Author Topic: oil leak '73 Eldorado  (Read 2660 times)
Offline samfrank
« on: August 09, 2020, 01:08:55 PM »
I was out riding a few weeks back and the bike started to lurch/hesitate. I pulled into a gas station and noticed a serious oil leak coming from the air filter housing area. I added some oil to get me home. I don't consider myself very mechanically astute but I checked some things out. The air filter was in serious need of replacing. I did that. I'm not sure if a fouled air filter would lead to an oil leak. I don't understand the mechanics of the oil recirculating system. The mechanic I HAD replaced this oil breather a few years back but not with OEM equipment.  Any ideas on what to look for or where to start would be greatly appreciated. I've got way too much $ into this bike and not really to looking at pouring more into it.
Sam Frank
1973 Eldorado
2013 Norge - moving to Arizona to live with John.
2015 Yamaha FJR1300
Offline nick949
    • Nick Adams Writing
Re: oil leak '73 Eldorado
« Reply #1 on: August 09, 2020, 01:26:59 PM »
Had you over-filled it? 3 litres only or it will puke.
Nick
« Reply #2 on: August 09, 2020, 04:04:42 PM »
On Loopframe Guzzis the engine breather and air filter are two totally separate systems, not connected in any way (at least not from the factory). If the breather wasn't replaced "OEM equipment" then what was installed? A photo might help.
It could be "the mechanic" replaced the breather box with one with a working disk-type check valve and added a Tonti-style ball-type check valve as well. If so, they can work against one another and cause oil to be ejected from the engine.
Perhaps it's nothing more than a burst breather hose.
However, neither of the above would cause it to lurch/hesitate.
Offline moto-uno
« Reply #3 on: August 09, 2020, 04:16:34 PM »
 ^+1 , possibly if the air filter itself was saturated in oil it could sure throw the running off , no ?  Peter
 As above pics are always a help.
« Reply #4 on: August 09, 2020, 04:53:43 PM »
Assuming stock air box, it would be very difficult to saturate the filter. The breather isn't connected to it in any way and the only openings are small louvers on the sides and holes in the bottom. Oil would have to blow up from underneath, or blow back through the carbs to get inside.
Offline samfrank
« Reply #5 on: August 09, 2020, 06:49:53 PM »
Here are a few pics of the breather and air filter
[/url]
[/img]
1973 Eldorado
2015 Yamaha FJR1300
« Reply #6 on: August 09, 2020, 07:24:06 PM »
Everything I posted above is made irrelevant by that photo. I'm not sure what breather box that is, something "custom". It looks like there's a second one back above the voltage regulator with a hose right into the air filter housing. So, the air filter could definitely be saturated with that system and that would definitely cause it to lurch/hesitate. How it's all supposed to work is something only the guy that built it knows.
Offline Furbo
« Reply #7 on: August 10, 2020, 04:01:17 PM »
Don't think I've ever seen an Eldo with the original filter still in place....
Killeen, TX
'96 Sport 1100
'72 N. Falcone
'72 Eldo
Eccl 9:9,10
Offline TOMB
« Reply #8 on: August 10, 2020, 06:54:55 PM »
It looks like a variation of an Agustoni breather from the LeMans bikes, and used incorrectly,
TOMB
TOMB
CENTRAL CONNECTICUT
1972 AMBASSADOR 169000 MILES
1978 G5 170000 MILES
1973 V7 SPORT 25000 MILES
1973 ELDORADO 300000+ MILES
1980 CX100 50 MILES
MGNOC # 2723
Offline moto-uno
« Reply #9 on: August 10, 2020, 06:58:51 PM »
 Nice colour matching on the intake manifolds ! Peter
« Reply #10 on: October 21, 2020, 08:39:35 PM »
Sam's Eldo is here at the shop now and I've started digging into it. The breather system is quite bizarre - the box itself is quite nice - reed type valve in top, but the rest is a bit of a mess. It's all removed and will be replaced with a standard Loop breather box.
The hose going through the airbox is the oil return.
It snakes around the right side of the box...
...and hooks up to the return line on the top of the engine.
A couple of extra holes in the airbox.
This is inside the top of the airbox.
Connections poking out the back.
Why would you put a jet into the oil return circuit to restrict flow?
All of it removed.
Reed valve in the top of the breather box.
Someone went to a lot of trouble to rotate the top of the box from it's original orientation.
« Reply #11 on: October 21, 2020, 10:14:46 PM »
I've never had any "expulsion of oil" unless I filled to the 3 liters specified in the manual. 3 quarts and there's been zero problems over more than 100,000 miles. <shrug>
There's a Harper's/Pertronix Ignitor in the distributor.
« Reply #12 on: November 01, 2020, 09:19:45 AM »
Original type breather installed.
« Reply #13 on: November 01, 2020, 10:30:36 AM »
That looks a lot less cluttered.
« Reply #14 on: November 01, 2020, 10:35:28 AM »
And it won't pump oil into the air filter.
Offline stmike
« Reply #15 on: November 01, 2020, 02:29:18 PM »
One of our riding crew had one of these awhile back. We affectionately called it Moto Valdez.
« Reply #16 on: November 01, 2020, 03:26:44 PM »
One of these what? If you mean an old Eldorado, they're no more likely to leak than any other Guzzi and if they do, need to be repaired. Simple.
« Reply #17 on: November 01, 2020, 03:50:04 PM »
Much better.  Making a living unfarking other so-called “mechanics” handy work.  Lotta job security out there!
