Author Topic: Jackal brake light  (Read 983 times)
Offline Park Ridge Phil
Jackal brake light
« on: August 24, 2020, 11:16:15 AM »
Front works fine but no rear brake light.
Re: Jackal brake light
« Reply #1 on: August 24, 2020, 11:23:54 AM »
 The rear switch is hydraulically operated and sits on top of the rear master cylinder . Pull the wires and connect them with a jumper , if the brake light comes on it is the switch .
Offline knockerjoe
« Reply #2 on: August 25, 2020, 04:04:00 PM »
Did it turn out to be the rear switch? I have a new one on the shelf if you need it.
Online fotoguzzi
« Reply #3 on: August 25, 2020, 04:40:46 PM »
Could then check the wiring that runs under the fender, It can fall down, get rubbed and short out.
« Reply #4 on: August 25, 2020, 05:02:35 PM »
Thank you for the suggestions👍. Hope to get a chance to check it all out. Watching 3 grandkids now because of all the nonsense going on.
