Author Topic: Timing Chain Sprocket Marks Alignment  (Read 1265 times)
Offline ozarquebus
  • Grand Canyon Pack Rat
  • Riding since 1979
« on: September 15, 2020, 12:17:34 PM »
On a V1000G5, I have reinstalled timing chain, but marks do not align exactly. They align at least as well as they did before disassembly, but slightly different orientation. Is this good to go in attached picture and withing the adjustment range of the dizzy or do I need to take it off and try again for perfect alignment?
 Convert Hangar Queen
Offline Stevex
Re: Timing Chain Sprocket Marks Alignment
« Reply #1 on: September 15, 2020, 12:21:15 PM »
Looks no different to mine.
Offline moto-uno
« Reply #2 on: September 15, 2020, 12:31:33 PM »
  How would you suspect you can get closer than that , considering how everything is located on the sprockets ?
  The distributor couldn't care less where those marks are , (it can be rotated 360 degrees).  Peter
« Reply #3 on: September 15, 2020, 12:36:28 PM »
That's about as close to perfect as you'll get on older Tontis. Good to go.
Offline ozarquebus
  • Riding since 1979
« Reply #4 on: September 15, 2020, 12:44:55 PM »
Thanx
Offline nc43bsa
« Reply #5 on: September 15, 2020, 09:09:57 PM »
Looks good to me..
Don't forget to bend the lock washer tab over.
1990 MilleGT
« Reply #6 on: September 15, 2020, 09:31:53 PM »
The easy way to check, the inlet valve and exhaust valve rock at TDC
Get it out by one tooth and it will be obvious.
When I say rock I mean as you approach TDC one Valve will be closing.
As you go past TDC the other valve will be opening.
Right at TDC they will both be partially open.
This is the same for any 4 stroke I have seen.
Offline lucky phil
« Reply #7 on: September 16, 2020, 01:59:34 AM »
Its a Guzzi, not a precision piece:) There's a limit to how accurate timing marks can be with chain driven cams. Not like lovely Gears:)
Ciao
