Author Topic: Convert Cut Out  (Read 2039 times)
Offline giusto
  • Giusto il canne del Como
    • photobucket
Convert Cut Out
« on: August 02, 2020, 07:09:15 AM »
Hi
I have a question. My 76 Convert has run and started flawlessly since I put in a Dyna lll Electronic Ignition three years ago. Quick perfect starts every time.
Coming into my drive from a nice ride last week and it cuts out.
No spark at the plugs. I checked the “run switch” as it seems loose...pull it off the bike and clean it up/ retention it.
The bike cranks fine, no spark... is there anyway to check the dyna lll through the Black/white/red wires?
Any ideas on what to isolate ?
Frank
2020 V 85 TT Travel
76 V1000 Convert Mr. Slate
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
Offline chuck peterson
Re: Convert Cut Out
« Reply #1 on: August 02, 2020, 07:20:00 AM »
Three years, uh? I’ve heard of more problems w Dyna electronic ignitions then w original points.
Probably 5-1
Dyna website has a flow chart for diagnostics and has really good customer services so I’ve heard over the years here
I think it’s common to carry a set up points plate as back up for the dyna if your visiting the world
Good luck, sorry you’re down
150k on Verts
750 Nevada
400f
R5 Yammie
BV250
Offline MotoG5
Re: Convert Cut Out
« Reply #2 on: August 02, 2020, 08:44:16 AM »
I have seen this twice over the years with the Dyna lll. Once on one of my bikes and once on a good friends bike. In both cases it was the Dyna unit that had failed. One was fairly new and the other was several years old. Its not a common thing but it does happen. In both of these cases the unit was replaced with out further trouble.
Nebraska MGNOC State Rep
Re: Convert Cut Out
« Reply #3 on: August 02, 2020, 01:11:25 PM »
nice to see you have it trained to break down at home.  :thumb:
Offline BMCMOTO
Re: Convert Cut Out
« Reply #4 on: August 02, 2020, 02:29:02 PM »
I had a Dyna for a while, carried points plate in my saddle bag everywhere I went. Now I just carry it around in my distributor. Easy peasy.
Brian
1989 MILLE GT
2006 BREVA 750
2004 BREVA 750
1975 CONVERT
Offline ray bear
Re: Convert Cut Out
« Reply #5 on: August 02, 2020, 05:22:58 PM »
I had the identical fault with my convert only yesterday but by turning the handlebars to the right my bike would run , turned out it was the multi pin plug was loose where it went into the back of the  headlight shell, just a thought.
« Last Edit: August 02, 2020, 05:24:27 PM by raybear »
73 V7 sport
73 Eldo police special
68 BSA rocket 3
74 Norton Commando
78 Honda CBX 1000
47 HRD vincent Rapide
XT 500 Yamaha
Offline giusto
    • photobucket
Re: Convert Cut Out
« Reply #6 on: August 02, 2020, 06:32:13 PM »
Hey Ray bear,
When I removed the on/0ff switch We got in the multi plug to remove the switch pins... thought it might be the switch or pinched shorted wires...but no...put the multi back securely.  btw I could use another headlight shell for another Convert I'm putting back together...have one?
I'll be contacting dyna for trouble shooting.
cheers
2020 V 85 TT Travel
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
Offline giusto
    • photobucket
Re: Convert Cut Out
« Reply #7 on: August 02, 2020, 06:37:12 PM »
Hey John, hope you are well...ok you made me laugh....well done.
seems like I have a photo of you on a racing tricycle from our rally 5 or 6 years ago...also funny :)
cheers
2020 V 85 TT Travel
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
Offline TOMB
Re: Convert Cut Out
« Reply #8 on: August 02, 2020, 08:54:19 PM »
Does your Convert still have the side stand switch ?
If yes disconnect it and see if your problem disappears.
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Offline giusto
    • photobucket
Re: Convert Cut Out
« Reply #9 on: August 02, 2020, 09:05:43 PM »
TOMB
Side stand switch long gone
2020 V 85 TT Travel
2008 Norge Mia
2007 Breva
66 Benelli 125
68 Gilera 106
Re: Convert Cut Out
« Reply #10 on: August 03, 2020, 01:07:49 AM »
When was the last time you took it to an Italian restaaurant?   :grin:
