Author Topic: Guzzidiag and Check Engine Light  (Read 3864 times)
Offline SmithSwede
  • I don't want a pickle
« on: August 20, 2020, 03:13:29 PM »
Probably a dumb question.   I've got a persistent check engine light on my 2013 V7 stone, single throttle body small block.  I've been meaning to get Guzzidiag and load a Beetle map.
Does Guzzidiag read fault codes so I would know for certain why I've got a CEL?
Accentuate the positive;
Eliminate the negative;
Latch on to the affirmative;
Re: Guzzidiag and Check Engine Light
« Reply #1 on: August 20, 2020, 03:41:19 PM »
My CEL comes on quite often but by the time I get around to putting Guzzidiag on it's cleared itself.
One thing I think it may be is low battery Voltage, it can come on first thing in the morning and reset itself on a later start.
It's ridiculous that we have to connect a laptop onto the bike, it should show up a code on the dash.
Offline SmithSwede
« Reply #2 on: August 20, 2020, 04:31:58 PM »
I had the bike apart for a month to do the clutch.  No CEL before I took it apart.  Now a constant CEL.  I stupidly left the detached headers sitting just off my porch, and they filled up with rain water.  So I'm about 99.9% sure that the Lambda sensors are fubar.  All other electrical connectors are good, everything is hooked up and snug.
Just don't want to replace relatively expensive O2 sensors if that's not the fault.  And I may not replace them at all if I get a Beetle map.  I believe that map turns off the sensors anyway.
Offline malik
« Reply #3 on: August 20, 2020, 06:06:58 PM »
Yes, the Beetle maps usually turn off the lambda sensors, but to test the sensors, just unplug them at the connectors (LHS under the side cover, RHS in front of the battery) and see if you still get the engine light. With no power, they don't get to talk to the ECU. You can get sensor blanking plugs on the net - M18x1.5 - best to use a washer, they've a tendency to unscrew themselves with the vibration. Both my V7's seems to working fine without the sensors.
« Reply #4 on: August 20, 2020, 06:10:08 PM »
Vagrants V7 had a CEL. Guzzidiag indicated the O2 sensors were open circuited. He had unplugged them. So we plugged them in and then GuzziDiag said they were bad. Duh, that is why he unplugged them. So I used GuzziDiag to turn them off. The light went out, the error codes are gone, and he claims it runs better. YMMV.
« Reply #5 on: August 20, 2020, 06:11:35 PM »
If you just unplug them without turning them off, you get a CEL for sure.
Offline SmithSwede
« Reply #6 on: August 20, 2020, 10:03:08 PM »
I’ve run it 500 miles now.  Bike runs fine despite CEL.   I’m getting the same gas mileage I always do.
Online Vagrant
« Reply #7 on: August 22, 2020, 04:59:29 PM »
The Iii doesn't need a map but earlier years would benefit based On my 2015.
Offline chrisfer
« Reply #8 on: August 23, 2020, 02:07:09 AM »
Hello,
On my V7 III I removed the probes.
I had to deactivate them, with Guzzidiag then Tunerpro.
Then to disconnect them and remove I had to place a resistor (600ohm, 1 / 4W is fine), otherwise I had the engine light for a probe heating fault, visible under Guzzidiag.
With an exhaust without catalyst, I was finally able to enrich, especially the small openings, for a much more pleasant operation (and solve some pinging). :thumb:
« Last Edit: August 23, 2020, 02:50:17 AM by chrisfer »
2022 V7 850 Stone - 2019 V7 III Carbon - 2004 V11 RossoCorsa - 2002 V11 Le Mans - 1995 750 Nevada
« Reply #9 on: August 23, 2020, 03:30:33 AM »
Where would I find the control to turn them off on my V85  in Guzzidiag ?
beard
« Reply #10 on: August 23, 2020, 04:59:34 AM »
It is not possible with GuzziDiag  :wink:
You have to switch off the Lamda regulation, this diasables also all errors which are related.
For this you have to use TunerPro and my XDF file for the V85TT.
You have to use the IAW7SMReader to get the binary image of your software,
change the flag with TunerPro,
and write the modified file back with the IAW7SMWriter.
I don't think that you will do this.
If your error moves if you exchange the sensors, simply buy a new one.
A replacement type is not so expensive.
Online Chuck in Indiana
« Reply #11 on: August 23, 2020, 11:24:24 AM »
 :grin: :grin: I could picture Huzo's eyes glazing over..
Offline SmithSwede
« Reply #12 on: August 23, 2020, 11:39:52 AM »
Where can I get the cheaper replacement sensors?  Is there a part number reference?
« Reply #13 on: August 23, 2020, 01:35:18 PM »
Damn right.. :blank:
Online Vagrant
« Reply #14 on: August 23, 2020, 04:27:15 PM »
Smith, they were on the "does anybody own a V7 " thread on adv rider a few weeks back. July 8-2020 page 716 About $50 each or 1/2 price. I'll take a look for them if nobody pops up with them.
I would also see if Rock auto can reference the part # they are usually cheaper even with freight.
