Author Topic: Everyday T3?  (Read 5904 times)
Offline Stu
Everyday T3?
« on: August 05, 2020, 05:10:21 AM »
Bit of background; I bought myself a 76 T3 back in April and have been fiddling with it since (Mamma Mia project thread). Hopefully it'll be back on the road this weekend at least to get a feel for what else needs doing. I currently have three bikes. As well as the T3, I have a 91 Kawasaki 750 Zephyr, which is cute but not really my cup of tea, and a BMW GS1200 (07) which is useful, but huge and not terribly inspiring. They are both for sale, which leaves me with the Guzzi. I don't need more than one bike, I quite like the idea of having something old and quirky and if it's off the road being fixed it's not the end of the world; I only ride for fun.
My question is: Is it realistic to have a 44 year old Guzzi as an only bike? What would I have to do to it to ensure its ongoing reliability? I've been through top end (it has cast liners), brakes, suspension, tyres, fuel system. I haven't looked at the electrical system yet, which I guess may be the main issue... everything seems to be working so far, but I'm not sure I trust it! Everything is original including handlebar switches and contact breaker ignition. I have replaced the ignition switch.
Any thoughts and experiences? Should I go for it and invest time and effort into this one bike, or do I hedge my bets? Is it still capable, with some work, of knocking up some miles (only maybe 4-5000 per year) or should I keep it as a toy and maybe keep the BM or similar? If I go for it what mods are essential/desirable to keep it going or make it useable in modern traffic? Your input and experiences would be appreciated!
Re: Everyday T3?
« Reply #1 on: August 05, 2020, 05:38:16 AM »
Electrically the ignition should be reliable, whatever you do DONT change the capacitor, the ones on the market today are just rubbish as are some of the points sets available.
You could boost the headlight by adding relays to take the load off the bar switches, Other than that just clean connections and add some Vaseline to ward off corrosion.
I assume its got the type of fuses that sit between two spring loaded clips, I suggest stretching an "O" ring around the clips to add tension after first polishing the ends by rubbing on your Jeans.
Online Chuck in Indiana
Re: Everyday T3?
« Reply #2 on: August 05, 2020, 05:41:26 AM »
After the Apocalypse, the only thing left moving will be cockroaches and old Guzzis.  :smiley: Of course it can be an only bike. Go through the electrical system completely. Take every connection apart. Clean, spray with Caig DeOxit, use Vaseline *not* dielectric grease as necessary, and it will run forever.
I see Kiwi Roy posted at the same time.  :grin: Great minds and all that..
Offline Frenchfrog
Re: Everyday T3?
« Reply #3 on: August 05, 2020, 05:45:38 AM »
I used mine in that way from 92  to 06..had the occasional hick up but it behaved overall very very reliably after routine maintenance. I then striped it down after a full nut and bolt restoration that was mainly cosmetic and for tuning purposes.
Offline Stu
Re: Everyday T3?
« Reply #4 on: August 05, 2020, 05:47:40 AM »
Thanks Guys
One of the things I had on my list to do soon as I noticed the points were sparking a bit...  :undecided: Anywhere reliable to buy new contacts and condensers from?
Offline SpadapatinaII
Re: Everyday T3?
« Reply #5 on: August 05, 2020, 06:23:39 AM »
Guzzis are one of the few 40+ year old bikes that can still be a realistic everyday bike
Re: Everyday T3?
« Reply #6 on: August 05, 2020, 06:36:47 AM »
Thanks Guys
The condenser is not there to prevent sparking it acts as part of a tuned circuit along with the coil
I think you would have better luck with a condenser from some old abandoned car from the 60s rather than buying a new Chinese knockoff
I thought I would treat my old loop to a new one, big mistake, it ran fine for a day, then I barely made it home cutting out with any throttle.
The ends weren't even connected to the foil. I could see where it was arcing inside.
Perhaps go to an auto wrecker.
