Is the bolt something common place? Like I said, I'll have to order it, but if I could get something from a local hardware store to replace it, that'd be great. I don't have high hopes for that.
Hi all,I got new levers for my 2019 V7iii night pack. I bought cheap levers from aliexpress, with the theory that if they didn't fit, I was only out $20 and I'd spend more on Pazzo. Anyway, they came today and I put them both on. I was a bit worried about the clutch lever, after reading some stories, but it went on easy enough, as did the brake lever. After a quick test ride, I noticed the brake lever was loose (Had some play moving it up and down). No big deal I thought, I'll just tighten the bolt a little more.Well, I don't know what I did, but I did something. Pics are below. I can spin the nut with my hand. But If I turn it to tighten it, it just keeps spinning, never really meeting resistance. If I turn it to loosen it, I can get it to where the pic shows below, but no lower. It just spins and spins and spins, never moving lower on the bolt. At this point, I think I need to cut the bolt and order a new one. I found the appropriate bolt on af1 to order. I am pretty pissed at myself for costing myself a week or more of riding. A few questions I'm hoping someone can answer.Has this every happened to anyone? My only thought is that I damaged a thread by accident, or stripped the threads on the nut? I've never had this exact situation before. I'm assuming I tightened too much?Is the bolt something common place? Like I said, I'll have to order it, but if I could get something from a local hardware store to replace it, that'd be great. I don't have high hopes for that.When I get the new bolt, has anyone had aftermarket levers where the fitment is a little small? Could I solve that by using a very thin washer on top of the brake assembly?
Grab the nut with some lock jaw pliers and pull down as you rotate the nut. Should come off. Then check the bolt threads for damage.Ciao
Didn't think of that. I was pushing down with a screwdriver as I turned, but nothing. I'm going to try the locking pliers tomorrow and see what happens. I did order new hardware, but I'm curious to just look and see what is going on with these threads.
I’d be concerned re the heat shrink PLASTIC wearing and thereby either loosening or binding. Suggest disassemble and cut off PLASTIC and do proper shimming with beer can Al (snapping red braces).
I'm having a hard time understanding what is so good about aftermarket levers? And what's wrong with the stock parts? I've never felt a need to change out the levers on any of my bikes.
Could you just put the OEM back on and do an adjustment by re positioning the angles?
