Author Topic: Who sells just the u joints 07 calvin  (Read 3237 times)
Offline Tim Henry
« on: August 15, 2020, 11:53:08 AM »
I had the 07 Calvin on centerstand to clean the rear wheel and noticed a slight bind turning it and can hear the u joint making noise when I used the stethoscope on the swing arm to locate so my question is who has just the u joints so I can rebuild the shaft as I've done plenty of driveshaft rebuild when I had old willys jeeps especially the one I put a v8 in it liked to do wheelies and I was 18
Re: Who sells just the u joints 07 calvin
« Reply #1 on: August 15, 2020, 01:09:04 PM »
I'm pretty sure the Vintage has the newer u-joint and shaft as one unit. You need to replace the entire thing and it isn't cheap.
Offline Tim Henry
« Reply #2 on: August 15, 2020, 01:16:15 PM »
Yeah that's what I am seeing I was hoping the knuckles were available separately I'm sure they must cross with something, this is my daily ride so don't have a lot of time to fool around
« Reply #3 on: August 15, 2020, 01:26:32 PM »
MG Cycle has the cheapest I noticed, and it was still close to $400.
« Reply #4 on: August 15, 2020, 02:07:19 PM »
There is a guy in NE that rebuilds the older Tonti & Loop. His info is out there, I'm sure Charlie knows who name, starts with a C.
Offline Tim Henry
« Reply #5 on: August 15, 2020, 02:45:44 PM »
I can't afford a bunch of down time I am wondering if anyone has an old one to get measurements or a makers mark part number
To cross reference them I'm sure guzzi isn't the only one using those knuckles
« Reply #6 on: August 15, 2020, 03:24:44 PM »
John Chicoine rebuilds Loop and early Tonti u-joints, but I'm not sure he's ever done any late Tonti stuff. <jchicoine@verizon.net>
Tim: You might treading new ground here. You might need to pull the driveshaft and measure the "knuckles" to find a cross-reference. For small-blocks, Loops and early Tontis, here's one source: http://www.theujointstore.com/moto-guzzi.html
Offline Tim Henry
« Reply #7 on: August 15, 2020, 03:49:30 PM »
Allan (antmanbee) mentioned he remembered someone in Canada  had them so I've been searching www found an outfit that sells Della Concordia u joints called technomec  but I need to know what is in our driveshaft so I can get correct items so if anyone has a old unit for measuring purpose
« Reply #8 on: August 15, 2020, 04:35:07 PM »
Thanks Charlie, I don't have his info, I just by new ones.
Online Tony F
« Reply #9 on: August 15, 2020, 04:48:51 PM »
If you have the bike on the center stand the rear suspension is at full extension which puts the UJ at maximum angle so what you are feeling may just be the UJ coping with that angle. Can you feel any play or slack in the driveline?
Maybe remove the wheel and the drive box and level the swinging arm with a jack so you can check for free play in the joint.
Tony
'79 SP1000
KTM Duke 890R
MV Agusta F4 (x2)
Offline Tim Henry
« Reply #10 on: August 15, 2020, 05:26:11 PM »
It makes a clicking noise when I also pushed
It in neutral definitely from the u joint the stethoscope confirmed it so it's getting ready to fail I was hoping not to have to spend for a whole shaft but not looking favorable like I said it's my only transportation so can't muck about
Offline Ncdan
« Reply #11 on: August 15, 2020, 05:29:29 PM »
Tim I have the number for a salvage outfit in Canada that you may be able to get a low mileage used one at a good price. I got a great deal in a TPS sensor a couple months back. PM me if you want me to look it up.
Offline Tim Henry
« Reply #12 on: August 15, 2020, 05:58:08 PM »
Yes please do I pmd my information
Offline 80CX100
« Reply #13 on: August 15, 2020, 06:31:36 PM »
     Hey Dan If you've got info on a Canadian salvage outfit, go ahead and post it here, or please pm me the info as well.
    Tks
    Kelly
     ps I seem to recall seeing a post recently about CVTech in Montreal selling some parts, possibly that was the outfit mentioned re U joint parts, fyi
2008 California Vintage
2003 V11 Lemans
1979 G5 & 1980 Lemans CX100
« Reply #14 on: August 15, 2020, 06:48:04 PM »
Me too, most of the time.
« Reply #15 on: August 16, 2020, 09:08:24 AM »
Mine failed. One of the bearings locked up. The bike vibrated And made a 'clicking' noise at low speed. The splines on the back end were worn enough that I didn't even bother with trying to repair it.
