Author Topic: Early Stelvio Battery Case Chafing.  (Read 926 times)
Offline John Warner
  • Growing old is mandatory, growing up is not . . .
    • Stelvio/V85 Owners Group FB
« on: August 12, 2020, 09:44:14 AM »
Fitted a new Battery today.
Motobatt MBTX16U.
Last one (same type), has been in since Jan 2016, and was getting a bit 'tired'.
Was regularly struggling to turn the Engine over reliably from cold.
If I just hit the Button and let it do it's 'Auto-Start' thing, it would usually just do half-a-spin, then stop, with the 'Blank Dash' scenario.
Holding the Start Button down bypasses the sequence, and it would always start, albeit with a slight pause as it struggled past compression.
Starts nicely now.
Found some damage on the old one, where the Welds on the Bracket had been rubbing.
Not far off breaking through maybe.
Might be worth checking if you have the early Small Tank model.
I removed the original Foam Rubber Pad it sits on, and used some slightly thinner Adhesive-backed Foam, adding a section where those Welds are.
Also levered down on the Retainer while tightening the Screws, to make sure it was as secure as possible.
« Last Edit: August 16, 2020, 05:33:31 PM by John Warner »
Doc out . . .
Stelvio Owners Group on FB ~ https://www.facebook.com/groups/888995181188209/?fref=nf
Offline bigbikerrick
Re: Battery Case Chafing.
« Reply #1 on: August 12, 2020, 12:44:39 PM »
Thats on a Stelvio? Would a Griso be the same?
Rick.
« Reply #2 on: August 12, 2020, 01:34:48 PM »
This is where having some old tubes around helps.  :thumb:  Custom fitted vibration abatement pads.   :shocked:
Offline John Warner
« Reply #3 on: August 16, 2020, 05:35:26 PM »
Rick.
Apologies Rick, forgot to put the model in the title, so used to being on Stelvio-only Forums/threads!
From what I can find on Google images, the Griso has a different layout, so wouldn't be affected.
Doc out . . .
