Author Topic: Norge tire balance  (Read 1827 times)
Offline delrod
Norge tire balance
« on: October 03, 2020, 07:52:06 AM »
Putting a new rear on my 08 norge. Rear wheel has over two ounces of weight on it. New Shinko does not have an obvious red dot (it w was late last night and I was tired). Should I A mount it and see what happens. B Take weights off. C take it to town for balancing. Two ounces of weight seems like a lot to me. This is first tire change on the bike for me and I  lack a previous baseline for guidance
Doug in Pittsburg KS
2003EVT
Re: Norge tire balance
« Reply #1 on: October 03, 2020, 08:09:57 AM »
If it were my bike I would remove the weights that are on there, I'm sure the wheel was balanced when it came from the factory, the weights were added for the specific tire you are replacing.
Motorcycle wheel are large diameter a slight unbalance cannot be felt, the tire shops insistence on adding weights and their reluctance to fit tubeless tires to my spoke wheels is the reason I now fit my own tires. "balancing wheels" is just another way for the shop to add on an extra charge IMHO.
The last time I had a tire fitted by the shop they did a balance but I asked them to give me the weights so I could add them if I felt the need, they seemed to work fine in my jacket pocket.
« Last Edit: October 03, 2020, 08:14:08 AM by Kiwi_Roy »
Offline Ncdan
« Reply #2 on: October 03, 2020, 08:15:47 AM »
I’ve never balanced a MC tire in all my years of motorcycles. If you notice a shaking in a newly mounted tire you have a bad tire more than likely, IMHO
Offline Zoom Zoom
« Reply #3 on: October 03, 2020, 09:20:23 AM »
I would suggest breaking the bead and rotate the tire 180 on the rim. Sometimes that helps. Not always, but it's something easy to try.
ZZ
Offline flower_king001
« Reply #4 on: October 03, 2020, 09:23:18 AM »
All the Shinko's i have mounted have the red dot. I would always remove the previous wheel weights and start balancing from scratch.
1971 BMW R90/5
1998 Moto Guzzi 1100 EV
2005 BMW 1200 RT
2007 BMW 1200 GS
2007 Moto Guzzi Breva 1100
Offline Perazzimx14
« Reply #5 on: October 03, 2020, 09:49:51 AM »
as a former tire balancer I stopped several set so f tire ago and have noticed absolutely zero difference. This is with motorcycle tires and also the darkside in two instances.
The only form of balancing I'd do now if the wheel had TPMS sensors on it. I'd balance the wheel only then  spoon whatever tire on and ride.
GeorgiaGuzzi
« Reply #6 on: October 03, 2020, 09:56:52 AM »
^^^^^^ this. Some manufacturers use a yellow dot. Look at it in the light with glasses. The mechanic I use doesn’t balance tires, and he works on some seriously fast bikes.
« Reply #7 on: October 03, 2020, 10:41:56 AM »
you made me go look Doug, I have a buddy with a tire machine do mine. He spin balances them every time. Hopefully this weather will clear and I can go scuff this sucker up a little 👍
« Last Edit: October 03, 2020, 11:10:14 AM by Guzzistajohn »
Offline delrod
« Reply #8 on: October 03, 2020, 11:20:15 AM »
Found the red dot. Mount and weights removed.gonna go scuff it up.If I don't come back....... Well you know
2003EVT
« Reply #9 on: October 03, 2020, 11:23:08 AM »
You kept going?
Offline Perazzimx14
« Reply #10 on: October 03, 2020, 12:19:31 PM »
You kept going?
...without any issue whatsoever
« Last Edit: October 03, 2020, 12:20:07 PM by Perazzimx14 »
Offline delrod
« Reply #11 on: October 03, 2020, 02:35:16 PM »
All good did the ton for a while and no problem. Exercised the Abs a few times. Good to go
2003EVT
« Reply #12 on: October 03, 2020, 03:10:03 PM »
I went out 66 west, cut N @ Halltown and around the west side of Stockton Lake and had some catfish tacos at the Dadeville Cafe.
Ended up being about a 130 miles of "scuffing" didn't quite make the ton however. I think I'll scoot over to Mother's brewing and get a growler of Octoberfest then lay 'round the shanty and put a good buzz on  :thumb: :thumb: :thumb:
