Author Topic: Moto Guzzi Nevada Gearbox/engine swap?  (Read 5073 times)
Offline Pexy13
« on: July 25, 2020, 08:19:04 AM »
Greetings!
I have a custom built scrambler from a 2002 Nevada.
Is it possible to replace the stock 5 speed gearbox with a 6 speed one out of a V7iii?
If it is is it a straight forward swap or will it require lots of fiddling around to make it work.
Also is it possible to swap the entire engine and gearbox from a V7 to a nevada 750?
If you need any more information about the bike let me know.
Also if something like this is possible but not swaping parts from a V7 also please share.
Thanks,
Sven
Offline chuck peterson
Re: Moto Guzzi Nevada Gearbox/engine swap?
« Reply #1 on: July 25, 2020, 01:18:45 PM »
Welcome! I’m a nevada owner, but as far as i can tell there are maybe 4-5 here. I’m using it as a step down bike. Not too much modifications going on.
You might find more info on the smallblock/v7 forum. Don’t know the link, sorry. Someone will be along.
We want fotos!
 :bike-037:
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline malik
« Reply #2 on: July 25, 2020, 04:58:41 PM »
The injected Nevada has the same engine, gearbox and running gear as the 750 Breva and the 2TB V7's, parts are interchangeable. There were some carbureted Nevadas. The fuel handling and breather plumbing on those seem to be same as the V65. The earlier 1TB V7's are also basically the same. I haven't yet come across anyone who has tried to retro-fit the six speed gearbox. Try it, and let us know. The 1TB Stone engine has been fitted to a V65 in the past. As well as the six speed box, the V7 II's engine is slightly titled. Don't know how much difference that makes to the engine mounts. Still leaves you with lots of alternative sources.
Online sign216
« Reply #3 on: July 26, 2020, 04:54:39 AM »
I agree w Malik.  My 2 cents is that the 6 speed won't fit, and ... the engine has such a good torque range that six speeds aren't needed.
I think the factory added a sixth speed just for marketing.
09 Guzzi V7C
58 BMW R50
65 Gilera 106
69 Benelli 350
« Reply #4 on: July 26, 2020, 05:50:52 AM »
Small block interchangeability is really good. I'm running a V7 transmission behind the Aero engine in the Lario. That said, *I don't know,* but doubt the 6 speed will fit without major modification.
Offline Pexy13
« Reply #5 on: July 27, 2020, 06:03:25 AM »
We want fotos!
 :bike-037:
Thanks for the info I will check there as well.
Here are the photos!
Offline Pexy13
« Reply #6 on: July 27, 2020, 06:08:26 AM »
Alright. Thanks for the info.
Offline malik
« Reply #7 on: July 27, 2020, 02:04:19 PM »
Nice job. It looks like another carbureted Nevada. If you get a later engine, there's some sensor holes which will need blanking. Noted in the V65 with Stone engine thread of a few years back. I've an idea that the front mudguard could be raised a tad using spacers & longer bolts. Perhaps. Access is awkward there, but that's nothing new with the smallblocks.
