Author Topic: Small, mid ,large valve engine  (Read 3346 times)
Rough Edge racing
« on: July 21, 2020, 06:07:18 AM »
 I hear talk of big and small valve engines used in Tonti frames. Also seems to be a mid sized valve heads. Some also have larger carburetors ?
   What year and what models use the various heads. heads?  Thanks
Offline PeteS
Re: Small, mid ,large valve engine
« Reply #1 on: July 21, 2020, 06:28:30 AM »
I can only offer a few. The LMI, II, and III have medium valves. The LMV has large valves as does the first year 1000S. Mixed reviews on the large valve. Some say you give up low end for top end. T, T3 have small valves.
« Last Edit: July 21, 2020, 06:29:11 AM by PeteS »
jwinwi
« Reply #2 on: July 21, 2020, 08:33:43 AM »
Beg, borrow, steal or in the worst case scenario buy a copy of  Guzziology.
This kind of info is why I say that Guzziology is both cheap and priceless.
« Last Edit: July 21, 2020, 08:37:54 AM by jwinwi »
Rough Edge racing
« Reply #3 on: July 21, 2020, 08:58:48 AM »
Duh, I had a copy and included it with the sale of my Guzzi to a friend...I will take a look at it...
« Reply #4 on: July 21, 2020, 11:58:23 AM »
1993 and up Cali had all mid-size
V11 Sports, 1100 Sports are bigger yet
Offline Turin
« Reply #5 on: July 21, 2020, 08:16:39 PM »
Actually, the Valves on 1100 and V11 sports are ever so slightly smaller than the big valve heads.
1985 Sidlow Guzzi
Offline Murray
« Reply #6 on: July 22, 2020, 05:11:59 AM »
WHS they reduced the valve size -5mm from memory as they were concerned the lift of the 1100 sport cams would cause them to interfere.
Rough Edge racing
« Reply #7 on: July 22, 2020, 06:37:28 AM »
 While on this topic, do the square fin heads fit on round cylinders? Or square fin cylinders fit on a block originally fitted with round fins?
Offline PeteS
« Reply #8 on: July 22, 2020, 07:51:00 AM »
The moved the studs out on the square fins to allow for the larger bore.
Rough Edge racing
« Reply #9 on: July 22, 2020, 08:05:43 AM »
Ok,so if a person  is looking to do performance modifications, a square fin is the best option....
« Reply #10 on: July 22, 2020, 08:17:47 AM »
Yes, can't remember crap anymore, and don't care to look nothing up, the new normal.
Offline PeteS
« Reply #11 on: July 22, 2020, 08:22:26 AM »
Depends how big you want to go. I have a 992 kit for my 850. The block has to be bored out to accept the bigger spigots. If you want bigger without resorting to stroking the crank you want a square fin.
jwinwi
« Reply #12 on: July 22, 2020, 09:52:22 AM »
Yup. LM1000 or the rare as Rocking Horse Sh#* 1990 (?) Cal 3 with big valves and 40 mm Dellortos.
« Reply #13 on: July 22, 2020, 10:13:29 AM »
Or turn the spigots. Also if you can find it, there was a kit turned and ready to install.
Rough Edge racing
« Reply #14 on: July 22, 2020, 11:04:29 AM »
 I'm more interested in the heads than bigger engine cc's. The square fin has the option of bigger valves without using rare Lemans heads with their large combustion chambers or expensive head mods done by moody specialists.
  The raised intake ports on my 650 Triumph racer and the squish modification on the 79 750 Triumph says there's lots of improvement in throttle response, overall power and higher compression on available pump gas with old design hemi heads...
Offline PeteS
« Reply #15 on: July 22, 2020, 11:06:41 AM »
6 of one 1/2 dozen of the other. Just as easy to open the block and turn the spigots if you have the equipment. I did it myself on my mill.
There is a point where you just get an 1100 sport rather than spend the dollars tuning a smaller motor.
Offline Turin
« Reply #16 on: July 22, 2020, 11:49:15 PM »
Any major gains are going to require one of the more serious camshafts, which requires re-working the heads. This is something I would farm out.
1985 Sidlow Guzzi