« Last Edit: August 05, 2020, 06:58:26 AM by Kiwi_Roy »
Re: Everyday T3?
« Reply #7 on: August 05, 2020, 06:52:18 AM »
In my 31 years of owning an old Guzzi, my experience tells me it's better to run the old bikes more often is better that not. My cx100 was my only street bike until I bought a Triumph in 2006, you'll be OK with the old Goose.
« Last Edit: August 05, 2020, 07:39:57 AM by Guzzistajohn »
Online kfz
Re: Everyday T3?
« Reply #8 on: August 05, 2020, 07:21:33 AM »
Not really applicable to you but...
Situation in the States is different from here in the old world. But if you already have an old Tonti, especially something sought after life a LM, T3,T4, then it quite happy to be used a everyday bike.  Its a different situation to buy one.  Prices are so high that you really got to ask your self are they worth it for the money.  You can but something much more modern (Guzzi Inc) for the same or a lot less money.  When i see shattered ex Carabinieri T3/T4 for 6.5K  and pampered Norge's lucky to get 2k, you gotta ask yourself.
The tonti's are just gettin old and rare I guess.
Regards
Kev
Offline Stu
Re: Everyday T3?
« Reply #9 on: August 05, 2020, 07:47:36 AM »
Bought mine here in UK for £2.5k. Hadn't been taxed since 1990. Not much wrong, considering.  :undecided:
Thanks for input... will have to see how she goes once I get her back together this weekend.
I suspect she might be coming apart for a rear crank seal in the not too distant future  :sad:
Online Groover
    • Scooteropolis
Re: Everyday T3?
« Reply #10 on: August 05, 2020, 07:54:00 AM »
On top of what has been said for electrical (find NOS Magneti Marelli points and condensers if you can), I'd say also be sure your final drive has good seals (inner and outer) and proper oil level then you should be set.
1981 Moto Guzzi V1000G5
1987 Moto Guzzi LM1000SE, a
1987 Moto Guzzi LM1000SE, b
1980 Piaggio Vespa P200E
1980 Piaggio Vespa P125X
1980 Vespa Grande Moped
1980 Vespa SI Moped
http://scooteropolis.com/
Re: Everyday T3?
« Reply #11 on: August 05, 2020, 08:03:07 AM »
There's sort of a difference between "An Everyday Bike" and an "Only Bike".
Does it make sense to have ANY bike as an "Only Bike"?   Up to 1976, I had One Bike and no car.  From 1976 to 1999, I had One Bike and a car or truck.
Any bike can be down for some period of time if something goes wrong.   If it's a shop job, you're dependent on the shop's schedule and you could be without the bike for weeks if they've got it and can't get a part or something.   You have to decide whether you'd be happy with that or not.
Certainly a Tonti Guzzi could be a ride-it-every-day bike ... but what if it needs some maintenance that you just haven't got the time or parts to do?   Might it be a good idea to have a backup bike to ride, or is a car good enough as a backup?
My problem is, when my main bike needs maintenance, and I ride my backup, I tend to ride it until IT needs maintenance, and maybe by that time I've bought another, and ... and .... well, you get the idea.
Be that as it may, no reason that a properly sorted T3 couldn't do exactly what a 2020 Triumph or Honda could do in terms of on-road time and miles ....
Re: Everyday T3?
« Reply #12 on: August 05, 2020, 08:09:07 AM »
I’d keep the GS until you get this bike sorted. And I’d replace the entire wiring harness, contact Greg Bender @This OldTractor for all your wiring needs.
Offline acogoff
Re: Everyday T3?
« Reply #13 on: August 05, 2020, 08:14:08 AM »
    Gilardoni cylinders make a long in storage T3 an everyday bike
Marshall County Minnesota USA
Offline Stu
Re: Everyday T3?