« Last Edit: August 16, 2020, 02:18:11 PM by Wayne Orwig »
Offline OldMojo
  • Career of Evil
« Reply #16 on: August 16, 2020, 12:56:25 PM »
I'm surprised that no one has sourced a replacement from Motion Industries or the like.
'15 Griso 1200
'14 California Tour
'02 California EV
'80 CB 650C
Offline John Warner
  • Growing old is mandatory, growing up is not . . .
    • Stelvio/V85 Owners Group FB
« Reply #17 on: August 16, 2020, 05:45:49 PM »
Any idea what sort of Bearings/Bushes are used in the UJ?
I'd be surprised if they couldn't be sourced and replaced.
They were assembled from parts by the manufacturer, so you might be able to find replacements.
Doc out . . .
Stelvio Owners Group on FB ~ https://www.facebook.com/groups/888995181188209/?fref=nf
Offline Tim Henry
« Reply #18 on: August 16, 2020, 07:08:49 PM »
Exactly what I was thinking someone on the v11 site mentioned that place in Canada for Della Concordia u joints they have a bunch listed but which do I need that is why I hoped one of our bunch here had an old one so it could be disected to gethe a part number off the crosses or at least a accurate measurement, but looking like I am going to just get the whole thing from us vendor as no one on flea bay has any new or used right now
Offline wirespokes
« Reply #19 on: August 16, 2020, 07:45:34 PM »
There are several ebay vendors parting out Guzzis. Check out the listings for wheels and you'll find them. I can name a couple off the top of my head:
moto-dojo and pinwall cycle. Send a personal message asking if they have anything for you.
And then there's Harpers - I've heard they have a huge used parts selection.
Offline Tim Henry
« Reply #20 on: August 16, 2020, 08:08:16 PM »
That's on my to do list tomorrow and this week I've been working graveyard the past few weeks so I'm a bit of a zombie during the day I've landed a security gig  for less pay after being permanently furloughed from Jared here in Jacksonville told we can reapply for position if or when they open for normal operations and my other half was a victim of a staffing cut due to pandemic so that is why I'm trying to be a bit more frugal than normal
Offline Ncdan
« Reply #21 on: August 16, 2020, 08:12:43 PM »
Sorry I’m just getting back guys as I’ve been up to my arse in sea monsters and Sasquatch’s
Here’s the guy and his number, he’ll go out of the way to help you.
Offline Tim Henry
« Reply #22 on: August 17, 2020, 08:46:28 AM »
Just received an email from umberto at technomec says need dimensions of the u joint so if anyone saved the old one let me know
Offline Tim Henry
« Reply #23 on: August 18, 2020, 05:35:32 PM »
So I ordered the driveshaft they call the universal joint from MG cycle today as nobody had a salvage or old one to measure the universal joints from looking forward to the job then I'll see if old one rebuildabe as a back up
Offline pressureangle
« Reply #24 on: August 18, 2020, 05:46:43 PM »
If it's the same dimension joint, here's the skinny. Replacement is a bitch but it can be done.
E.
https://www.v11lemans.com/forums/index.php?/topic/20425-universal-joint-replacement/&tab=comments#comment-234774
Offline janguzzi
    • My YouTube Channel (Guzzi Content)
Kind Regards
Jan, Schuby (near the Danish Border), Germany
www.janguzzi.de
-1992-2002: 1000S, 2nd Series
-2002-2004: V11 Le Mans "Grigio Titanium"
-2004-2011: V11 Le Mans "Rosso Corsa" & 2008-2011: 950S
-2018-2021: California Vintage
-2011: Griso 8V & 2023: V85 TT "Giallo Mojave"
Offline antmanbee
« Reply #26 on: August 19, 2020, 04:05:27 PM »
Thanks Jan,
I also saw you post this on the V11 forum.
I think both Tim and myself have already viewed your excellent video. It is much appreciated.
Offline Tim Henry
« Reply #27 on: August 19, 2020, 09:11:36 PM »
It's supposed to be here on Saturday hope removing the old shaft doesn't fight me too bad I remember my old quota came right out now problem not sure how tight it's in carrier bearing yet
Offline Tim Henry
« Reply #28 on: August 24, 2020, 03:34:09 PM »
The new driveshaft arrived this afternoon from MG cycle  everything went back together without a hitch
The old u joint the one that mates with the transmission output shaft was locked up in one direction the other was fine but the yoke was worn where it goes into the carrier bearing so it's basically trash
Offline Ncdan
« Reply #29 on: August 24, 2020, 04:47:59 PM »
Good deal Tim, glad you got her done👍👍
