Author Topic: Do I replace the headstem bearing?  (Read 4837 times)
Offline Bazil
« on: October 17, 2020, 04:04:47 PM »
Working my way through my V40 Targa at the moment and pulled the triple tree to search for grease. Luigi didnt have any in the 90s either - what little existed was dry and grungy, and the top bearing didnt run smoothly. Took it out and cleaned it, and it seems to run well now with no notchiness. Looking at the race, I can see wear marks but can't feel any depressions. Mileage shows less than 4000 km, but I suspect this may not be accurate.
Do you think its good enough to repack the bearing and reinstall it, or should it be replaced.
Cheers
Bazil
1986 Lario ( long gone, still missed)
1985 Mark IV Lemans ( Gina)
1991 V40 Targa ( L'il Jeannie)
1962 Royal Enfield Crusader Sports
Offline n3303j
  • Ron Cichowski
Re: Do I replace the headstem bearing?
« Reply #1 on: October 17, 2020, 04:22:18 PM »
Sure looks corroded to me. Parts are cheap and labor expensive. Replace the bearings while you are in there and stuff them with grease. Then ride 10 or more worry free years.
« Last Edit: October 17, 2020, 06:01:26 PM by n3303j »
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #2 on: October 17, 2020, 05:37:39 PM »
Yep. Knock out the races and replace them. Yeah, I know.. it's not a particularly fun job..
Online John A
« Reply #3 on: October 17, 2020, 08:02:38 PM »
Nonsense, a little crocus cloth on them races and they’re good for another half season. :evil:
Well, I thought it was funny.  Replace both the upper and lower cups and cones and it’ll be fine for a very long time.  The lower bearing can be troublesome to get off the stem.
« Last Edit: October 18, 2020, 09:14:56 AM by John A »
Offline Bazil
« Reply #4 on: October 18, 2020, 03:23:25 PM »
Thanks for the second opinions - I'll get some bearings on order.
That bottom race is a bear to get out too; last one I removed needed a Dremel in the end.
Bazil
« Reply #5 on: October 18, 2020, 06:01:21 PM »
Bazil
Yep.
« Reply #6 on: October 18, 2020, 07:07:28 PM »
Bazil
I use a bearing splitter & steering wheel puller, still not fun.
« Reply #7 on: October 18, 2020, 10:07:19 PM »
Dremel cut and replace.
Offline lucky phil
« Reply #8 on: October 18, 2020, 11:41:17 PM »
Bazil
OR you can run a bead of weld around the race and it will fall out. OR you can get you Barbeque gas bottle and turn it upside down outside and let liquid LP run onto the race and tap it out with a Brass drift.
Ciao
Online John A
« Reply #9 on: October 19, 2020, 08:03:54 AM »
Or you can just use a bloody great big hammer and punch and squarely drift it out.
Use a big hammer to move stuff and a small hammer to form stuff.
The cone that’s on the stem is sometimes troublesome when you are trying to save the rubber washer underneath it.
Offline acguzzi
« Reply #10 on: October 19, 2020, 08:17:05 AM »
another option is to partially press the stem out of the triple clamp, just a little way so you can get a puller underneath the bearing, or press it further till it comes loose.
Offline wirespokes
« Reply #11 on: October 19, 2020, 09:22:14 AM »
The bearings don't move much so they wind up leaving marks on the race. No biggie. If the rollers don't have flat spots and you can't feel any notches in the race, I'd re-use them. Grease and reassemble.
When in doubt, most guys will advise you to remove and install new. i know, I'm taking the unpopular approach, but with such low miles and no wear to speak of, they're still pretty much at beginning of life. I'll bet they have ten to twenty years of hard use left in them.
They say labor is the expensive part. Yeah - it took nothing getting to this point, it's going to be quite a bit more removing the lower tree and then removing the races. You'll be saving a bunch of labor by greasing and reinstalling what you've got.
« Reply #12 on: October 19, 2020, 09:54:50 AM »
Bazil
Offline n3303j
  • Ron Cichowski
« Reply #13 on: October 19, 2020, 10:28:16 AM »
Recently read a great story where a boatyard removed a propeller under water with C-4 explosive.
That would be a fun experiment on the stem bearing.   :boozing:
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
jwinwi
« Reply #14 on: October 19, 2020, 11:03:33 AM »
I think the bottom race the OP is referring to is the inner race on the stem:  Much harder to remove than the 2 outer races. I've used a reinforced cutoff wheel on a Dremel to cut a good size notch and then hit it with a chisel which will crack it. YMMV
« Reply #15 on: October 19, 2020, 12:18:56 PM »
Oh I see. In bicycles that would be the crown race, and I usually just knock them off with a screwdriver (i know, bad) or a chisel-shaped punch and a mallet.  Only works if there is a small relief in the fork crown to fit such a tool, or the race overhangs the edge by enough to get the tool seatedon it for the *WACK*
« Reply #16 on: October 19, 2020, 12:32:57 PM »
Large bearing separator clamped onto the stem under the inner race, separator supported in the (big) vise, nut threaded onto the stem to protect the threads, apply (big) dead blow hammer as needed.
