Behind battery hanging on rubber holders & under R/H side cover on the Sport like a Breva. To find out which one it is either use lites & feel for click OR go to wiring diagram and match which one has the correct colored wires(what I do).I would clean all the plugs for the relays after 12yrs.
If the High beam indicator was On and the bulb was not it would likely be a bad connection on the holder or bad ground.The High beam indicator has its own ground through the dash and it picks up the relay status direct from the relay.The schematic shows separate bulbs for High and Low is that the case? (I believe the Sport and the Norge use the same schematic)You can see the white wire from the switch splits going one way to the lamp and the other way to the dash to turn on the light. So we can say the white wire is alive in High Beam position.https://www.thisoldtractor.com/guzzi007/schematics/2007_Norge.gifAs above only this is switched by a relay.https://www.thisoldtractor.com/guzzi007/schematics/2007_Norge_ABS.gifYou should be able to get a new lamp holder c/w leads at any Auto parts store.