« Reply #14 on: August 05, 2020, 08:24:09 AM »
This one had cast sleeves put in years ago. They're not perfect, little bit of rust pitting in one pot, but they're not the old chrome ones either. I'll leave it this way until I've run it a bit and seen if the pitting causes any issues.
Re: Everyday T3?
« Reply #15 on: August 05, 2020, 08:30:04 AM »
I was going to say he'd mentioned it had iron bores.. but Tom is right. The weak link in the bike other than the chrome bores is that old wiring. It may (or may not) be ok. I had an SP where the copper inside the sheath was green. At that point, a call to Greg Bender is in order.
Offline Stu
Re: Everyday T3?
« Reply #16 on: August 05, 2020, 08:43:42 AM »
I get you... this is where I've been most of my life. I've got to the stage now where I only ride for pleasure when I want to... commuting and other necessities are all done in the car (an old BMW z4 3.0i convertible, so no great hardship). Working on the bike (don't think there's any such thing as a shop job these days) is almost as much fun as riding them. Agreed there could always be a spares problem, but the bike's not a life and death thing.
A friend of mine has a theory. The more bikes you have, the less chance any of them are working at any given time... (She may be on here, between her and her husband they have at least three Guzzis including a Mk1 Le Mans and a Monza). It's probably been the case for me.  If I only have one, it gets all my time and attention, and money, and I make damn sure it's fixed!
Offline Stu
Re: Everyday T3?
« Reply #17 on: August 05, 2020, 08:45:21 AM »
I'll definitely give it a going over and check it through.
Offline acogoff
Re: Everyday T3?
« Reply #18 on: August 05, 2020, 08:56:18 AM »
     Sorry, I did not catch the part where it had iron sleeves. What I found on my T3 over the years with the harness is the crimp on ends themselves  work harden/get brittle and tend to split and not make good contact. Mind you I have not replaced the entire harnesssj just replaced about half a dozen female ends as they give problems. One of Greg's harnesses would not be a bad thing though. His stuff is top notch.
Offline MotoG5
Re: Everyday T3?
« Reply #19 on: August 05, 2020, 10:13:35 AM »
I visited a good friend this last weekend who has a 75' 850-T he bought new. It has been the only bike he has ever owned. It still runs and sounds great. Always maintained and repaired when needed so it has been down a few times but not for long. He has no plans to sell it. He has talked about possibly doing the Gilardoni upgrade in the near future.
Nebraska MGNOC State Rep
Re: Everyday T3?
« Reply #20 on: August 05, 2020, 10:33:46 AM »
Charging system: In addition to making sure the terminals are tight and clean, plus wiring is all in order, I'd recommend an electronic voltage regulator and a big battery. The updated v/r will enable to the system to charge earlier and better overall. A large battery such as the ETX30L has more power and reserve than most smaller, cheaper options. Or, one can upgrade to a permanent magnet alternator w/matching reg/rect. which has higher output.
Lighting: LED bulbs will reduce the load on the charging system, and if chosen wisely, will provide much better illumination as well.
Ignition system: Original points will stay in adjustment for quite a long while if the cam is lubed with Bosch Distributor Grease. I've put 17k miles on my Convert since I got it on the road and the points are still at the gap I set them at and timing is still spot on. I've had two Dyna III ignitions fail on other Guzzis, so will never fit another.
Offline SmithSwede
  • I don't want a pickle
Re: Everyday T3?
« Reply #21 on: August 05, 2020, 11:20:41 AM »
My theory is that bikes like to be ridden on a regular basis.  They will actually last longer and be less problematic if you use them.
If you like the bike, why hesitate to make it a daily rider so you can enjoy it more?  Life is short.
I would also be patient with the old girl.   Put her back into regular service, and be prepared to address any issues that crop up without getting frustrated or second guessing yourself.  Fix any issues the right way.   Pretty soon it will probably be fine.
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Online nick949
    • Nick Adams Writing
Re: Everyday T3?
