I have no super hero capabilities, but it took me 2 rides to conquer the brake pedal stub. Loved it ever since. It gives you a supportive pivot point for your foot to make precise braking action. Maybe I do have super hero traits. Bill
How tall are you? How much do you weigh? Relevant questions for the EV.
I bought my 01 EV new. It wasn't long before I knew that with my size 14 boots I had issues with the stock brake pedal. It was a couple years old when I fabricated my own pedal with my torch, grinder and licoln buzz box welder. That was over 100,000 miles ago and I never looked back. Soon after I posted pics of my design the "Avance Pedal" went on the market and was a direct copy of mine. The advance pedal is no longer available and if I am correct the manufacturer passed away. Here are some pics of my fabricated pedal.
The handgrips will wear out and need to be replace at 110K.
couple more questions.What is this light and is it important? I was digging around my bike and noticed that this little light had what appears to be a wire pulled out.
When the vapor recovery system disappears you need to provide an alternate breather for the fuel tank. The factory line has a tip over device that will close the line if the bike is laying on its side. You can put that device (mechanical) anywhere in the line where it will be vertical when the bike is vertical.
Try shifting at 60 mph into 4th. 75 & above for 5th.
that's very interesting. I actually thought I was shifting closer to 60 but decided that was crazy and I couldn't have possibly been shifting into 4th at that speed! So that's pretty standard? Wild!
