Author Topic: Electronic Speedo driver solved  (Read 1476 times)
Offline Irishflyer
« on: August 04, 2020, 05:04:20 PM »
Previous owner of my 96 Cal III had purchased some very nice Speedhut Gauges, but was having a hard time with the drive adapter to send the pulses.  I found an adapter on Amazon,  the DAYTONA Motorcycle Speedometer Conversion Adapter.  It threads right onto the speedo output on the transmission, and has three wires.  The instructions are in Japanese.  I looked up symbols for colors.  12v is Red, Output to speedometer is Yellow, and Black is ground.  $61 on Amazon.
anonymous image hosting
https://www.amazon.com/gp/product/B01A7VLTFQ/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
Hopefully this helps anyone looking for a cut and dried solution.  It does have a pass through to drive a cable driven speedo as well, I am actually using it differently than what they intended, I turned it around and screwed it right to the output threads.  I will find a cap that is 18mm to seal it.
Re: Electronic Speedo driver solved
« Reply #1 on: August 04, 2020, 05:14:20 PM »
Looks pretty fancy, I used a small magnet spinning in the square hole and a reed switch for mine, no bearings required as it spins in the original drive.
« Last Edit: August 06, 2020, 12:14:40 PM by Kiwi_Roy »
Offline dguzzi
« Reply #2 on: August 05, 2020, 03:52:46 PM »
Do you know pulses per revolution? Or some way to match up accurately?
'03 EVT
'87 Cagiva
'72 Commando
'71 Commando
'13 F150
'16 Mustang
Online Chuck in Indiana
« Reply #3 on: August 05, 2020, 06:06:36 PM »
Thanks for that.  :thumb: I've saved KR's sketch in my "Roy's Guzzi stuff" file in case I had to make one, but I'd rather just bolt something on and be done with it in my waning years.  :smiley:
Offline Irishflyer
« Reply #4 on: August 05, 2020, 11:17:43 PM »
Speedhut has a calibrate mode, as long as you have pulses, it can calibrate basically.  Drive to 25mph, hit save, and it extrapolates from there.  I'm not sure of Daytona's pulses per mile.
Offline AZRider
« Reply #5 on: August 05, 2020, 11:53:13 PM »
My VDO speedometer has you drive exactly one mile while in programming mode, speed doesn’t matter. It counts the clicks in a mile and does all the math from there. I looked on my state Highway Department website and found a map showing all the posted Measured Miles, went to the nearest one and drove from post to post.
Trying out the motorcycle life from the other side of the counter.
Offline Old Jock
« Reply #6 on: August 06, 2020, 03:46:14 AM »
I had a spare sensor from MotoGadget lying around so incorporated it onto the rear brake mount where it reads off the disc bolts.
I chose the Speedhut over Marshall, I preferred the looks of the Marshall, but they were thicker and their pulse range more limited so I opted for Speedhut.
Speedhut is great, but I did find all the button press m'larky to calibrate it a bit of a PIA. Trying to sets the modes, get it to the correct speed then hitting the cal while trying to keep a constant speed via a GPS mounted on the tank was tricky and I had eventually to take my gloves off to do it. As I recall the problem was the speedo reverted out of cal mode after a given number of seconds, which was irritating.
All that said it didn't take long to do once I worked it out and it works.
« Last Edit: August 06, 2020, 03:47:28 AM by Old Jock »
Offline Zoom Zoom
« Reply #7 on: August 06, 2020, 07:40:44 AM »
I noticed Amazon lists it as currently unavailable although I'm sure they'll get more.
If I remember, there was also a GM hall sensor that worked. I don't recall the application or cost though. Perhaps someone remembers.
I was thinking about posts like this providing helpful info. Some of this stuff ought to be added to the tips and tricks page.
John Henry
« Reply #8 on: August 06, 2020, 10:29:19 AM »
The GM sensor is about $25 or so. The problem is that it does not have the correct size end to fit the trans.