« Reply #22 on: August 05, 2020, 02:47:01 PM »
Carry a comprehensive toolkit. Ride  :thumb:
People are too scared of the occasional breakdown. It's never likely to be something desperately dire. Carry a few spares. Fix it yourself.
Nick
Online moto
  • Fear the deer!
Re: Everyday T3?
« Reply #23 on: August 05, 2020, 03:52:45 PM »
My T3 has been an extremely reliable bike, always starting, running well, never leaving me stranded.
I use the Dyna electronic ignition system, which some distrust but I have found reliable.
Obviously you know that you will have to service the bike from time to time.
Moto
P.S. The Greg Bender wiring harness, should you give up on the one you have, is here: http://www.thisoldtractor.com/for_sale_wiring_harness.html.
850 T-3
Griso 1100 corretto
Online moto
  • Fear the deer!
Re: Everyday T3?
« Reply #24 on: August 05, 2020, 03:55:09 PM »
Also old VW bugs, which share the same technology! (See the movie Sleeper.)
M.
850 T-3
Griso 1100 corretto
Offline wirespokes
Re: Everyday T3?
« Reply #25 on: August 05, 2020, 05:11:58 PM »
I got the 77 T3 about five years ago and the only time it let me down was the starter wouldn't start. A few roll starts got me home. Since then I've had an 87 LM I've put 20K on, an 85 LM I resurrected (parked since 1991) and an 84 LM III. I don't recall any issues with them once they were sorted. They all needed a clutch, but each for a different reason, none because the friction material was worn out.
I've ridden these bikes on trips and would trust them to a X country trip tomorrow. They're all I've been riding in the last five years.
Offline TOMB
Re: Everyday T3?
« Reply #26 on: August 05, 2020, 05:42:12 PM »
Im riding a 76 Convert with 60000 miles. This is my new to me 9 years ago.
Look at my signature below for the mileages on old Guzzis.
To quote a old Guzzi rider IRON MIKE " your not riding it hard enough".
Mike was a very good friend of mine who passed away way to soon but people on this board
have great memories of Mike.
Sort out your bike and enjoy many memorable miles.
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Re: Everyday T3?
« Reply #27 on: August 05, 2020, 05:52:47 PM »
My "almost new" G5 is on it's second time around the odometer.  :smiley: I'd get on it tomorrow, and head out to California fully expecting to get there..
Re: Everyday T3?
« Reply #28 on: August 05, 2020, 05:53:43 PM »
T3 being a keeper and every day rider.  :thumb:  The problem on mine was that some spokes on the front wheel snapped.  That's fixed and I'd ride it again as the only bike in the fleet to be on the road.
« Last Edit: August 05, 2020, 09:01:02 PM by Tom »
Offline Testarossa
    • Skiing History
Re: Everyday T3?
« Reply #29 on: August 05, 2020, 08:11:46 PM »
I acquired my 850T in 1983 and it was my only bike until the flood in 2013. A daily rider most of the year throughout that time, and a dependable one. It was down for the winters because I lived in ski country.
Electrical issues:  Bit by bit I replaced everything electric. The T has some problems you won't see in a T3 (weak alternator and switchgear, wrong master cylinder for instance) and wound up with my own wiring harness, somewhat simplified to shorten critical circuits. When I upgraded the alternator I adopted a solid-state rectifier/regulator. The factory switchgear is gone, and the headlamp runs from a relay, which should be standard practice. I did switch to Gilardonis. After the flood rather than fiddle with lousy new-manufacture ignition plate and condensers I put in a Dyna III and am happy with it. The original clutch began slipping around 50,000 miles but I don't know how much of that is due to the drowning.
After the rebuild it's better than new and I could get by with it as my only bike and daily ride. Of course I no longer commute, and the  rest of the collection is fun so those bikes aren't going anywhere.
Bottom line is that with regular maintenance and fixing the electrics as needed, a T3 can be immortal. If you live in a damp climate, daily riding is part of regular maintenance.
