft and on the seal.
      Paul B :boozing:
