Author Topic: Jackal Charging System  (Read 1640 times)
Offline nsmith
« on: August 25, 2020, 08:16:17 AM »
Now this Jackal has stopped Charging the battery. I'm not having much luck finding information in these newer than the T/T3 systems. So any REAL SIMPLE step by step diagnostic help would be greatly appreciated.
Thanks guys, some day I will have this thing road worthy again and I will owe you all a beer.
Neil formally from South Dakota now living it up in Arkansas
Re: Jackal Charging System
« Reply #1 on: August 25, 2020, 08:20:40 AM »
That uses the Ducati system.
It has two yellow wires coming from the alternator. The bullet connectors going to the rectifier/regulator often corrode and overheat. Make sure those are clean and tight.
The rectifier/regulator is not the most reliable bit on the planet. Often a diode goes out, and you get a weak charge, or they completely fail. Aftermarket replacements are often more reliable.
And of course the charge output passed through a fuse. Likely a 30 amp,  which you want to verify is good.
I found this fault finder. But there used to be a simpler one that just applied to that system.
https://www.euromotoelectrics.com/kb_results.asp?ID=121
« Last Edit: August 25, 2020, 08:29:34 AM by Wayne Orwig »
Offline nsmith
« Reply #2 on: August 25, 2020, 08:21:42 AM »
thank you so much.
Offline kidsmoke
« Reply #3 on: August 25, 2020, 08:56:55 AM »
Wayne, thanks for that hit list of things to check.
My Jackal has started being a bit weak after sitting for a couple of weeks (11.8) and won't kick over. I wonder if that corrosion you mention could be the culprit.
I know, I know....the real culprit is letting the bike sit. This summer at work has been unlike any for quite some time .....
'79 G5      (Gina)
'93 1000S (Monica)
'00 Jackal  (Claudia)
'09 GRiSO  (Perla)
Offline nsmith
« Reply #4 on: August 25, 2020, 09:11:16 AM »
Wayne, I have seen mention of the 30 amp fuse but have no idea where it is located. My diagram shows (all fuses 15 amp)
Offline nsmith
« Reply #5 on: August 25, 2020, 09:16:03 AM »
so if I unplug the two yellow wires and try for an electric value across or to ground what might I hope to find?
Offline Murray
« Reply #6 on: August 25, 2020, 09:27:33 AM »
50 volts AC at around 4000rpm across the two. I don't think the jackal has the 30amp fuse that came latter if I recall correctly.
« Last Edit: August 25, 2020, 09:34:54 AM by Murray »
Offline nsmith
« Reply #7 on: August 25, 2020, 10:42:06 AM »
Thanks we will start with that.
« Reply #8 on: August 25, 2020, 10:46:53 AM »
 Correct.
Offline nsmith
« Reply #9 on: August 25, 2020, 12:37:04 PM »
We are out of town for a couple weeks. Will let you know what we find when we return.
« Reply #10 on: August 25, 2020, 12:46:59 PM »
Yes, I recall that they didn't all get fused did they.
« Reply #11 on: August 25, 2020, 12:48:52 PM »
It should be floating, as in open circuit to ground. A somewhat high AC voltage when unplugged at high revs, as Murray noted.
