Author Topic: 1000 SP into a storage unit...  (Read 3722 times)
Offline whyrichard
« on: July 20, 2020, 05:46:57 PM »
Hello,
I think I may need to put my 1000 sp into a storage unit... it is air conditioned and dry as a bone.
Question... how should I prep the bike? My plan is to drain the gas tank, (should I empty the floats?), keep the engine oil in, take the battery out and bring it home and put it on a battery tender, and put a shop rag under the rear brake (as it seems to have a slow leak at the master cylinder)...
Anything else I am missing?
Question, should I drain the tank? Given it is metal, will it rust? Should I have the gas tank open so to fully dry out? (I think the storage unit requires no gas to be in the bike...)
thanks,
Richard
Re: 1000 SP into a storage unit...
« Reply #1 on: July 20, 2020, 09:00:58 PM »
 Bump
Pizza Guzzi
« Reply #2 on: July 20, 2020, 09:04:22 PM »
I can't help with advice but something relevant to your question is how long will the bike be laid up in storage.
Online cliffrod
« Reply #3 on: July 20, 2020, 09:57:05 PM »
How long is the storage?
My no a/c stored bikes have 100% empty (not 99.9% is close enough) empty and dried gas tanks.  I make sure by using something to mop or absorb residual liquid after the tank is drained by petcocks.  Fogging the empty tank helps limit rust.  Carb/carbs were either run completely dry including restarts & throttle action or bowl drains opened to drain them.  Battery removed.  lots more can be done, but these are the basic necessities.
Even for short storage, I will run carbs completely dry or drain them.  With non-ethanol gas, it's not as big a deal.  My V7 Sport will stall but restart at least 1-2 before both carbs are really out of gas.  Your bike will probably do the same..  Get it all out.  It makes it simple to add gas & battery and go without yet another easily avoided carb strip/clean/r&r.
Offline Scout63
« Reply #4 on: July 21, 2020, 05:19:02 AM »
For longer storage I empty the fuel tank, plug the petcock holes and coat the inside with a cup of 30w oil.  On recommissioning rinse with fresh fuel. I always store with fresh oil in the crank case. A heavy coat of wax on shiny parts and blocking the exhaust ends never hurts.
Ben Zehnder - Orleans, MA USA
« Reply #5 on: July 21, 2020, 05:52:18 AM »
Wheels off the floor, too.
Offline geoff in almonte
« Reply #6 on: July 21, 2020, 06:06:22 AM »
If you are still using the OEM airbox, stuff a rag in the snorkel to keep critters out.
Midnight bugs taste best
Offline whyrichard
« Reply #7 on: July 21, 2020, 09:28:14 AM »
thanks all for the tips.
i am waking up my friends griso, which has been in storage for 5 years. I may sell it, but if i fall in love with the griso I'll put my sp in storage for a few years (4?) and wake it up to do a nice restore...  if i sell the griso i'll take it out of storage in a year and use the sp as a weekender....
thanks,
r
Offline Perazzimx14
« Reply #8 on: July 21, 2020, 02:02:34 PM »
How was the Griso put up? After the fuel is removed there really is no difference.