« Last Edit: October 19, 2020, 03:40:14 PM by Antietam Classic Cycle »
Offline moto-uno
« Reply #17 on: October 19, 2020, 01:49:58 PM »
  I'm with "wirespokes" on this one . If you can clean and grease the top (easily removed) neck bearing , I'd then take it
and push firmly up into the bottom race and rotate back and forth a slight amount . If you sense any roughness then replace .
And if not convinced , clean and grease the lower bearing (still on the lower tree ) and try again , no roughness , then why bother.
I only suggest this because for many people at home the lower bearing on the tree (stem) can be quite a struggle to remove .
Peter
Offline wirespokes
« Reply #18 on: October 19, 2020, 02:13:29 PM »
I'm a firm believer of not fixing not-yet-broken stuff.
I like your method Charlie!  :thumb:
Thank you.
I wouldn't have thought of doing it that way, but my bearing separator doesn't get much use, so along with it and the press, it should be an easy job.
Offline lucky phil
« Reply #19 on: October 19, 2020, 03:34:21 PM »
Thank you.
Lucky you don't maintain aircraft :laugh:
Ciao
Offline n3303j
  • Ron Cichowski
« Reply #20 on: October 19, 2020, 04:52:19 PM »
Aaaargggh! (Cringe)
There are so many ways to get that inner race off the steering tube that don't involve wailing away at the threaded end of the steering tube with any kind of hammer.
Pick any one of them first!
« Last Edit: October 19, 2020, 05:39:50 PM by n3303j »
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
Offline moto-uno
« Reply #21 on: October 19, 2020, 05:00:24 PM »
 ^^  You mean like Boeing ? :evil: , Peter
« Last Edit: October 19, 2020, 06:30:30 PM by moto-uno »
Online Moparnut72
« Reply #22 on: October 19, 2020, 05:46:49 PM »
Ciao
There is some truth to that. Google the Warrington Effect.
kk
Mopar or Nocar
Current Bike:
2026 Triumph T120
1976 T3 disaster
Taking new riders for a spin:
2023 V100 Navale
2019 V7lll Special
2016 Audace
MGNOC #24053
Offline Moto Vita
« Reply #23 on: October 19, 2020, 06:34:00 PM »
Bazil
 After you have the race out use your dremel to cut a notch or two in the frame so you can use a punch to easily remove it next time.
Offline moto-uno
« Reply #24 on: October 19, 2020, 06:34:52 PM »
 ^^ I just tried to google your "Warrington Effect " . Possibly you could supply a link . Everything that I found
 seems kinda irrelevant .  Peter
« Last Edit: October 20, 2020, 12:15:47 AM by moto-uno »
« Reply #25 on: October 19, 2020, 06:56:38 PM »
Aaaargggh! (Cringe)
Why? This works (for me). The threads are protected by the nut and a dead blow hammer isn't going to deform them anyway! Unless the inner race is rusted stuck, it doesn't take a lot of force to remove. Never damaged any of the dozens of steering stems I've done this way.
« Last Edit: October 19, 2020, 07:01:32 PM by Antietam Classic Cycle »
Offline n3303j
  • Ron Cichowski
« Reply #26 on: October 19, 2020, 07:10:40 PM »
You are a professional. So am I. In our experience background we learned just how much "hammer" was acceptable. Just like we get to break a few bolts while learning how hard is "too hard" when extracting a frozen fastener.
Most people don't have enough hammer experience to know the crossover point between persuasion and disaster. Best they begin with a less expensive project for their training session.
'98 MG V11 EV
'96 URAL SPORTSMAN
'77 MG 850T3 FB
« Reply #27 on: October 20, 2020, 04:17:12 AM »
The top bearing looks ok but what's the bottom one like?
If you need to do one you might as well do them both.
Use a lot more grease of course.
Offline s1120
« Reply #28 on: October 20, 2020, 06:10:12 AM »
I saw a vidio ad on facebook the other day. It was meant for removing the inner race that sometimes stays on a car wheel hub when you press the bearing off. It was a cone that spun. You mount it in a vice, put the hub on, spun it while heating the race with a torch. In the vid it just slid off..and we know how that is..  but it still looked like a cool fixture to get heat all around. I wondered if it would work for stem bearings.
Paul B
Online John A
« Reply #29 on: October 20, 2020, 07:58:36 AM »
This works for pre 98 forks but on later ones it is more likely to destroy the stem, they are tighter than Dicks hat band.
I tried to get the stem out of a couple trees with no success. Ruined the stem on both, they bent before moving. They were from crashed bikes so it was a trial but if I need a stem I will turn one on the lathe.
