Author Topic: Roundhead cranks....  (Read 1028 times)
Offline rjamesohio
« on: October 18, 2020, 09:06:56 AM »
Hi all -
I'm moving my feet on my G5 and wondered:
Are the crank throws and pin diameter the same for 1000 CC motors as 850's?
I ask because I have a spun rod journal on my G5 crank and it will likely cost me as much to repair that crank as to possibly source another good crank to use in that engine with new bearings obviously.
Ron
Ron James
Ex LM V
Ex SP1000
Ex Eldorado
Ex Quota - parts live on after crash
EX 1000G5
EX 850T3
EX 2003 V11 Stone
EX 1996 California 1100i
EX 2006 Big Breva
1979 1000 G5
1993 California iii
Spine Frame Mongrel
1999 BMW R1100R
Waynesville, Oh
9372715697
Re: Roundhead cranks....
« Reply #1 on: October 18, 2020, 10:01:25 AM »
Yes, both 78mm and pin diameter spec is all the same from 700 on. I'm doing a 700 motor now.
Offline 1down5up
« Reply #2 on: October 18, 2020, 02:24:19 PM »
V7 Sport, 750s 750s3 have cranks with a smaller stroke, and any that were for a loop wont have the threaded hole in the front nose for your alternator rotor bolt.
« Reply #3 on: October 18, 2020, 06:23:21 PM »
Hi all -
Ron
Convert & G5 cranks are "graded" - ones with a white paint spot are different than those with a blue paint spot. Crankpin diameters:
Blue: 44.008-44.014 mm
White: 44.014-44.020 mm
When checking the balance on the Convert and G5 crank, the weight used is 1.650-1.680 kgs.
850-T crankshaft: crankpin diameter: 43.893-43.994 mm
Balance weight: 1.471-1.601 kgs.
850-T3 crankshaft: crankpin diameters: same as the Convert & G5
Balance weight: 1.586-1.616 kgs.
FWIW, for ~ $125 + shipping, I can have your G5 crank rod journal ground.
« Last Edit: October 18, 2020, 06:55:00 PM by Antietam Classic Cycle »
